#169 |
Drives: 2022 BRZ Limited
I had a chance to test the front splitter and @Wonderbar Driveway Labs T1 diffuser yesterday, woot!
![]() ambient temps were about 92 F+ degrees (a more robust oil cooler is a must at this point) and I had to deal with the traffic all day.. I should be able to cut another 4-5 seconds with the current setup easily.. Important things to note, car feels a bit more planted after combining the Hancha/FT86SF front splitter with the Driveway Labs T1 rear diffuser (especially at high speed corners/sweepers) ..braking down feels a bit more improved as well ..either that or it's a placebo effect ![]() [ame="http://youtu.be/lqiiD42H0d0"]http://youtu.be/lqiiD42H0d0[/ame]
| The Following 3 Users Say Thank You to glamcem For This Useful Post: |
#170 |
I have a question to you aero guys @Wonderbar @eric6 @plucas
Is there a way to make an extension (made of aluminum) that is adjustable and can be attached to the OEM BRZ spoiler or TRD ? Like this one, I figured this would be a great upgrade for those who don't want to swap trunks or remove rear spoiler..it looks like it only uses rivet nuts on the spoiler itself (considerably cheaper to replace compared to a trunk in case a person wants to go back completely stock) ![]() http://www.moderncamaro.com/forum/ca...stall-z28.html if so please make this happen and put me on the top of the list I heard that adding a functional spoiler not only add the downforce but also help getting rid of the lift in the rear ..
#171 |
I know it's a completely different car but between the front splitter, hood and wickerbill GM was able to add 440lbs downforce with Z28 aero package !!
http://media.gm.com/media/us/en/gm/n...amaro-z28.html
#172 | |
Lacking brains
Drives: frz
Really doesn't take me much time at all. Just give in and get a trunk from one of the 9000 wrecked ones on ebay and throw a huge wing on it. |
#173 | |
#174 | |
Lacking brains
Drives: frz
on my end i had a plain trunk and wanted a spoiler anyway, so the hit there wasn't as bad, the wing was a punch in the **** though |
| The Following User Says Thank You to Model Citizen For This Useful Post: | glamcem (09-18-2014) |
#175 | |
Off Topic
| The Following 4 Users Say Thank You to gramicci101 For This Useful Post: | BurnetRhoades (04-25-2016), Captain Snooze (09-19-2014), glamcem (09-18-2014), Silver Ignition (09-19-2014) |
#176 |
#177 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
You might be surprised at what downforce appropriate for your car will do for you in slow-speed corners, too. My experience is that the numbers that come with a wing don't always tell the full story when it comes to the difference they make when you're on the track wheeling the car around. There are a lot of factors at play, though, and adding effective aero to a car is a process, even if you're installing a proven package from a known reliable source. |
| The Following User Says Thank You to dradernh For This Useful Post: | glamcem (09-18-2014) |
#178 | |
Drives: Subaru
#179 |
Off Topic
One potential problem with the OEM BRZ spoiler is the decorative risers on each side. The add-on spoiler would either be only for the middle or it would need cutouts for the risers.
You're basically looking for a taller, sturdier version of the STi gurney flap? |
#180 | |
Drives: 1966 Mustang, 2013 FR-S
![]() ![]() This is the exact reason I was designing a wing that mounts to the rear tow mounts. The lack of interest and personal funds has directed me to other projects. |
#181 | |
will do, thanks
#182 |
It helps that APR is rather close to us... :p
| New TRD Aero Parts & Others | zephyr69 | Cosmetic Modification (Interior/Exterior/Lighting) | 44 | 10-06-2013 11:20 PM |
| Aero Parts Availibility? | maj75 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-06-2012 11:48 AM |
| How do you buy aero kit / TRD parts? | scwewywabbit | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 03-17-2012 11:45 PM |
