#127 |
Drives: '13 Whiteout FR-S (M/T)
Did a quick search for this but didn't yield any results - is there a way to check what revision your tune is after it's been flashed? In retrospect, would have been good to rename the file before uploading.
#128 | |
Drives: 2013 FRS
Easiest thing to do, as you said, is rename the file when you load the tune into the OFT. |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | 1Cor10:23 (09-12-2014) |
#129 | |
Codename: Stitch
#130 | |
Drives: 86
But, there is no map for A01f. You said you support A01f map with a formal and how it is. http://www.ft86club.com/forums/showpost.php?p=1762805&postcount=5 Dose v2.06 have a difference with a v1.60 map. Dose not A01f support from this map? Last edited by boxerkim; 09-12-2014 at 09:59 PM. |
#131 |
Drives: 2013 Asphalt FRS
@Shiv@Openflash i just recevied the tablet Thank you!! One question i want to ask, do you remember which octane did you upload for the stage 1 that the tablet you shipped recently?
#133 |
Drives: FR-S Whiteout
Loaded up the v2.06 stg1 91 rom, went out for a drive then all of the sudden all the warning indicators come on and the OFT screen turns white.
| The Following User Says Thank You to solidONE For This Useful Post: | lucid215 (09-13-2014) |
#134 | |
Drives: FT86
Cann-buss communication error will have caused dash to go birko, most likely bad connection at obd port. OFT screen going white indicates the power to oft went on/off/on in quick sucession. Check connection to oft at obd port and at oft. no harm done but certainly will get your attention
#135 | |
#136 | |
#137 | |
#138 | |
#139 |
Drives: JAWS
@solidONE I bet you have a bad connection at your OBD2 port. Mine went bad from plugging and unplugging too many times and the same thing happened to me. I bet if you hold the connection at the OBD2 port and wiggle back and forth it will flicker and your car will trip out. I had to clear my code with a Scangauge and reset my ECU.
#140 | |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 09:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 08:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 12:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 03:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 09:02 PM |
