Pat.Thornton
Old 09-08-2014, 11:39 AM   #113
Synack
Boosted
Synack's Avatar
Drives: Sideways
Got my fork lubricated. Fixed the problem. We'll see how it holds up.
Usually the case. The boot on top of the transmission that shields the clutch fork from the elements easily comes out and doesn't easily go back in so it is no wonder why the clutch fork dries up so easily.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-09-2014, 06:54 PM   #114
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Follow up to an earlier post, I finally got word back from my dealer that they ordered a throwout bearing and shift fork. Its on backorder and will probably take a few weeks to get in.
aghuman is offline   Reply With Quote
Old 09-11-2014, 01:04 PM   #115
alv012
I started having the same issue this week. Crunchy pedal for the last few inches of pedal travel and a squeak. Took it in this morning dealership just told me they're gonna replace the clutch master cylinder. Most of the parts are on backorder so it may take a few days. Seems like most people just had the throwout bearing replaced so I'm curious about my diagnosis.
For reference, my car was built in 03/13, has 19.5k miles and is stock. Met a guy while I was waiting and he had a similar problem and they replaced his entire clutch. I'd recommend anyone who is worried about it just take it in, especially if you're in warranty. They didn't give me any hassles
alv012 is offline   Reply With Quote
Old 09-11-2014, 03:03 PM   #116
Synack
Boosted
Synack's Avatar
Drives: Sideways
I've replaced the master and slave cylinder already. It literally has nothing to do with the problem. They are just starting from the cheapest fix and will realize that that didn't fix anything and will have to open the transmission.
Old 09-11-2014, 03:58 PM   #117
alv012
Trust me I had the same reaction when I talked to the tech. I didn't push it for now but hopefully the collection of bills Toyota is about to get from me and all the others will push them for a TSB. Seems to me my best move will probably be using the hell out of the warranty then going aftermarket after.
I love this car and was planning on keeping it for a long time but now I'm going to be about paranoid about life after warranty. My itch for an NSX is slowly coming back.
The Following User Says Thank You to alv012 For This Useful Post:
Ramster (09-15-2014)
Old 09-11-2014, 04:20 PM   #118
stevemp5
Drives: scion fr-s
Originally Posted by gonzo View Post
Agreed. I'm taking mine back since the noise slowly came back after I adjusted my clutch pedal higher (previously had it adjusted really low).
Here's a video of mine taken today:
Can anyone with a replaced bearing confirm this is the same noise? Could this have been caused by adjusting the clutch pedal grab point too low?
I have the same sound, dealer change all clutch under warranty! But after that, i dont like the feeling of my shifter... feel more loose
stevemp5 is offline   Reply With Quote
Old 09-13-2014, 01:02 AM   #119
shellslinger
Drives: Whiteout FRS
Same issue here, the dealer stated that they could not replicate the noise so I was sent on my way.
I'm going to there after I drive around a bit, it usually makes that crunchy pedal feeling w/ the squeak after I've driven it around a bit. Then take it back to the dealer.
shellslinger is offline   Reply With Quote
Old 09-13-2014, 01:24 AM   #120
Fastbrew
Drives: 2014 Pearl White BRZ
Reading this thread makes me realize how grateful I am that this car was made. It is an econobox with econobox parts. Toyota/Subaru are getting punched in the nuts with all the repair bills. I am not sure what their bottom line will look like when all is said and done. But - I can anticipate them upgrading the components and charging more. Or just charging more with superficial changes. When a dealer jumps on the opportunity to replace an entire transmission / clutch assembly for a relatively minor issue with a $2 part - that has to hurt eventually.
I picked up my BRZ knowing full well that I was going to upgrade the shitty stuff to better stuff because I really like the platform. I have 8500 miles and I am on my third clutch and third set of TOBs. (I never had a problem with any of the TOBs - they were replaced along with clutches - that's another story)
Anyway - I feel bad for folks that are having issues but I can see where this is all headed
On top of that - most of these parts come from the same damn factories whether it is OEM or aftermarket. The one part that I worry about over time is the AISIN transmission. Not a ton of options to upgrade there. Anyway - my 2 cents for what it's worth.
Fastbrew is offline   Reply With Quote
Old 09-13-2014, 04:28 PM   #121
Ozzman
Drives: old
You really think more expensive cars use better parts? Keep dreaming. If it's mass produced, then every penny possible is cut where you can't see it.
Ozzman is offline   Reply With Quote
Old 09-14-2014, 02:20 PM   #122
kodyo
Drives: Scion FR-S
Mine started making this squeak noise as well. With hood open, it's clearly coming from the clutch fork. Anyone tried pulling the rubber boot back and spraying grease in there?
kodyo is offline   Reply With Quote
Old 09-14-2014, 11:59 PM   #123
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Mine just started making this noise as well. Guess I'll be taking it to the dealership on my days off.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 09-15-2014, 05:59 PM   #124
Ramster
Ramster's Avatar
Drives: Subaru BRZ Limited
Does anyone know if there is an aftermarket throw out bearing that someone sells? I've searched around and only thing i've been able to find are aftermarket clutch kits. Mine's started going out also but i'm thinking, is the OEM really any good if it went out after just 15k miles?
Ramster is offline   Reply With Quote
Old 09-17-2014, 05:47 PM   #125
CK_Bladesmith
Drives: Raven FR-S
Toyota just called me and said they will not be able to replace the throw out bearing under warranty because my car has a supercharger on it. Not very happy at the moment but I guess you gotta pay to play.
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
Ramster (09-20-2014)
Old 09-20-2014, 02:54 PM   #126
kodyo
Drives: Scion FR-S
Originally Posted by tunami View Post
I took a better video tonight of the problem area. Is there a fix for this?
Mine sounded exactly like this.
I'll answer my own question.
Pulled back the rubber boot around the clutch fork today and sprayed white lithium grease randomly inside the housing (with clutch in and out) and the squeak went away and it feels buttery smooth now.
Protips:
1) The bottle doesn't spray upside down, which makes maneuvering it into place difficult. It is possible to orient the can vertically on the drivers side of the bell housing to spray in grease.
2) Put a piece of tape to tether the spray straw to the can. The first one I had fell off into the bell housing.
I'll report back later on how long this fix lasts.
The Following User Says Thank You to kodyo For This Useful Post:
Gords_zenith (09-20-2014)
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
