Old 09-06-2014, 09:59 PM   #43
akyp
Drives: 2012 86
Shiv,s 2x tunes are much better knock wise and i pulled a bit of timing in problem areas for 98 ron fuels so the amount of fbkc or flkc will b verry little hopefully
I am getting a fair bit of flkc during aggressive driving: http://www.datazap.me/u/akyp/20140904
It happens mostly when lifting off before a corner, or modulating the throttle for the corner exit. No flkc at all when going wot on a straight road or normal urban driving. Did some reading and seems this is not severe enough to bother, it is probably too hot for the ECU to be 100% happy anyway.
My LTFT is also a bit over the place compared to a log I made in April. Could also be the weather but I notice v2.0 has a new MAF scaling. I may just have a crack at scaling the MAF myself when it's not so hot out there.
akyp is offline   Reply With Quote
Old 09-06-2014, 10:27 PM   #44
steve99
Drives: FT86
to me it looks like you on the throttle and load increasing when you get the knock
It looks like it was hot as the oil temp is running to almost 250F , you have not logged IAT but I suspect it may be 90+F
You might want to try making the IAT vs ignition retard tables a bit more aggressive if your already on the 98RON MAP I did. The knock its not that bad but its pretty consistent.
This is what I am using I did not put the temp compensation changes in the maps I posted
akyp (09-07-2014)
Old 09-08-2014, 02:51 PM   #45
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
Looks like the proposed map released date also coincided with a new firmware release (v1.29) and a new OF Manager software version (v1.10.4) that should be available for download later tonight. So to keep to many updates from happening all at once, I'm going to be pushing back the release date of the v2.06 maps until tomorrow
This also means that ll new OFT orders that came in over the weekend should ship tomorrow with the v2.06 maps preloaded in them.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
benlaz88 (09-09-2014), fstlane (09-08-2014), NorCal_Guy (09-08-2014), zc06_kisstherain (09-08-2014)
Old 09-08-2014, 03:57 PM   #46
benlaz88
Drives: 2013 Asphalt FRS
Originally Posted by Shiv@Openflash View Post
Hi guys,
Cheers,
shiv
@Shiv@Openflash Awesome, can't wait when its receive!!
benlaz88 is offline   Reply With Quote
Old 09-08-2014, 04:21 PM   #47
cookiesowns
Drives: WRB BRZ Series.Blue
Probably just my unit then.
On another note, I've been able to log IAM and FLKC with my 700G ROM for some time, still no FBKC though.
Same issues here, but on D00C :/ Unable to log IAM, FLKC, and FBKC.
cookiesowns is offline   Reply With Quote
Old 09-08-2014, 04:37 PM   #48
Shiv@Openflash
Drives: 2013 FRS
Has your OFT updated to the new firmware (v1.29)? If not, connect it to OF Manager and let it update. Then connect OFT to ECU and go to Configure channels and then press the right arrow. This step is important as it updates the new changes to the datalogging protocol. Then see if you can log those channels successfully. I know we have made changes to enable logging for FLKC and IAM. If those work as they should, we can enable FBKC next.
Old 09-08-2014, 10:03 PM   #49
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Hi guys,
On Monday we plan to release the first non-beta version of our v2.0x maps. With this release we will add support for all the other Cal IDs that are currently not support with our v2.0x beta maps. We will also disable the U0155 code (as we have always done before in our non-beta map releases). This code/CEL is triggered the OFT is disconnected from the OBD2 plug in the middle of communication (datalogging, data displays, etc,.) It's harmless but annoying nonetheless.
In additional to releasing the new maps in non-beta format, we will be preloading all OFTs with v2.0 maps prior to shipping. So now there will be no need to manually upload the v2.0 maps using your laptop. For those who already have OFTs, we will also be releasing the database file (.dev) that will auto generate all compatible v2.0 maps for you. But by now you've probably already loaded the v2.0 maps you needed anyway
If there is any other suggestions you have with regards to beta->non beta changes, let me know and I can look into implementing them.
Cheers,
Shiv
PS. The sales team is also running a sale: http://www.ft86club.com/forums/showp...0&postcount=21
Where do we go to disable U0155 if we are running an modified v2.0 beta? I cannot seem to find it in the Rom Raider Defs. It's not under 'Diagnostics Trouble Codes' folder.
Old 09-08-2014, 10:35 PM   #50
solidONE
solidONE's Avatar
Also, would disabling this U0155 code prevent the car from going into limp mode if the connection between OFT and the ECU at the OBD port goes bad for whatever reason (usually because of my right knee hitting the cable, I think)
I've had my car go into limp mode may times while in a middle of logging and triggering a CEL, so I've been afraid of logging with the OFT on track. Typically it's between the U0115 code and some other code I cannot remember off the top of my head.
The Following User Says Thank You to solidONE For This Useful Post:
lucid215 (09-08-2014)
Old 09-08-2014, 11:23 PM   #51
lucid215
Mine has been doing the same thing but when I hit a decent bump
lucid215 is offline   Reply With Quote
Old 09-08-2014, 11:40 PM   #52
JB86'd
JB86'd's Avatar
Drives: JAWS
The other day I lost and gained connection a few times in quick succession, and my car threw a U0xxx code, and my tachometer was stuck around 6000 rpms, with the car off, started the car and it stayed there..so I turned the car off and cleared the code with my Scangauge, since the OFT said no codes. I then disconnected my battery and reset my ECU and all went back to normal. Just about shat myself though. Found out my OBD2 port was bad, got a 30cm extension cable and all is good.
Anyways, to disable this from happening again I'd need to modify the map in romraider and reflash?
JB86'd is offline   Reply With Quote
Old 09-09-2014, 12:02 AM   #53
solidONE
solidONE's Avatar
Yup had that happen many times as well. CEL on and OFT detects no code.
Old 09-09-2014, 12:18 AM   #54
JB86'd
JB86'd's Avatar
Drives: JAWS
It only detects engine related codes so that doesn't surprise me. Just don't want this to happen again.
Old 09-09-2014, 12:36 AM   #55
steve99
Drives: FT86
disable code U0155 in romraider and reflash its comms fail to instrument panel , can cause limp home mode as well
lucid215 (09-09-2014)
Old 09-09-2014, 01:13 AM   #56
solidONE
solidONE's Avatar
Where is U0155 located in the defs? I could not locate it under 'diagnostic trouble codes' folder.
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
