Old 08-24-2014, 02:15 PM   #57
radroach
Drives: car
Infinite door detent positions. The doors need to hold open better when you're parking on an incline, and also make getting in and out easier with. Would make a nice option.
I wish the trunk opening width was just a little bit wider, like a centimeter. Would make getting a bike in the back a little easier.
Valet mode. Something to prevent illegal joyrides.
Old 08-24-2014, 05:06 PM   #58
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I have three main complaints with my BRZ:
1. Crappy stereo/interface. Subaru should either install a better head unit, or at least give us the WRX steering wheel with built-in audio controls to make control of the head unit easier.
2. Lack of torque and the 4k torque dip. Would have loved to see a 2.5L engine in the car, with 20-25 lb-ft more torque (and no dip).
3. Fragile paint & body. I've had more damage from hitting cones while autocrossing the BRZ two years than with all of the other cars I've autocrossed combined in the last 15 years.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-24-2014, 09:25 PM   #59
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by HeadBanger View Post
People who want more cup holders and shit like that bought the wrong car.
And yet you want...
The seat to remember it's position when you pull the fabric puller thing.
Alcantara inserts on the wheel would be cool.
The frameless mirror would be nice.
White face gauges. I love white face gauges.
While having a more stripped out version sounds nice in theory, nobody actually wants that except people who aren't going to DD.
xxBrun0xx is offline   Reply With Quote
Old 08-24-2014, 11:17 PM   #60
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Originally Posted by xxBrun0xx View Post
And yet you want...
I DD my car. I even DD'd a semi-stripped RB20 swapped S13 - though winter too.
I don't feel like the things I mentioned take anything away from the car. There's already Alcantara in the car. Wouldn't make a big difference to have 2/4 quadrants of the wheel wrapped.
My 2000 Sunfire would go back to it's original place after pulling the seat forward. It's 2014, that isn't rocket science.
It also just occurred to me that the car needs a better GPS system. When you're starting out the car never knows which direction you're facing and I always seem to head the wrong way. Nor does it allow you to simply search cities or towns, or places like arenas.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
The Following User Says Thank You to HeadBanger For This Useful Post:
xxBrun0xx (08-25-2014)
Old 09-05-2014, 05:15 AM   #61
Mondongonica
Drives: 2014 Subaru BRZ Limited WR Blue
I wish I had steering wheel controls for the head unit. If I could rewire the Crouse control stick to control the head unit it would be perfect. Wider stock wheels too
Mondongonica is offline   Reply With Quote
Old 09-06-2014, 06:38 PM   #62
Turbowned
Turbowned's Avatar
-Better standard infotainment system, like the ones in the 2015 Legacy and Outback
-More power (duh)
-better-looking standard wheels
-less dead cat space (fender-to-wheel gap)
-OEM taillights that don't hark back to the Toyota Altezza
-GT86 OEM armrest included as standard
(and as @Miniata mentioned) - better factory paint - this stuff is worse than nail polish!
Oh well, I've done all that myself with my 2013... would be nice if you poor bastards buying the 2015+ cars didn't have to spend as much money as I've spent to get your cars where mine is, though! Coulda bought a 2-3yr-old M3 for what I have into this silly little Scoob
Old 09-06-2014, 08:31 PM   #63
quality_sound
Drives: '15 BRZ Series.Blue
You have almost $60k in your BRZ?
quality_sound is offline   Reply With Quote
Old 09-07-2014, 03:10 PM   #64
Yoniyama
Drives: BRZ 2018
Everyone's idea of a perfect Toybaru is different, and even contradictory in many aspects of the car. For example, some want more and some want less sound insulation.
Toyota set out to produce an incredible sports car, for the price of a Camry, and made it easy for every owner to customise to his perfection. I would score Toyota at 85 out of 100 points in this remarkable endeavour.
I would focus on making the Toybaru hit closer to its design goals, so more drivers can enjoy their dream sports car. Particularly, there are attributes that are not easily changed once the car leaves the assembly line that Toyota/Subaru should rectify/remedy.
My list includes:
1 A bigger fuel tank, at least 14.5 US gallons (up from the current 13.2 gal);
2 Much Less rattling and other mechanical noise that should not be there;
3 Fix the grinding of the manual gear box; and
4 Increase the wheel travel by about 15mm.
Most of the other common performance related issues can be readily ameliorated:
a Noise - sound insulation material can be added or reduced.
b More speed - light weight components (carbon drive shaft, pulleys, wheels, and flywheel) are readily available to make the drivetrain spin faster.
c Sound system and GPS - much better after-market units are there.
d Seats - many after-market to choose from (but usually quite expensive).
e Headlights - brighter light bulbs are available.
f Harsh Ride - lighter wheels, 2-piece brake rotors, and the aforementioned increase in wheel travel, will improve the ride characteristics.
Yoniyama is offline   Reply With Quote
Old 09-08-2014, 02:03 AM   #65
demonpoofball
demonpoofball's Avatar
Drives: 05 wrx, 07 tsx, 15 brz series.blue
HATE the Nav… I don't like it in any car though, it's obnoxious. I'm quite sure that within the next couple years, if I find a method that will fit the space right (which shouldn't be hard), I'll be getting a regular stereo w/out that obnoxious screen…
Oh. And those horrid headrests… but those, too, are in all vaguely new cars because apparently they didn't feel people could actually sit in their seats properly to avoid whiplash and thus decided to bend it forwards so you can't even sit up straight…
So, I guess nothing specific to the BRZ. Though better paint would admittedly be nice as we've already got our first little divot in our bumper…
Can't believe people want more sound deadening. It's so quiet. Perhaps that's as I'm used to our '05 WRX, with a catback…
demonpoofball is offline   Reply With Quote
Old 09-08-2014, 11:42 AM   #66
Darnold
Darnold's Avatar
Drives: 04' 400whp S2000, 01' DD S2000
Better tires.
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car)
Darnold is offline   Reply With Quote
Old 09-08-2014, 05:34 PM   #67
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I could prattle on about 5-6 relatively minor annoyances, but I'll just say this:
Add more power and all is forgiven. If the BRZ had 240-250hp from the factory I couldn't care less about all the minor things.
Old 09-09-2014, 07:16 PM   #68
2013GTRNate
2013GTRNate's Avatar
AWD option.
2013 Nissan GT-R Premium
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
The Following User Says Thank You to 2013GTRNate For This Useful Post:
w.k.s. (10-30-2014)
Old 09-09-2014, 07:45 PM   #69
Chee-Hu
Chee-Hu's Avatar
No cricket and an additional 50hp would be appreciated.
Chee-Hu is offline   Reply With Quote
Old 09-09-2014, 08:14 PM   #70
Ubersuber
Drives: BRZ Pearl White
Originally Posted by 2013GTRNate View Post
AWD option.
Not feasible because the engine is too low.
Ubersuber is offline   Reply With Quote
