#2045 |
Drives: 2013 BRZ Premium Dark Gray Metallic
What's your average temp. running around town? Mine gets all the way to 234 @ about 70-60 mph and 220 to 228 in City.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#2046 |
Drives: 2022 BRZ Limited
a little update, I've installed the new belt (it's fairly easy if know someone who can help holding the bracket and the supercharger)..
It held up just fine at the last event...too bad I could only drive for couple sessions since it started raining really bad @KraftWerks @moto-mike [ame="http://youtu.be/hIgpo7q_6GI?"]http://youtu.be/hIgpo7q_6GI?[/ame]
#2047 | |
Drives: 2013 WRB BRZ
Second place is just the first place loser.
Dale Earnhardt |
#2048 |
Lacking brains
Drives: frz
It was pretty easy to do alone also, what i did was loosen all the mounting points enough to get some play on the plate, then pull the bolts back from one area (lower left iirc) and slip the belt through. Then retighten.
#2049 |
@KraftWerks Oil cooler sandwich plate and oil filter mounted.
#2050 | |
Drives: Kraftwerks BRZ
Let us know if you need anything further! |
#2051 |
Drives: whiteout FR-S
Does any one know the highest numbers that have been put up on the c38 kit on pump and e85?
#2052 |
Probably mine, but I had stock everything and was the first tune all other Delicious tuned c38s are based on. I'd say to expect 385whp on a dynojet with e85 on an otherwise stock motor normally, you won't care about pump after being on that, lol.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2053 |
Maybe someone pegged more after me with some other mods on top of the kit and a revised tune.
#2054 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Got my kit today.. Finally.. C38 black, smaller pulley, church is tunning next Thursday here in Vegas. We lose a couple lbs of pressure due to elevation so right now unsure what the actual PSI will be. 900cc deatschwerks injectors walbro 255 pump. 91 map and E85 map. Running MXP UEL headers over pipe, and catless front pipe, greddy EVO3 cat back. I'll post up numbers next Thursday, I'm installing the kit on Sunday, Monday the injectors will be in.. After installing these in other guys cars, selling them to others it finally my turn to get one..
#2055 |
900 is huge! Small pulley, injectors, corn and revved out a little longer plus all the exhaust mods... Maybe optimistic, but maybe you could see 430 wheel, that would be crazy
#2056 |
We'll KW said I have to drop the revs to 7300.... But... Well we will see.. Shawn expects 380-400 up here.. I really wanted 8k on the rev limit, but won't happen on the C38.. The injectors will flow 1050 at 51 psi fuel pressure I think, and I've been told they see around 50 so it should be more then 900cc.. I didn't want to run that big, but I guess it's better to run slightly bigger then to small,..
#2057 | |
#2058 |
Shawn church??? I hope so lol, I really wanted to go through with bill at delicious, but we refuses to answer emails, text or calls, and we can't use him for the business any more.. The tune he did for the other car is really bad, he won't fix it, so we had to look else where.. Moto east was my next choice, but seeing as church comes here every other Thursday I decided to go that route.. So we will see how it goes
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
