Old 09-05-2014, 06:46 AM   #29
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
This might be a stupid question, but for those of us running a 2.x beta rom, any reason to update?
xxBrun0xx is offline   Reply With Quote
Old 09-05-2014, 07:44 AM   #30
steve99
Drives: FT86
Originally Posted by akyp View Post
Yeah just noticed FBKC worked: http://www.datazap.me/u/akyp/stg-1-v...zoom=3913-4081
Didn't notice it the first time I read the log, since it only dropped once.
I will try messing with the channels and see if they are memorised.
Edit: Come to think of it I haven't updated the template file for a while, so I'll do that first.
Shiv,s 2x tunes are much better knock wise and i pulled a bit of timing in problem areas for 98 ron fuels so the amount of fbkc or flkc will b verry little hopefully
Old 09-05-2014, 12:56 PM   #31
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
During the beta I keep getting code p2096, due to my after market header. Is that code now disabled? Tired of always plugging in my OFT and clearing it.
Juanito08 is offline   Reply With Quote
Old 09-05-2014, 01:28 PM   #32
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
Make sure you delete all the existing tune files in OFT ( except your original tune) before you load .dev file you cannot mix tune types
Wait, is this true? I deleted one of the 1.x 93 tunes and replaced it with a 2.x 91 tune (and renamed it so it'd be obvious). But everything else was 1.x. If it didn't flash a 2.x, then what the heck am I currently running?
nocturne1 is offline   Reply With Quote
Old 09-05-2014, 01:38 PM   #33
steve99
Drives: FT86
The code that is disabled for catless headers is P0420 Cat efficiency.
The code your getting is P2096 post catalyst fuel trim system too lean .
You may have exhaust leak did you use new gaskets when headers installed.
Are you running stock intake as you may get this code if fuel trims are high due maf scaling off. could also be leak in intake after maf sensor or maf sensor gasket.
Old 09-05-2014, 01:43 PM   #34
steve99
Drives: FT86
I think you got the wrong end of the stick mate ,as we say over here.
I'm talking about .bin format (editable full format tunes) tunes and .dev database format non-editable tunes.
Not tune revisions like 1.5x or 2xx ect you can mix those no problem. but oft will only hold either all .dev format or all full format .bin tunes at any one time.
nocturne1 (09-05-2014)
Old 09-05-2014, 02:03 PM   #35
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Yea I installed new gaskets when I installed the header.I have 0 leaks, Funny thing is the previous tune didn't give me the code. I'm running the TRD intake. Going to take some logs maybe you can let me know what's happening.
Old 09-05-2014, 06:14 PM   #36
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
@Shiv@Openflash,
do we need to re-upload non-beta map if we already have beta?
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
355rockit (09-05-2014)
Old 09-05-2014, 10:28 PM   #37
steve99
Drives: FT86
Originally Posted by zc06_kisstherain View Post
@Shiv@Openflash,
Read first post appears only change is to disable CEL code U0155 can buss comms to dash panel error code no tunning changes aparantly. If you can put up with clearing that cel if you plug/unplug oft while car running then all good
The Following 3 Users Say Thank You to steve99 For This Useful Post:
1Cor10:23 (09-06-2014), J_kennington (10-07-2014), zc06_kisstherain (09-06-2014)
Old 09-06-2014, 05:57 AM   #38
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
hey steve when you get a chance can you let me know if you see anything in my log that might point out the reson im getting that code. thanks!
http://www.datazap.me/u/juanito08/206log?log=0&data=1
Old 09-06-2014, 07:14 AM   #39
steve99
Drives: FT86
That log looks fine your LTFT is only around 3% max so thats good
Your AFR look fine and appears to be folowing the Open loop fuel tables well
P2096 is a lean condition and that log is not showing it but it could be an intermittent exhaust or, intake leak near maf sensor or downstream of maf sensor . check that as well as exhaust flanges near O2 sensors
The AFR is based of the readings of the front 02 sensor, but its likely the rear O2 sensor that causes code p0420 and p2096 or the difference in readings of the front and rear 02 sensors.
As you have an OFT you can monitor the rear O2 sensor as well by selecting WIDEBAND AFR log parameter the scaling might be a bit off as your supposed to install an aftermarket sensor., but for the purpose of checking the rear 02 sensor it should work.
I just tried it on my car and the front and rear reading move in sync once the sensors are warmed up
do another log and log
Wideband Afr
afr
afr commanded
ltft
maf v
rpm engine speed
throttle
fuel pressure
the afr , wideband afr and commanded afr should all follow each other. The second 02 sensor appears to take a couple of minutes to heat up and produce a reliable signal.
If you definitly dont have any intake or exhaust leaks its possible the rear o2 sensor may be damaged or not working properly or cross threaded loose cable not plugged in correctly ect.
is the p2096 code permanent can it be cleared ?
Old 09-06-2014, 07:19 AM   #40
akahenry
akahenry's Avatar
Drives: '18 STi
So we're going to be getting v2.06 maps on Monday- sweet! I just have one minor and probably redundant question but, will there be much of a difference from the v2.03 and the v2.06? Please excuse my ignorance, as I haven't caught up to recent updates since the release of the v2.03 maps. Even with that said, I'll probably still load my car up with the v2.06 map and boot out the v2.03 map that I'm currently running, just to be safe and updated.
akahenry is offline   Reply With Quote
Old 09-06-2014, 04:12 PM   #41
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
So to be sure this flash works on the Euro cars right?
GT86meMR2 is offline   Reply With Quote
Old 09-06-2014, 05:18 PM   #42
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes if course. All gt86 worldwide are currently supported by OFT.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
GT86meMR2 (09-06-2014)
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
