Old 09-04-2014, 02:04 PM   #365
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Entroper View Post
But only a smidge faster than 2750 lbs and 200 hp. I'm betting ND will come closer to 2300 lbs and 170 hp, maybe 175. Still, we're just talking tenths here. The #1 complaint will be the same for the ND as it has for every previous Miata, and the 86 twins.
That is not a smidge faster. It is much faster. You just described a 2ZZ swapped MR2 Spyder, which is as fast as a base 981 Boxster, which I guarantee is a lot faster than an FRS.
The Miata will come with 150hp at best, IMO. They wouldn't give it the 2L engine.
Old 09-04-2014, 02:28 PM   #366
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Because it's inevitable
Old 09-04-2014, 02:28 PM   #367
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
I'm confused how you can think 180hp in 2200lb (12.2lb/hp) is as fast as 265hp in 2900lb (11lb/hp). That's as big of a difference as there is between an FRS (13.5lb/hp) and a 180hp 2200lb car (which, as I just mentioned, is 12.2lb/hp). The higher horsepower car will get a bigger advantage at high speeds too.
As for this Miata? I like the new design. I'll be very curious to see (and test drive) one in person...
chrisl is offline   Reply With Quote
Old 09-04-2014, 02:31 PM   #368
serialk11r
Originally Posted by chrisl View Post
I'm confused how you can think 180hp in 2200lb (12.2lb/hp) is as fast as 265hp in 2900lb (11lb/hp). The higher horsepower car will get a bigger advantage at high speeds too.
I was fudging it a little, I was taking the 2ZZ to have 190hp and the Boxster to weigh more like 2980 (I always got the impression that Porsche's curb weights were quoted a bit low compared to Toyota at least based on what people weigh their cars to be, near base speced Porsche Boxsters seem to clock in at 3000lbs according to owners on Rennlist).
What can't be fudged though is the 0-60 time (I think traction isn't that big of an issue for any of these cars, I know the 981 can't spin its tires at a stop unless you do a huge clutch dump on an MT), the 981 does 0-60 in a bit under 5.5 sec, whereas the FRS will take 7 sec (and I think back when they first reviewed it they were getting 7.0s with big clutch dumps). 2ZZ Spyders can match the 0-60 of a 981. Even taking out a hypothetical traction advantage and then some, 6s vs 7s is a pretty solid difference.
Old 09-04-2014, 02:34 PM   #369
xero404
So that video is my friends supercharged NA lol. Not sure why they used that for the engine noise.
xero404 is offline   Reply With Quote
Old 09-04-2014, 02:45 PM   #370
chrisl
To be fair, I'm using numbers from a close to base spec manual, since that's how I'd get the car. If you look at a well-equipped PDK, it's a lot closer to 3klb (or more).
Old 09-04-2014, 02:50 PM   #371
serialk11r
Yea I know, but I noticed MT owners also not getting under 3000 lbs. Pretty sure their curb weight is measured with something like a half tank of fuel instead of 75-80%, maybe minus a couple other things.
The power seats that most people opt for don't help, they are heavy as s***. I didn't notice a single person with a totally base car, but I remember thinking based on reading a thread that a realistic weight for a totally base Cayman MT with 18" wheels and 2 way seats is 2950-3000, not 2890. I recall some people had 3200+ lbs Caymans thanks to their 20" wheels, 18-way heated vented seats, PASM, PDK etc.
Old 09-04-2014, 03:56 PM   #372
Xti
Drives: Fast, Cool, New
Look like a Frankenstein, not impressive at all. In my personal opinion, anything with screws on it = ugly, not art
Xti is offline   Reply With Quote
The Following User Says Thank You to Xti For This Useful Post:
gramicci101 (09-04-2014)
Old 09-04-2014, 04:13 PM   #373
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
still missing the massive wing on the back
drewbot is offline   Reply With Quote
Old 09-04-2014, 04:23 PM   #374
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by n2oinferno View Post
Oh and remember this is the engine shot from a test mule.
Looks like what's under my hood now...
If that indeed is the engine the turbo swaps will be mundo easy! It reminds of GM's Kappa Platform's turbo placement...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-04-2014, 04:27 PM   #375
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Based on my ridealong in a 1.6L NA, <2,300 lbs and >150 horses will be a hoot, my money is on a retuned version of their current 2.0L (155 horses as stated above), with a sacrifice to fuel economy I'm guessing they can hop it up a bit push into high 160's and still match the Toyobaru's fuel economy.
Worth noting that 2.0L already has 150 ft-lbs of torque, if they don't lose that the Miata will certainly give the 86 a run for it's money when it comes to the butt dyno.
Would be a laugh if true, wonder why they would do that... Mazda trollin' hard with a 'reveal' that was not any better than a press release, Duran Duran and fake turbo mules and videos.
Old 09-04-2014, 05:04 PM   #376
I've never been a fan honestly, including the way it drives, but I know I'm of a minority opinion.
I will say I like the looks of this one better. It finally doesn't look like a rolling bathtub.
It will probably be a great car if its your thing. MomHawk would probably like it (not because she's female, but because she likes convertibles more than I do).
Last edited by Dadhawk; 09-06-2014 at 10:36 PM. Reason: corrected stupid misspellingz
Old 09-04-2014, 05:29 PM   #377
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I don't call this a reveal
adprokid is offline   Reply With Quote
Old 09-04-2014, 05:33 PM   #378
noobcake
noobcake's Avatar
Drives: EVO X
I liked the redesign, it was about time. The whole "if it ain't broke don't fix it" only applies half the time. Every time I would pass a miata I wouldn't look twice, but now it's on the map. This will definitely attract more buyers, and it seems to be the first car company to take a jab at the 86
Originally Posted by husker741 View Post
I will PayPal you $5 to quit making threads.
noobcake is offline   Reply With Quote
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission SteelReign Cars for Sale/Trade 5 06-22-2015 03:01 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 09:41 PM
FS: Supercharged 1992 Mazda Miata *$4000 OBO* BRZZZZZZZZZZ Canada Classifieds 5 08-18-2014 05:44 PM
The Mazda 2 trully the FWD Miata NA! Tbomb 25 Other Vehicles & General Automotive Discussions 24 01-14-2013 10:30 AM
