| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#43 | |
Drives: 2013 Subaru BRZ
#44 | |
Drives: Subaru
FR-S MT: 2,758 lbs Per Subaru's site BRZ Premium MT: 2,762 lbs BRZ Limited MT: 2,776 lbs Weight is most definitely not a factor unless you believe 4-18 lbs make a difference. Your normal body weight fluctuates by 2 lbs day to day. If you do believe that makes a difference and you on the big boned side, I suggest you go on a diet. |
#45 |
What's the difference in spring rates between the two? Has anyone gotten actual data on that?
Seems like a collosal waste of money for Toyota to test, develop, and manufacture a separate set of springs for the FR-S if all that effort ended up making a negligable difference in handling. But.. stranger things have happened.
#46 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
OMG This thread is ridiculous.
You could probably take two FRS (same specs) and run different times because of manufacturing tolerances in the engine, tires, dampers, etc... |
#47 |
Drives: SSM LT MT BRZ
my message was aimed at anyone who had issue, specifically at you yes, but not exclusively.
Jason's thoughts on why the times were different were even quoted in this post atleast once, show me some hard proof that the FRs is faster than the BRz by an amount that is even potentially worth talking about, same day same driver, then we can talk about it, short of that happening this whole conversation is about people that are probably over extended to buy this car anyway convincing themselves that they are buying the FRs because it is "faster" (albeit by .1 or .2 seconds to sixty in an unimpressive run to 60 anyway) rather than the reality of because it is cheaper. So again, if you are buying this car because it is fast, then you are making a bad choice to start, in order for these cars to be fast you are gonna need to knock a couple WHOLE seconds off the times not a couple tenths. My reaction time at the strip varies more than the recorded variances in the 0-60 tests, heck on an unfamiliar transmission my accumulated time out of gear in a 1/4 mile run may vary by more than the recorded variances in the 0-60 tests, The cars are different in so many little ways that to buy one over the other blindly because it gets to 60 (potentially) a little tiny itsy bitty bit faster is kinda missing the whole point of the car, because the prius is gonna pass both cars on the straight any way lol |
#48 | |
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#49 | |
These are quotes from these reviews, not from forum discussion. And in response to uspspro, I don't see how the thread is ridiculous...if anything, wouldn't it be these reviews that are making these claims about the FRS>BRZ? |
#50 |
Drives: Civic Si sedan
Most of those quote have nothing to do with the FRS being faster, which was your original question. Most are comments about the driving feel and handling characteristics.
Just buy the FRS and then you can be the bench racing champion. Last edited by WhiteGDB; 04-26-2012 at 10:28 PM. |
#51 | |
on me, I'm serious about this question.I'm buying the FR-S as sort of "congratulations, keep it up" present for myself because I recently lost 80 lbs (heading to 100lb). Assuming the above weight is sans driver, that means that the car + me now would weight 2.6% less than when I started, and when I'm completely done will weigh 3.3% less. Any way to calculate what a difference that might make in 0 - 60 or other such performance measurements? I want to make a placard for the car that reminds me every time I get in it, how much speed I've added to it by hitting my goal.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#52 | |
Drives: Subaru
There really isn't a way to calculate what difference it makes. In the grand scheme of things, the extra 20 lbs that you want to lose is not going to improve the car in any significant way. This is also taking into the other facts that you really can't recreate the same 0-60 launch over and over with consistency and keeping all other variables the same. Even at a drag strip, no one ever runs the same exact time every single time. However, I think you'll see significant improvement in your health, fitness, and overall confidence. :happy0180: |
#53 |
Drives: Honda S2000
Scion updated their site with official weight at 2,785 lbs?! I thought the FR-S was going to end up lighter than BRZ. Why is the FR-S heavier by 20 pounds?!
#54 | |
Drives: Some rust bucket
the curb weight will vary depending on how much liquid was in the car. the FRS should be lighter if everything was equal, but the difference will only be 10lbs or so. |
#55 |
Drives: Attitude
Official documentation says 2758. Website says 2785. It's a typo.
#56 | |
Registered you sir
Drives: 99 impreza coupe
| The Following User Says Thank You to chulooz For This Useful Post: | Dadhawk (04-27-2012) |
