Old 09-02-2014, 01:00 PM   #1
Border7
Border7's Avatar
Drives: 2014 Subaru BRZ
Best way to cool you garage
I have been looking around from various large fans to certain A/C units and cannot seem to settle on a solid idea of how to cool my garage so i can work on my beloved BRZ.
I live in south florida, It is very hot and humid here. Current temp is 94 degrees with high humidity.
I am hoping someone has experience with this and has found the best possible solution.
I have a 1-2 car garage (1 door) with CBC construction all around. So solid concrete. And i also have a attic directly above the garage and throughout part of the house.
Thanks in advance guys! Hope to hear some great ideas!
EDIT: there are also no windows, have 2 little cinderblock sized gaps in one corner of the garage, i guess to prevent from carbon monoxide poisoning, they are quite small however.
Border7 is offline   Reply With Quote
Old 09-02-2014, 01:14 PM   #2
sklimo
Misting fans are what we use here at work
Kinda like these
Old 09-02-2014, 01:17 PM   #3
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
[ame="https://www.youtube.com/watch?v=HxSLbpAwibg"]Homemade Air Conditioner DIY - The "5 Gallon Bucket" Air Cooler! DIY- can be solar powered! - YouTube[/ame]
Have a smaller 1-ish gallon version in my room and it works pretty well.
Manic is offline   Reply With Quote
The Following 2 Users Say Thank You to Manic For This Useful Post:
rice_classic (09-02-2014), Trashed675 (09-02-2014)
Old 09-02-2014, 01:24 PM   #4
BadBRZ
Drives: Subaru
Take 3 midol, 2 shots of fireball whiskey and punch yourself in the nuts. That prescription if taken before you begin work should make you just man enough to work on the car. If the midol wears off just diuble up on the whiskey or nut punches
BadBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to BadBRZ For This Useful Post:
ftc~brz (09-02-2014), serial gixxer (09-02-2014)
Old 09-02-2014, 01:24 PM   #5
Border7
Border7's Avatar
Don't think i would get an entire misting fan setup :P don't have that much room. And i saw that 5 gallon bucket thing, would it really affect an entire garage? Or would it more be just to cool me off?
Old 09-02-2014, 01:25 PM   #6
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Have you got a budget for this?
I'm thinking the only way to have a consistently cool garage would be to insulate the place and get either a portable A/C or one of those split A/C units (depending on square footage). Everything else would just be temporary and won't do much to cut the humidity.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 09-02-2014, 01:26 PM   #7
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
ductless AC units would be the best bet.
http://www.mitsubishicomfort.com/en/...oduct-showcase
bee-jay is offline   Reply With Quote
Old 09-02-2014, 01:47 PM   #8
Border7
Border7's Avatar
Not a huge budget, was only looking like 100-300$. So basically i should just get a big ass fan ?
Old 09-02-2014, 01:48 PM   #9
Used to live in SFL, and did a good bit of woodworking and auto stuff in my two car garage, that was just as you described. Here is what worked for me (it won't get it "cool" but might make it more tolerable).
You need airflow. My attic stairs opened into the garage so I would open it, and put a large window fan laying down in the attic over the hole that sucked into the attic. Then I had a decent sized oscillating fan that I had to keep the air stirring. Had I had the money I would have installed a "whole house" type fan to push air into the attic.
I found as long as the air was moving, I could work in there on the worst days, even though it would be hot.
Then again, in my younger days I was a roofer (Dad owned a roofing company) so I have a higher tolerance for heat than most.
Old 09-02-2014, 02:24 PM   #10
Manic
Is not fast.
Manic's Avatar
Cousin of mine uses one for his living room which is roughly the size of a two car garage. Works really well, but then again, it probably has better insulation than your garage.
Like others have said, insulating your walls combine with some sort of cooling equipment will be your best bet at getting real results.
Old 09-02-2014, 03:13 PM   #11
noobcake
noobcake's Avatar
Drives: EVO X
In my garage I have a AC vent, basically when the ac is on in my house, cold air still comes out from the vent in the garage. A little bit, but if you put a fan under it then cool air will circulate around your garage as well.
Originally Posted by husker741 View Post
I will PayPal you $5 to quit making threads.
noobcake is offline   Reply With Quote
Old 09-02-2014, 03:22 PM   #12
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Big-
ass
fan.
Jyn is offline   Reply With Quote
Old 09-02-2014, 04:09 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This.
BadBRZ (09-02-2014)
Get it out my garage PolishFrs13 Engine, Exhaust, Bolt-Ons 6 01-02-2015 08:40 PM
is this cool or nah ? okkoem Scion FR-S / Toyota 86 GT86 General Forum 34 08-13-2014 03:39 PM
cool!! coyot Off-Topic Lounge [WARNING: NO POLITICS] 1 12-29-2012 11:28 AM
Cool FRS ad russv Scion FR-S / Toyota 86 GT86 General Forum 1 08-21-2012 10:31 AM
A Cool Article / FR-S Body Kit / Infinite-Garage.com KronosPerformance Cosmetic Modification (Interior/Exterior/Lighting) 3 07-12-2012 07:57 AM
