#169 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
Annnd again an update on my P0351, tracked it yesterday and guess what...
Not DTC AT ALL ! So look like swapped the coil and heat protected them "solved" my problem. It's great to make a track session without this damn light on.
#170 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
New one! P0353, days before Nationals!
I had a friend in parts pull strings to get one in house, getting it changed Saturday morning. Crap. Same behavior as previous, got it during ~80% throttle, 2-3 shift around 5500rpm
#171 | |
Drives: 2013 FRS / 2013 427 Vert
I still haven't addressed this yet as I have no track time in the short term and there are no issues with street driving
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#172 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#173 |
Dodging cones
My number 3 was replaced and the car made a noticeable improvement.
Just in time to load it up and haul to Lincoln, where I am now
#174 |
Drives: BRZ, STI, 535, Tiffin Allegro
The saga continues....
3/13 - I replaced all of my coils with Okadas after my cylinder one factory coil failed with P0351 code. 2/14 I replace my cylinder one Okada coil after getting the P0351 code again. This weekend, after running on a hot track, the P0315 code popped up again. 9/14 I replaced my cylinder one Okada coil again. I'm averaging 7 months per coil now on cylinder one. |
#175 |
Drives: Storm Black Manual 86GTS
Put a call in with my local stealership to see if I can get one of each and compare. Will update if I have any luck.
#176 | |
Drives: WRB BRZ Sport Tech
#177 |
Drives: bmw
has the gold tape helped?
| The Following User Says Thank You to sickmint79 For This Useful Post: | acro (02-16-2015) |
#178 |
Data point
Coil pack #1 lasted for 2.5 track events. Coil pack #2 lasted 1.5 track events. |
#179 | |
I haven't tried swapping coils across cylinders yet but have kept all of the "bad" ones. |
#180 |
Drives: 08 scion xb
Had P0353 last week and P0351 today... Looks like I will be replacing coils.
40k miles, OFT e85 tune, intake, catless front pipe, exhaust, pulleys
#181 |
Drives: 2013 Subaru BRZ
DTC - PO351
I am also experiencing P0351 CEL.
N/A, EcuTek Tune, catless header & midpipe Tracked the car in June @ Sebring for the 1st time. On the 4th of 5 sessions the code came up. Cleared it with Ecutek @ the track and ran the 5th session without recreating the code. Tracked the car again 10/11, after the warm up session it came up once again. I went ahead and cleared it and it came up every session throughout the day. The car appeared to be running fine, AFR was in range... Car has 40k miles & only 2 track events... From what I'm reading, I think I'm going to try new plugs & a new OE coil... Probably take a spare with me to the track... I like the idea of the Aluminum ECU bracket, will probably try that out as well... I will post my results... Seeing how the exhaust is only a few inches below these 1 & 3 coils, I'm going to try a pipe shield, found this: http://www.designengineering.com/cat...um-pipe-shield I am however concerned about the injector issues, but I haven't encountered any fuel or injector DTC's... Thanks Last edited by BRZ-One; 10-14-2014 at 06:05 PM. Reason: adding info.. |
#182 | ||
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
http://www.ft86club.com/forums/showp...0&postcount=78
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 06:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 06:29 PM |
