Old 08-28-2014, 04:35 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Ran it down to around 12 gallons/13.2 (45L to fill up), the needle was past the 'E' mark so I could have run another 20-30 miles if necessary. I've got no qualms running down to the line when looking for a fill, ideally I'll have a station within sight before the needle drops below E.
Oh hay, just checked my Fuelly and I've got 3 tanks >12 gallons (45L), almost exactly what the OP describes.
http://www.fuelly.com/car/scion/fr-s...tcaster/177974
Also agreed that the fuel pump thing is nearly an old wives tale at this point, it's a good habit to fill regularly so you're not stranded but I think fear mongering an 'expensive fuel pump replacement and possibly more damage is imminent if you run past the fuel light!' is silly.
DAEMANO (09-04-2014)
Old 08-28-2014, 05:38 PM   #16
paulca
Drives: Toyota GT86 Coupe Red (UK)
I have had the fuel light come on at different points on the gauge. Once just under a quarter full, once just as it touched the red E line. I think it includes the avg mpg in it's workings. The time it came up at near 1/4 full I had 24mpg (UK) on the gauge, the time it came on just above the red line I had 42mpg on the gauge.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-28-2014, 05:52 PM   #17
Pbrown
Drives: 2013 Scion FRS Raven
Originally Posted by jvincent View Post
I think either @Slick or @Pbrown documented his adventure with the fuel gauge last year.
I don't remember how low he got, but it was a lot lower than I would have been comfortable with.
That was slick for sure. he was on fumes when he filled it up.
Pbrown is offline   Reply With Quote
Old 08-28-2014, 06:00 PM   #18
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
B-but... the sediments at the bottom of the tank! Don't be a baka neeee~!
Jyn is offline   Reply With Quote
Old 08-28-2014, 06:17 PM   #19
stonenewt
Drives: BMW 120d
A little precautionary tail. I starved my old 1 series engine of fuel. The car went into limp mode & felt seriously rough. Got BMW assistance out, car to nearest dealership etc. A day or two latter I get a call from the garage, I'd killed off 2 injectors. Because it ran out of fuel replaced at my cost, not cheap I can tell you!
Now when i see the 1/8 of a tank left I start looking for the cheap petrol stations and when see the empty light it's fill up at the first one find regardless of cost.
stonenewt is offline   Reply With Quote
The Following User Says Thank You to stonenewt For This Useful Post:
Demandred7 (08-28-2014)
Old 09-04-2014, 10:41 AM   #20
PNA
Drives: 2013 BRZ Sport-tech
Most I've put in was 49.95L. I was quite worried though.
PNA is offline   Reply With Quote
Old 09-04-2014, 11:32 AM   #21
WNDSRFR
Drives: FR-S,GTI
I take it as far as I dare toward empty every time I switch between E85 and gas. Whenever the empty light comes on you have about 2 gallons left. I've gone as far as 50 miles after the light comes on with gas and sweated like hell but didn't run out.
Old 09-04-2014, 11:36 AM   #22
Wrong forum dude! BMWs are NOT the same as the Twins.
sklimo (09-04-2014)
Old 09-04-2014, 12:41 PM   #23
Luis_GT
Fuel pump sucks gas from the bottom of the tank...
OP
When I bought my car, fuel needle barely budged from where it sits when car is off... still managed to drive to a fuel station... I've had the needle below E a few times.
Old 09-04-2014, 03:20 PM   #24
stonenewt
Drives: BMW 120d
Failure modes of running injectors dry are fairly universal.
The theory is stuff which clogs the fuel filter tends to float on the top of the fuel so it's only when you get to near empty that it gets sucked into the fuel delivery system.
GoTornado (09-04-2014)
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 09:33 PM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 09:19 PM
FYI: Mileage left after the re-fuel light shows up ... qqzj BRZ First-Gen (2012+) — General Topics 17 01-31-2014 07:13 PM
Odd Gremlin with Fuel Light ON sw20kosh Forced Induction 19 09-02-2013 10:34 PM
Premature low fuel light WolfpackS2k BRZ First-Gen (2012+) — General Topics 76 06-21-2013 10:45 AM
