go_a_way1
Old 08-20-2014, 03:29 PM   #827
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Originally Posted by Sellout View Post
Cooler for the rotrex oil...
Gotcha - just wanted to make sure
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 08-20-2014, 03:31 PM   #828
themajesticone
Drives: '13 UM86
Originally Posted by wheelhaus View Post
The oil cooler is for the Rotrex SC unit, it has a roller drive mechanism that pumps its own special oil through it's own oil cooler. You will need a second one for the car's transmission should you decide you need one.
Ok nice, just want to understand that part. I have nearly hit my "car savings" goal haha so I am compiling everything on a spreadsheet of what I will need
Old 08-20-2014, 04:58 PM   #829
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Can I have my name taken off this list please? Not sure how I got on there...
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 08-20-2014, 05:32 PM   #830
Raven604
Originally Posted by romin View Post
I used a Flir One and an iPhone 5s.
http://flir.com/flirone/
I have an e50. The one blows chunks!
Raven604 is offline   Reply With Quote
Old 08-20-2014, 05:32 PM   #831
CSG David
CSG David's Avatar
What's funny is that this list is actually a lot longer except people never talk about their car on this forum.
Old 08-20-2014, 07:07 PM   #832
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
We installed a Jackson Racking kit on our customers automatic FRS. Easy kit to install and very detailed instructions.
Modifications-
Jackson Racing Kit
Borla UEL Header
Cat Back Exhaust
(stock overpipe and mid pipe)
Custom tuned by Ben at Carolina Dyno
Carolina Dyno is offline   Reply With Quote
The Following 2 Users Say Thank You to Carolina Dyno For This Useful Post:
Avo1789 (08-20-2014), CSG Mike (08-20-2014)
Old 08-22-2014, 09:18 PM   #833
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Can anyone tell me if i would need a custom tune if i only had an Evo3 exhaust? Or will the factory tune work with just the catback?
K-NoMs is offline   Reply With Quote
Old 08-22-2014, 09:21 PM   #834
CSG David
CSG David's Avatar
CARB tune works with a catback exhaust. No need for a custom tune unless you modify from the factory catalytic converters.
The Following User Says Thank You to CSG David For This Useful Post:
K-NoMs (08-22-2014)
Old 08-27-2014, 04:08 PM   #835
Deadpool_25
Drives: BRZ Limited
A couple questions, but first a few excuses for not searching through the thread...
- I'm on my phone (pain in the rear)
- I'm in a quick lunch break
- I just had a beer (I'm not supposed to drink while on the clock [St Bernardus...yum])
- Gotta head back to work
So the questions:
- What should I expect final cost to be?
- If doing a DIY install on a basically stock BRZ, which Kit should I look at? With tune it without?
- After doing the kit I would likely upgrade exhaust at the least. What other upgrades would make sense over the long term?
- I think I'd like to end up with at least 300 whp. Will this get me there?
Thanks. Feel free to yell at me for not searching or w/e.
Deadpool_25 is offline   Reply With Quote
Old 08-27-2014, 06:42 PM   #836
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
See Below. Costs are ballpark and not exact.
So the questions:
- What should I expect final cost to be? Kit $5000 (with tune) plus installation ($1000+) Without tune $3900 plus cost of tuning ($700?)
- If doing a DIY install on a basically stock BRZ, which Kit should I look at? With tune it without? With tune unless removing a catalytic converter.
- After doing the kit I would likely upgrade exhaust at the least. What other upgrades would make sense over the long term? Retune if removing catalytic converter. Engine Oil Cooler. Tires - With SC, stock tires are easy to spin. Upgrade clutch if going to higher hp.
- I think I'd like to end up with at least 300 whp. Will this get me there? With conservative tune, I am in the the 295-300 range.
Casey10s is offline   Reply With Quote
The Following User Says Thank You to Casey10s For This Useful Post:
CSG Mike (08-28-2014)
Old 08-28-2014, 11:03 AM   #837
Deadpool_25
Drives: BRZ Limited
@Casey10s
Thank you very much. I guess quite a few folks are installing themselves. Sounds like it's pretty easy. I also have a fully equiped shop available (base auto hobby shop).
I don't plan on removing the cat initially. As for tires, I'm on Nitto Motivos right now. Not sure how those rate as far as stickiness...
What other mods have you done? Thanks for your help.
Old 08-28-2014, 11:06 AM   #838
DarkSunrise
DarkSunrise's Avatar
Quick question - does anyone know whether the standard Perrin oil cooler fits with the JRSC? If not, how hard is it to modify the Perrin unit so that it fits?
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 08-28-2014, 12:21 PM   #839
CSG Mike
CSG Mike's Avatar
Thanks!
You just need to make a bracket to mount the oil cooler on, but the Perrin unit won't provide enough cooling for the oil with the FMIC in the way...
DarkSunrise (08-28-2014)
Old 08-28-2014, 12:25 PM   #840
DarkSunrise
Damn, I was worried that would be the answer. Thanks Mike.
2022 BRZ Build
2013 FR-S Build
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
