#1933 |
Drives: seat ibiza
Isn't two crashbolts per side a little bit on the unsafe side of things?
#1934 | |
For the rear the Whiteline rear camber adjustment bushings will do the trick, but as mentioned they are a pain to install and adjust. They do the job well though (and you get a firmer bushing in a key place while you're at it). - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | karlsson (08-26-2014) |
#1936 | |
Drives: 2013 white FRS
#1937 | |
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
Since I'm from Germany, too and also know Karlsson from the German Forum it's very interesting to know. Until now I haven't bought any but I absolutely plan that. So as far as I know German Toyota/Subaru dealers list Camber Correction bolts - are those what you refer to as crash bolts? |
#1938 | |
Drives: FR-S Firestorm 6MT
The Eibach's work well with the stock dampers, although I can feel them lacking at the track with quick transitions. On the street, you will be fine and there is not a big noticeable change in comfort. Plus your car will handle better with less stiffness in the rear to limit the oversteer. With just LCA's you'll be able to gain camber on the rear, but with stock springs you will be limited to about - 0.75 up to -1.0 on the fronts (with crash bolts but without a drop), and this is the end where you actually need more camber. |
#1939 |
I posted this question up in the simulation thread since we were talking about roll centers and such, but I think it got ignored (probably because it's not related to simulation).
At what point of lowering is it suggested to get the Whiteline roll center correction kit? Or is it suggested anyway to be able to run softer springs and increase mechanical grip? (Assuming the roll center is raised and get's closer to the CG, in which case reducing elastic weight transfer.) |
#1940 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Camber bolts as most generaly refer to as eccentric and have a lobe that adjusts for camber. See this link: http://www.ft86speedfactory.com/spc-...front-776.html. You can buy a 16mm for the upper hole or a 14mm for the lower hole. Just do not use these is a slotted strut hole. |
| The Following User Says Thank You to finch1750 For This Useful Post: | Grim-Reaper (08-27-2014) |
#1941 | |
Drives: 2012 Toyota 86
#1942 | |
Drives: 13 Scion FR-S
#1943 |
That Guy
Drives: 2013 asphalt FRS MT
I just checked my white line bushings that I haven't installed yet. The adjuster does bottom out in the bushing; the hole doesn't go all the way through. Hopefully you'll be able to put enough torque on the longer bolt that the tension of turning either direction wont cause it to come lose.
| The Following User Says Thank You to Calum For This Useful Post: | jdubious (08-27-2014) |
#1944 | |
That Guy
#1945 | |
Tag me in a post with @CSG Mike if you need a response; I can't watch the whole forum
| The Following User Says Thank You to CSG Mike For This Useful Post: | jdubious (08-27-2014) |
#1946 | |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
