Old 08-26-2014, 06:33 PM   #197
Brinks
Brinks's Avatar
@RiskyTrousers Plus 1 for a sound Clip
Brinks is offline   Reply With Quote
Old 08-27-2014, 09:31 AM   #198
Account Attempt No. 4
Account Attempt No. 4's Avatar
Drives: 2013 WRB BRZ Limited
Got a reply from Nameless today, they confirmed that they will be replacing the old style can with the new ball type helmholtz when it gets back there for repairs
Originally Posted by Calum View Post
No it's not. - Yes it is. - It'll make 400 whp. - No, it'll only make 200 whp and break down all the time. - Oil temperatures!! - This will never happen. - But the other kit. - Turbo is better. - No, supercharger is better. - Rotrex sucks. - You suck. - Perrin said. - But Visconti said.
Account Attempt No. 4 is offline   Reply With Quote
Old 08-27-2014, 11:47 AM   #199
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
do you know why they want to replcae the new ball type helmholtz?? is it because the clearance issue?
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 08-27-2014, 01:52 PM   #200
Did you read the last couple posts?
Theyre not replacing the ball helmholtz, theyre replacing the can style. The ball is the new, better design that apparently gets rid of the VVT rasp
Old 08-27-2014, 02:15 PM   #201
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
thx for clarify
Old 08-27-2014, 07:06 PM   #202
emutcfut
Drives: 2013 Argento
Originally Posted by RiskyTrousers View Post
To better match the 3" header collector. The front pipe does taper down to 2.5" at the cat-back flange. As a bonus, this actually fit better than the 2.5" and has a deeper exhaust note.
Is this a custom order pipe? I cant seem to find this configuration on Nameless's site. The description for their 3" downpipe says it uses a donut to connect to a 3" midpipe.
emutcfut is offline   Reply With Quote
Old 08-29-2014, 04:59 PM   #203
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Yes, it was a custom order. The last couple of inches tapers down for 3" to a 2.5" flange which uses your standard 2 bolt gasket.
Heres a vid with my old setup which had the rasp. Its a little hard to hear from the outside, it was more noticeable in the cabin.
[ame]http://youtu.be/mX7fGB1iu58[/ame]
Heres the current setup with absolutely no rasp.
[ame]http://youtu.be/_mzHRTIGiX4[/ame]
RiskyTrousers is offline   Reply With Quote
Old 08-29-2014, 05:53 PM   #204
deliroast
Drives: 2014 SSM BRZ
What exactly did you ask them for? That sounds great! I'm so tired of the rasp. And that was a fast course! Good driving
M3 > BRZ
deliroast is offline   Reply With Quote
Old 08-29-2014, 06:18 PM   #205
RiskyTrousers
I asked them to put a 2.5" flange on their 3" over/front pipe with a taper of some sort. I also asked that they not put that little pipe extension for the stock donut gasket as that brings the ID down to 2.25". I am running a Perrin cat-back which has a flex joint that takes care of articulation so keep that in mind.
Old 09-03-2014, 08:00 AM   #206
deliroast
Thanks! I'll have to give them a call soon
M3 > BRZ
Old 09-04-2014, 02:53 PM   #207
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
when is the new version able to be order?
Old 09-04-2014, 04:15 PM   #208
johan
Drives: '14 981CS, '99 NB1
This sounds amazing. Haven't started modding the exhaust on my FR-S yet, but doing lots of research. Care to share the exact details on your exhaust setup?
johan is offline   Reply With Quote
Old 10-06-2014, 09:19 PM   #209
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I'll post vid's once I get the new pipe in. Most likely a month from now.
Did you get the new style pipe in? Did it fix the issue?
Mad_Mike is offline   Reply With Quote
Old 10-06-2014, 10:16 PM   #210
Brinks
Brinks's Avatar
Still Waiting...........
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
Vitamin R from Nameless Performance. Jason@Nameless BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-22-2012 11:27 AM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
