Old 07-13-2014, 03:57 PM   #141
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Car: '14 BRZ
Miles: 7,800
Use: DD, never tracked/autocrossed/abused
Suspension: RCE Yellows (20mm drop)
Power: ~240whp (theoretical/estimate, not dynoed)
Forced Induction: Vortech SC
Axle broke story: Eventually...
I've had ticking going on for a few weeks that's progressively gotten more frequent and I'm feeling I should replace it soon. Started even when I was on stock suspension but given that now I'm slightly lowered and have an SC the dealer's not going to warranty it, granted I should have had it checked out much sooner but I didn't realize it was the axles unless it was too late. Is the 20mm drop geometry likely to repeatedly destroy axles or did I just have a bad one from the factory? I've been considering diff risers but only if it's necessary.
zkv476 is offline   Reply With Quote
Old 08-14-2014, 11:50 AM   #142
irocz0r
Drives: '88 E30 325i, 2015 FR-S
What I'd really like to know is how many people have cars lowered more than 2.5"s and HAVEN'T broken an axle?
I don't plan on driving hard, I just want to like the way my car looks. But I don't want to break anything
irocz0r is offline   Reply With Quote
Old 08-21-2014, 03:55 PM   #143
gonzo
Drives: frs
For anyone who has confirmed it's the axle: does it sound like this?
[ame]http://youtu.be/OZoN6mWBgro[/ame]
gonzo is offline   Reply With Quote
Old 08-21-2014, 06:15 PM   #144
wheelhaus
wheelhaus's Avatar
Not exactly. That little click/ping could just be the wheel bearing nut needing a re-torque. It's possibly the CV, but I don't think it is.
A bad CV jont sounds like a more regular clicking that happens in time with wheel rotation. The more the joint is deflected, the more prominent the click will be. In a FWD car, the easy way to do this is to turn the wheel to full left/right lock and drive forward/reverse. RWD it's a little harder to deflect the axle, but it should have a more regular clicking.
The Following User Says Thank You to wheelhaus For This Useful Post:
gonzo (09-03-2014)
Old 08-21-2014, 07:03 PM   #145
mike the snake
Wouldn't the spacers make the angle slightly greater?
What is it that causes the CV's to fail? Is it the increased angle, or that when lowered the axles are pulled out of the CV's slightly?
Originally Posted by Roxy86 View Post
S2000's have a similar problem with lowered cars...
Someone should develop some alxe spacers - pushing the axles further in by the CV
Old 08-21-2014, 07:11 PM   #146
Dipstik-sportech
Dipstik-sportech's Avatar
Spacer can't be made for our cars because our cars don't use flange style axles.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Kwaziekeller (09-08-2014)
Old 09-02-2014, 08:56 PM   #147
Jac
Drives: Fiat Abarth
I've had this same ticking/clicking noise coming from my drivers side rear axle for the past 2 months and its been resolved after a tech greased my spindle.
First dealership had the car in for 2 days and came back asking for $600 to replace the axle, they blamed my lowering springs. After some back and forth I took the car to another dealership, after that tech read the notes from the last dealership they also concluded it needed a new axle. I succumbed and they ordered the part.
Fast forward to today, i brought the car back to have the axle replaced but one of the senior techs wasn't totally convinced it was an axle issue. After giving him a ride along he had an idea and 20mins later i took the car out for another spin and no more clicking/ticking/tapping noises.
He removed the hub/wheel/axle assembly, cleaned it, greased it, retorqued and boom. Issue resolved.
If you're also encountering this issue I'd recommend you try the above solution first before replacing your axle.
EDIT: Just to be clear, this is the noise i was hearing: http://www.ft86club.com/forums/showthread.php?t=43936
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
The Following 7 Users Say Thank You to Jac For This Useful Post:
Baldoak (10-10-2015), DAEMANO (09-08-2014), gonzo (09-03-2014), Hyper4mance2k (03-27-2015), strat61caster (09-02-2014), wheelhaus (09-03-2014), xZAMx (09-04-2014)
Old 09-04-2014, 03:18 AM   #148
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
I have the same sound. I'm bone stock. I have a appointment with the dealer tomorrow so we'll see what's up.
- The Ancient BRZ Sacrament
by Zaku
Old 09-05-2014, 01:21 PM   #149
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Yeah, axle spacers won't help.
The best methods to keep from busting the axles are:
Differential risers
Subframe risers
Upgraded axles
Keep in mind that diff risers, whil raising the diff by almost an inch, is going to dramatically increase the noise entering the cabin from the diff. Subframe risers will help, but not as much as the diff risers. However you won't get the dramatic increase in NVH either. Upgraded axles help but if they're still at an extreme angle, they won't last forever.
Seems like the best solution without sacrificing the daily driveability of the car is upgraded axles and subframe risers. That will raise the subframe by 10mm or so and give you stronger axles to work with.
Old 09-08-2014, 01:18 AM   #150
Dipstik-sportech
Add me to the list
498whp
I was attempting to run 10's
Lowered on h&r super sports
43,000kms
Turbod
Drag and drifting
Does anyone know the torque spec for the axle nut?
Old 09-08-2014, 01:37 AM   #151
cnk
Drives: '13 DGM BRZ Limited
Originally Posted by Dipstik-sportech View Post
Add me to the list
140.1 ft-lbs
The Following User Says Thank You to cnk For This Useful Post:
Dipstik-sportech (09-08-2014)
Old 09-08-2014, 01:44 AM   #152
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Also Add me to the list. Broke it the same weekend as Cale up there ^^^, only mine happened on the way home from the track, 1 mile from home.
Car: BRZ 13
MI: 9,300
Use: Autox, Road Course, Street. Never Dragged it.
Lowered: Yes - see photo below
Power: ~265 to the wheels
Forced Induction: Yes, Vortech S/C
Axle broke story: 2nd major 3 day track event since S/C, 5th overall. Everything went fine on the track, was driving home (~2hrs) and 1 mile from home I hit a sizeable bump in the road and snap, no more power to the wheels. Haven't taken it apart yet - but it's pretty clear:
[ame]http://youtu.be/yRhIxNFClNs[/ame]
The Car as it stands:
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
DAEMANO (01-02-2016)
Old 09-08-2014, 08:43 AM   #153
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Welll allmost a year later and I've still didn't broke an axle !
Because of this :
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 09-14-2014, 05:00 AM   #154
Cu0ngsayz
Drives: 2013 WRB BRZ
Without going under the car. How can you tell if the axle is broken? Is there a loud humming noise
Cu0ngsayz is offline   Reply With Quote
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
