#15 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Won't be much gains from an intake. The stock tube isn't very convoluted, and the airbox takes in air from the front of the car above the radiator, so it'll be clean, cool air while the car is moving.
I still think there are gains to be had by moving the first cat further down stream. And the second cat isn't worth keeping anyways since it isn't monitored. |
#16 |
Drives: '06 AM V8V Coupe
I think I'd keep the precat since startup is when your car is coughing out the largest quantity of carcinogenic aromatic compounds, and it happens right in your driveway where it will linger...that's just me. Maybe if you want to get fancy you could do a bypass valve.
#17 |
Drives: 2012 WRX Sedan
I'd say about 20hp MAX, especially with a tune. I'd like to see a rev limit raised to about 8k as well.
Not to mention a single exhaust plus a lighter header and simpler intake might save about 50+lbs. I can't wait to see what the actual gains will be.
#18 |
Site Moderator
Drives: ichi 86 Project
Not gonna happen with simple I/H/E. maybe cams & remap ECU. Mine only raise extra 250RPM in EJ25 (NA)
#19 |
Drives: Honda S2000
Unfortunately in California the only legal bolt-ons are a CARB legal intake (if available) and a catback below ~95 dB (forgot the exact amount). Headers, high flow cats, and testpipes are illegal, as well as non CARB legal intakes and loud exhausts
#20 | |
Sure, any higher and you might want to get better valve retainers, and cams, though they usually aren't worth the cost and rougher drivability for what you'd get. |
#21 | |
Site Moderator
#22 | |
But yeah mods wise, it's looking like the FA is more like the F20/22, in that it will be harder to get more HP out of them. But...we won't really know until we get our hands on them.
#23 |
The Mechanic
Drives: Civic Turbo,FR-S
they make about 172 whp stock so i/h/e may get you too 200 if lucky, but has anyone actually considered how are we suppose to tune this twin injector setup? its no walk in the park with direct injection... is cobb going to make a plug in for it?
cams and a intake manifold should do a lil justice.. hoping for 245whp n/a
#24 |
But the FA20 is less rev friendly than the EJ which has a very short stroke :O
I have this bad feeling increasing revs is going to be a bit of a problem. |
#25 |
Kuruma Otaku
But it's going to have vastly superior combustion at high revs. Lots of engines with 86mm strokes will rev to mid 8k without bottom end issues. Valvetrain seems to be the weak link/fuse for rpm.
Because titanium. |
#26 |
Guess we just need to wait for HomemadeWRX or someone who can get their hands on the engine to tell us the detailed specs...the short rods bother me quite a bit, the Honda motors are also 86x86 but they have much longer rods, and have those nifty dual cam profiles, whereas the FA20 will lose more and more bottom end as you push the power up (mild hybrid system?
).For outright power things aren't looking so good, but at least we have an updated efficient combustion chamber design. Last edited by serialk11r; 04-25-2012 at 02:44 AM. |
#27 | |
Kuruma Otaku
Because titanium. |
#28 |
Yea, but that supports my point because the TRD 3S-GE has basically no low end torque at all. By 4000rpm you're already down to 160Nm which is pathetic, and I bet that the FA20 at idle is better than that TRD engine at 2000rpm.
Not saying I'd care though The top end is like a freaking Ferrari 458 cut in half.
| What kind of gains without Turbo | Surge101 | Engine, Exhaust, Transmission | 18 | 01-25-2012 09:23 PM |
| Dealer Trade in ......what to expect ? | Sall | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-17-2012 01:34 PM |
| Estimated HP gains - bolt on mods and reflash? | ahausheer | Engine, Exhaust, Transmission | 207 | 01-14-2012 06:14 AM |
