Old 07-28-2014, 12:14 PM   #155
ja1217
Drives: 2004 Toyota RAV-4 5M
Please stay on topic in this thread, which is for ignition coil failure and the subsequent CEL codes related to it.
We don't want people reading this and thinking that P0351 or the like means their DI seals have failed. The two problems are NOT known to be directly related.
I assumed that they were related. Will do.
ja1217 is offline   Reply With Quote
Old 08-05-2014, 12:00 PM   #156
sickmint79
Drives: bmw
P0351
stock everything for the engine, tune, etc. bbk and suspension mods only. threw my last/fastest track session. 29k miles brz. probably the hardest my own limited skillz have pushed it on the track. 3rd car delivered at my dealer and it has never been taken back, so if there have been any service bulletin items i have not had the work done. it got up to 85 yesterday. 93 octane.
a drive home and to get food a couple times and the check engine light has gone away.
1. do i need to get my oem software updated by the dealer - http://www.ft86club.com/forums/showp...2&postcount=75 ?
2. is the advised fix ordering and replacing the OEM part 22433AA651 ?
3. should i have dealer fix it or is that a bad idea given mods and track stickers on the car ?
4. i see my oil at 270-277 for my fast lap. is this time for an oil cooler too?
sickmint79 is offline   Reply With Quote
Old 08-05-2014, 12:20 PM   #157
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
I'll try to keep this updated.
About 3 week ago on the track the magic P0351 came back (Last year was a DI Seal)
This time it was clearly the coil since I don't have any POP.
Just before my appointment to my dealership, my friend @Silverdub who always work on my car told me just to swap the coil on the same bank to be sure that is the coil. If the DTC goes from P0351 to P0353 we'll be sure that the coil is defective.
But guess what, on track condition with swapped coil, no more DTC at all. So I've cancelled my appointment and I've done this...
- The coil that was at cylinder 1 is at cylinder 3 position
- The coil that was at cylinder 3 is at cylinder 1 position
- I've covered the coil with DEI Cool-Tape: http://www.designengineering.com/cat...ials/cool-tape
Now I'm testing it... This week I'll track it and I'll give you some update.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 08-11-2014, 04:12 PM   #158
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Updates ?
Yamajee is offline   Reply With Quote
Old 08-12-2014, 12:38 PM   #159
trueno86power
[||•]=(86)=[•||]
Originally Posted by Yamajee View Post
Updates ?
I did not make a run on the track since it's raining everytime theirs a lapping session -_-.
But I've made a cupple 3-4 WOT shift in race condition and still no DTC.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 08-13-2014, 06:40 AM   #160
Yamajee
Yamajee's Avatar
I'll swap them out then, I usually get them at 3-4 WOT.
Old 08-17-2014, 01:30 PM   #161
playdjembe4god
playdjembe4god's Avatar
Drives: 2013 Ultramarine Scion FR-S
Got mine for the first time yesterday. Downshifted to 3rd and gave it WOT with the AC full blast because my car sat 12+ hours in 90+ degree weather. Checked the code, cleared it, and got on here first thing. Glad to see it's not mod related. I've got a Unichip intake and tune and a Perrin crank pulley.
playdjembe4god is offline   Reply With Quote
Old 08-19-2014, 10:47 PM   #162
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Add me to the list. Got the dreaded 0351 code in session 3 on Sat along with some backfire or popping noises when down shifting. Did quick research and cleared the code but it came right back on the next session. Cleared it again and took the car out for the orientation laps the next morning, no cel. First session it came back and the noise was more prevalent. Retired after cel reappeared.
It was 97 degrees out in the afternoon but cooler in the Sunday morning session. I have an E85 tune and oil cooler. Guess I'll replace the coil on #1 and see if that resolves the issue but the popping sound has me concerned.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 08-19-2014, 10:58 PM   #163
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Check your DI seals if the popping persists after replacing the coil. Keep an eye on your AFRs in the mean time.
Old 08-19-2014, 11:51 PM   #164
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
I think the ECU parked above cylinder one is trapping the heat.
These IR images of my engine show it's very hot relative to the ECU mounting bracket.
I'm going to switch to an aluminum ECU bracket and see if it dissipates some of this heat better.
romin is offline   Reply With Quote
Old 08-20-2014, 01:00 AM   #165
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Took mine to the dealer for this code P0351, and the updated the ECM first thinking it was causing the code. Drove a little bit and bam the code was back immediately, took it back, they swapped the coils and no more issues. My mechanic seems to think that the connections became poor and were the cause of the code. I got 500 km on the update and coil swap and have tried my hardest to get it again before I leave for a big road trip, but no luck. moral of story, I was certain it was a bad coil but knock on wood - "was an easy fix". I'll update should anything pop up. I have 54000 km. All stock.
Gords_zenith is offline   Reply With Quote
Old 08-20-2014, 06:31 AM   #166
trueno86power
[||•]=(86)=[•||]
Good to know. I've swapped my coil me too and no DTC since then. Today I will (finaly) make a track session. Let's hope that it's okay!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 08-20-2014, 09:52 AM   #167
Deep Six
Deep Six's Avatar
Drove it around on quiet streets this morning and the cel did not come back however I was able to isolate the noise as an exhaust backfire not a popping sound. I also found carbon traces at the connection between the front pipe and overpipe where there is a tiny exhaust leak.
[SIGPIC][/SIGPIC]
Old 08-20-2014, 10:30 AM   #168
ATL BRZ
ATL BRZ's Avatar
Good news. DI seal failure will produce popping noises from underneath the intake manifold.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
