Old 08-18-2014, 08:52 AM   #1849
Racecomp Engineering
Originally Posted by Panman View Post
Are the RaceSeng CasCams:
1. Worthwhile with Std Shocks.
2. Available with perches for the standard springs.
1. If you track the car and need/want the camber, yes.
2. Yes.
- Andy
Old 08-18-2014, 09:07 AM   #1850
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
2. Available with perches for the standard springs with aftermarket dampers, then change to Hyperco spring perches later.
Revised Question 2 because that's what I'm thinking of right now.
bimmer635csi is offline   Reply With Quote
Old 08-18-2014, 09:21 PM   #1851
Calum
That Guy
Drives: 2013 asphalt FRS MT
Recently put on MPSSs and now when I'm approaching the new found limits I find the car bouncy/floating mid corner when going over even mildly uneven pavement. Is it possible to keep it predictable and steady going over bumps while the bump stops are well compressed? Without either spending a shit ton of money, or turning the limit into a knife edge that I wont feel comfortable with either?
Set up is stock unless otherwise stated:
RCE Yellows
Whiteline: diff inserts, subframe inserts (I doubt these would have much to do with it, but it's possible, camber bolts, and front control arm bushings.
And of course, the 215-45-17 pilot super sports.
Old 08-18-2014, 09:32 PM   #1852
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I think u can try to keep off the bump stops by adding roll stiffness via anti sway bar or stiffer spring rates, but you might have other problems to worry about if u go that route. You probably have to source out different bump stops or live with it otherwise.
Old 08-19-2014, 12:09 AM   #1853
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Um. When staying to the adjustment recommendations on the spl parts camber arms, the most negative I could get the camber (on a stock car) is positive 44 minutes left, and positive 4 minutes right. Can't get the toe anywhere close to acceptable. Is it safe to just thread the thing out beyond their nominal limits?
NissanGuy is offline   Reply With Quote
Old 08-19-2014, 12:30 PM   #1854
solidONE
solidONE's Avatar
RCE Yellows
@Racecomp Engineering Andy, any solution/suggestion for this?
When I had the Swift sport spring and cut bumpstops I had similar issues riding on 245/45/17 Goodyear F1's. I just figured that it's something I'd have to learn to drive around until I upgrade. You really cant ask for perfection with a set of lowering springs on factory dampers. Didnt really think it was that big of a deal, the bounciness, to be honest. I still like it much better than all stock FR-S suspension.
Not sure what 44 minutes and 4 minutes means but maybe some of the vendors like @CSG and @Corner3garage that sell these things can help you.
Old 08-19-2014, 12:43 PM   #1855
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
There are 60 minutes in 1 degree.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 08-19-2014, 01:02 PM   #1856
MyRx
MyRx's Avatar
You can still get some toe with the OEM toe links. The camber arms have none or minimal toe adj. SPL does sell toe links (in conjunction with their lockout kit). How much toe are you looking at?
Old 08-19-2014, 01:37 PM   #1857
RCE Yellows
Better shocks will help.
- Andy
Calum (08-19-2014), MyRx (08-19-2014)
Old 08-19-2014, 01:44 PM   #1858
Calum
That Guy
- Andy
Any time line on the revalved bilsteins?
Old 08-19-2014, 01:58 PM   #1859
solidONE
solidONE's Avatar
Wow did not expect that from these spl arms with only a fraction of a degree of adjustment toward negative. Extending them beyond recommended length is going cause problems. he should really call spl up or consider a different brand.
- Andy
Heh... I thought you were trying to avoid spending that kind of money.
Old 08-19-2014, 01:59 PM   #1860
Unfortunately it doesn't look like we'll be able to do custom Bilsteins for this platform.
Might have something else up our sleeves, but too early for a timeline.
- Andy
Calum (08-20-2014)
Old 08-19-2014, 02:13 PM   #1861
STV3
Señor Member
STV3's Avatar
So still nothing on the TRD springs as to whether they positively or negatively affect the handling of the FRS?
Really just looking to keep the cars ride quality and handling as close to stock as possible.
STV3 is offline   Reply With Quote
Old 08-19-2014, 02:30 PM   #1862
Calum
That Guy
~$1000 for good dampers I'm fine with I've been discretely encouraging Andy and Myles, for close to two years now, to make a custom valved damper set.
It's things like the Ohlins coilover kit at ~$3100 plus paying someone to corner balance the car afterward that I'm looking to avoid.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
