Old 08-11-2014, 10:11 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by sw20kosh View Post
Does an oil cooler mounted behind the fog light/turn signal bezel (with a cut-out in the wheel well liner to let air flow out) make you face palm?
Sorta... depends on the application, but generally speaking yes.
AZP Installs (08-11-2014)
Old 08-16-2014, 01:45 PM   #16
MyRx
MyRx's Avatar
Just lurking here as now I have an extra fog light bezel emptied. Passenger side bezel has the oil cooler. Pondering the idea of either 1) move the core to the driver side or 2) how to make use of the driver side as cooling the window washer reservoir is pointless.
Old 05-20-2016, 10:46 PM   #17
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Easier to just size the oil cooler properly.
A 13 row series 6 setrab is too small for FI.
@CSG David says the 15 row series 9 setrab is working well on the JR supercharger on track but they have played around with the possibility of the 20 row series 9 setrab (less pressure drop than the 15 row) to get temps down further from 245-250.
I think I am going to swap my 13 row series 6 for a 20 row series 9 on my turbocharged setup. No need for the complexity of a dual cooler set up.
I think you might run into pressure drop issues with a dual cooler set up too?
What core comes with the JR kit?
Edit: Never mind, I see that it's the 15 row.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Double Parked FR-S xantonin Scion FR-S / Toyota 86 GT86 General Forum 9 03-15-2014 01:05 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 06:46 PM
Halo 4 Double XP xn7485 Off-Topic Lounge [WARNING: NO POLITICS] 0 11-19-2012 10:51 PM
sorry double post LS13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-29-2012 03:42 PM
Double U T F...is this for real? Hawk77FT AUSTRALIA 20 07-14-2012 06:21 PM
