Old 08-14-2014, 09:50 AM   #1
Don Ivey
Drives: '13 FR-S
How Much Oil is Too Much?
I had my oil/filter changed at the dealership, and once home checked and it is about an eighth of an inch over the full line. Should I bother removing some, or is it ok? Thanks,
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
Old 08-14-2014, 12:51 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
It'll be fine. Over-filling a smidge won't harm anything. If it's grossly overfilled, the crank and come in contact w/ the oil causing aeration, but that's usually only if it happens to be like an inch above the max fill line.
aznatama is offline   Reply With Quote
Old 08-14-2014, 01:30 PM   #3
mike the snake
Agreed.
Dealership overfilled my car by an inch above the full mark on dipstick. I felt that was too high and had some oil removed.
A tiny bit above the full mark is nothing to worry about.
Old 08-14-2014, 04:38 PM   #4
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
It's fine.
If anything, you need to add more.
NWFRS is offline   Reply With Quote
Old 08-15-2014, 12:04 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Remember to take the lower marking for your oil level.
Also, would you be happier if it was an eighth of an inch oil before the fill line?
N1rve
Old 08-15-2014, 10:08 AM   #6
Don Ivey
Drives: '13 FR-S
Not quite sure what you're saying. OTOH, sounds like I'm ok with a bit over full line. Thanks,
Don Ivey
'13 FR-S (Hot Lava)
Old 08-15-2014, 11:10 AM   #7
N1rve
N1rve's Avatar
In the manual it states that when you check your oil, you'll get the front and back of the dipstick wet. The lower one is your oil level.
N1rve
Old 08-18-2014, 02:25 PM   #8
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
Make sure the car is on a level surface when you check the oil- it can make a big difference.
cwb48 is offline   Reply With Quote
