Old 08-08-2014, 08:47 PM   #645
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
FlexFuel Tuning will be even easier now for those of you running our Speed Density tunes. We have now confirmed our Speed Density tunes work perfectly with our Flex Fuel connected directly through the MAF sensor. So now installation could not be any easier.
Literally pop your hood, connect in the fuel system, connect in the plugs to the OEM MAF sensor, close your hood and install our Speed Density FlexFuel tune. No need to go under your car, no need to wire through the firewall, just pop your hood and everything you need is right there.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
maziar (08-09-2014), whataboutbob (08-13-2014)
Old 08-10-2014, 04:07 PM   #646
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
So when will this kit be available for pickup? Also, do you guys sell a e85 safe fuel pump as well? Thanks!
texasbound972 is offline   Reply With Quote
Old 08-12-2014, 11:04 PM   #647
DeliciousTuning
Our kit should be available for sale within the next couple weeks if all goes as planned
As far as the fuel pump goes, we have put thousands of miles on the shop brz on E85, as well as countless customers, all on the stock pumps, without any issue. What we do see is customer's eventually maxing out the flow capabilities of the stock unit when they make enough power.
While we have seen a thread or two on here about the fuel filter disintegrating, we do have a hunch that there may have been some other fuel additives at play there. It's hard to say for sure. What we do know is from our own personal experience and that of our customer's.
Bill and I will both personally be running the stock pump until we need to upgrade due to needing more fuel flow.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
texasbound972 (08-13-2014)
Old 08-13-2014, 12:17 AM   #648
Dezoris
Dezoris's Avatar
Can you build, power reduction into the tuning based on oil temps?
(dynamically lowering redline, timing etc.)
Been working on a project and talked to several people about the bottom end of this motor and there are great concerns about oil pressure drop with higher oil temps and power.
Bill in any of your tuning are you monitoring oil pressure on your FI tunes?
And when I mean monitoring I mean when oil gets to track temps like 235-255F.
Because we are seeing near 40PSI at 7000RPM when oil hits 240F.
Which is 20PSI lower than when oil is at 200F.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 08-13-2014, 02:17 AM   #649
8686
8686's Avatar
Drives: 86
Dear Bill
Do you have a way to measure IAT post super charger?
I was offered an Innovate supercharger without intercooler with an attractive pricing.
Should I go for it? or just wait until I can afford and intercooled one?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-13-2014, 02:40 AM   #650
aero.kit
Drives: GT86
Hi,
What's my order (HKS v2 tune file + ecutek) ? his placed few days ago .
Thank you !
aero.kit is offline   Reply With Quote
Old 08-13-2014, 12:57 PM   #651
DeliciousTuning
Originally Posted by aero.kit View Post
Hi,
Thank you !
Hi,
Your cable and license order was placed yesterday according to our records and will be shipped out today. The file was ordered a couple days ago as you stated but we did not have a dongle ID for the file. Now we know why, as you needed a cable and dongle.
Everything is shipping today.
Cheers,
William Knose
aero.kit (08-13-2014)
Old 08-13-2014, 01:00 PM   #652
DeliciousTuning
We can accomplish this, should not be a problem. We have the ability to add this into custom mapping and pull power out of the tune. We have tried playing around with closing the throttle, but if it becomes too aggressive it will throw a check engine light. But power wise we can pull back on cams, timing and add fuel. So there are plenty of options to get things cooled down.
Is there someone that goes to the track often enough that we can test this with, as I would be interested in working out some sort of scaler to work into the system to make it work.
Cheers,
William Knose
Dezoris (08-14-2014)
Old 08-13-2014, 01:03 PM   #653
DeliciousTuning
Originally Posted by 8686 View Post
Dear Bill
We have an adapter that goes in between the the MAF sensor connector so you can install a intake temp sensor. We are sourcing the intake temp sensor we would like to use with it. But this should make it pretty easy and we can scale the timing for charge temps for you.
Definitely a good kit and worth it. You can always upgrade later too.
Cheers,
William Knose
Old 08-13-2014, 01:10 PM   #654
8686
8686's Avatar
Drives: 86
Cheers,
William Knose
Thank you for your reply.
where can I order this as I couldnt find it on your website?
Old 08-13-2014, 01:21 PM   #655
DeliciousTuning
I will add it to the website a little later this week. Sorry been busy with many other things lately.
Cheers,
William Knose
Old 08-13-2014, 11:10 PM   #656
texasbound972
USMC
You say additives might cause the fuel pump to disintegrate. If I added the Lucas E85 fuel conditioner in would that cause the pump to go bad?
Old 08-14-2014, 10:37 AM   #657
ja1217
Drives: 2004 Toyota RAV-4 5M
Figured I'd give a little review of the Stage1 Pump Gas tune on 93 octane.
Blue line is stock tune, red and green are with the Delicious tune.
The tune worked completely as advertised, picking up about 8whp at peak, but 11whp and 13wtq in the mid range. My car has a totally stock exhaust system and just a drop in K&N air filter. I've done a few other mods that might slightly effect hp, such as CF driveshaft, lighter clutch/flywheel, and Perrin motor mounts, but I doubt they have much effect. My car just seems to make more power than most as most stock cars only make around 160-165 whp on this dyno.
So thanks to @DeliciousTuning for the tune and to @Pure Automotive Performance for the dyno!
ja1217 is offline   Reply With Quote
The Following User Says Thank You to ja1217 For This Useful Post:
DeliciousTuning (08-14-2014)
Old 08-14-2014, 11:23 AM   #658
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Cheers,
William Knose
What about the heat soak issues other people were having with the IAT sensor not being in direct air flow if it is installed post blower? With what you're going to have available, does this solve that problem? I'm fairly certain my setup eliminates that problem, but it's not something most people are going to want to do. Especially with how well the car runs with your OTS tunes you have available.
Dustin is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
