#127 |
Drives: Waiting for the ND Miata
This is the first negative review I've seen. But also the first automatic comparo.
#128 | |
Kuruma Otaku
Subaruwrxfan: In their cases their performance comes more from exceptionally low mass than rigidity. But they were also designed from the ground up to be top-less and still meet their rigidity targets. 7 through its backbone chassis, Atom through its large triangulated arced side structures. The reasons that Lotus and McLaren dominated in their eras in F1 were major breakthroughs in rigid chassis design. Lotus with the aluminum monocoque and McLaren with the carbon tub. So reducing the rigidity of the BRZ through cutting its roof off will not be a good thing.
Because titanium. |
#129 |
Rocket Surgeon
Drives: PSM GGA OMG
#130 |
Drives: Attitude
#131 |
Drives: 2011 WRX
I think the auto trans is a big down fall here. As all the other reviews seem to back up. And as for the understeer I think a simple in-expensive upgrade to a larger rear sway bar with cure that completely. I had a 00 Type R. Loved it and to this day I wish I had kept it. I am hoping this car will remind me somewhat of a RWD version of it.
#132 |
Drives: FRS :D
Sorry wrxfan but you lost me once you said convertible and lighter than a coupe just because they had it in mind when they were designing the car
If we are doing unfair comparisons then you should argue that a F1 car is technically a open top car
Out of the FRS game
#133 |
Motordyne
Drives: Nissan Z & Infiniti G
Tests like this should be done with a manual transmissions to better convey the potential.
#134 |
Habitual Line Crosser.
Drives: ^ Two of my favorite things.
Were the other cars in the outfitted as such? I think that is the case. Regardless, a six manual variant should have been used since it has more sporting gear ratios.
But, but, but... It's only 200 hp?!
#135 |
Drives: Clio TCE
Read through the whole article (and spoiled the issue that's going to arrive soon as I'm subscribed)
As my choice for the next car are in the article (Megane RS 250/265 or GT86, both available aroun 25k euros by the end of the year) it was very interesting. Everything I though about the car was confirmed: -Engine is too weak for the chassis -Auto box is useless -Why not normale sportier tyres? The fact is the 86/BRZ was made to be modified, so a coilover kit, exhaust+ecu tune or supercharger etc will be fitted by many onwers. |
#136 | |
Drives: 04 Evo 8
But you're right, many will mod it right away. Suspension kits like full on coilovers and lightweight wheels plus respectable tires would put this car's handling on a different level that truly will rival supercars and specialty cars (Cat 7s, Exige, etc). But once again, it's going to boil down to that lump they threw in the car that's going to drag it down. I think it's safe to assume I/E+T won't yield great gains at all. This car isn't FI, nor is it a larger displacement. Only way to get some power out of this is going FI aftermarket/TRD. Which outside of a TRD option, aftermarket is scary for those who rely on the car as their everyday machine and possibly can't afford the repairs if the engine pops under pressure. It's unfortunate, but from the tests they almost all grumble "wish it had more power", as expected when the numbers were unveiled. Toyota/Subaru made an incredible chassis, but they put in a dud of a motor. Which, perhaps the FI model wasn't really ready yet under tests as this is a newer block, or Toyota thought they could get away with throwing the car out there as is, testing the waters, but it backfired. I'm sure Subaru had Turbo in mind from the get go. They understand their enthusiast followers at least, and listen. Would not be surprised to see a Turbo/SC version of this car next year. Two years tops. |
#137 |
Drives: Clio TCE
I'm really thinking to buy a 2 years old Megane RS and switch to the 86 once the FI version comes out or when some SC aftermarket kit has been proved realiable and you can get a used 86 for ~20.000 euros.
http://www.autoscout24.it/Details.aspx?id=212580382 A few months of warrany, Recaro seats, 18", RS monitor, bixenon, LSD, parking sensors, bluetooth, upgraded stereo with USB and ipod connection, 12k miles... Last edited by Gardus@Supersprint; 04-23-2012 at 09:40 AM. |
#138 | |
Drives: 13 BRZ, 04 SV650
#139 |
Drives: Clio TCE
Yes too bad, it's faster than the Golf GTI or R and the S3. With a few tweaks is dangerously close to a 1M or an RS3.
The trophy has close to 280 hp stock and we tested one with a full exhaust on the dyno with very cold weather and the non corrected value of the flywheel power was 305 hp! All the 2012 cars get the Trophy engine... |
#140 | |
Site Moderator
Drives: Stuff
The car was never less fun beating on it because it wasn't sideways all the time. On the street the S2000 wasn't all that fun though because the limits were too high. Evo points to the same problem with the BRZ but as has been said their goal was power oversteer, and that's not the sole definition of "fun to drive" in my mind.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| SoCal BRZ Group Buy | Giccin | Southern California | 1297 | 04-27-2013 03:29 AM |
| Houston Group Buy | BradBot | Southwest | 110 | 06-11-2012 03:20 PM |
| Australian BRZ Group Buy | coyote | AUSTRALIA | 20 | 04-19-2012 07:56 AM |
| Ontario (or whatever) Group Buy | no_name | CANADA | 6 | 02-05-2012 09:39 AM |
| FT-86 focus group | mokinbird87 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 11-11-2011 05:11 PM |
