Old 08-11-2014, 10:13 PM   #1261
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by DC2R View Post
You could use auto start app to run scanner.
Iono
Sent from my SM-N900T using Tapatalk
Problem is the scan takes a few minutes to complete with my 256gb flash drive... just not a reasonable option, surely there has to be a way for the app to see /mnt/usb/sdb1/ without doing that every time.
Deathalo is offline   Reply With Quote
Old 08-11-2014, 10:36 PM   #1262
inositle
Drives: Subaru BRZ Limited WRB
I posted my Google Doc a few weeks ago that I've been building up with a collection of all the tips & tricks from this thread. Just a reminder that if anyone wants to help add on to it, it is open for editing and hopefully has a good amount of useful information on it. I know a couple other people from here have been adding to it also.
Google Doc link: https://docs.google.com/document/d/1...it?usp=sharing
inositle is offline   Reply With Quote
Old 08-11-2014, 11:42 PM   #1263
DriftEm
DriftEm's Avatar
How you installing PowerAmp? when i try, it says not supported
DriftEm is offline   Reply With Quote
Old 08-11-2014, 11:44 PM   #1264
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
They don't have the Dashlinq4 in their list of compatible devices on Google Play, even though it does (at least mostly) work. To install it, you have to download the APK from their website and sideload it.
SilverlightPony is offline   Reply With Quote
The Following User Says Thank You to SilverlightPony For This Useful Post:
DriftEm (08-11-2014)
Old 08-12-2014, 10:38 AM   #1265
Deathalo
Unfortunately Poweramp has probably the worst control layout for car control of any of the major music apps, so I really need to use a different player so I'm not running off the road trying to read the stupid small font on the song listings. PlayerPro would be perfect, and maybe Shuttle too, but I can't get them to continue to read my music.
Old 08-12-2014, 10:58 AM   #1266
Foobar
SLO NO MO
Foobar's Avatar
Just an update for anyone curious about their current order to ship lead time - I ordered on the 5th (Wednesday) and received tracking info on the 11th (Monday). Anyone know how long DHL takes to get from Hong Kong to NY? I'm assuming I'll have it by the end of this week.
Old 08-12-2014, 12:51 PM   #1267
LPC_FRS
LPC_FRS's Avatar
Drives: Scion FRS
Does anyone know if this will work fine with the O+ 400 or reference series audio upgrade you can purchase for the car.
LPC_FRS is offline   Reply With Quote
Old 08-12-2014, 01:48 PM   #1268
SilverlightPony
I'm using this HU with the 400 cf reference system. Works great.
Old 08-12-2014, 03:27 PM   #1269
Deathalo
BOOM! USB MUSIC REMOUNT!
AHA! I figured out how to get all your music from USB storage to show up on any music player!
First, you need root access.
Once you're rooted, download this app: https://play.google.com/store/apps/d...e.fmount&hl=en
What foldermount does is essentially creates a link to your external USB mounts (that are not scanned by the system "media storage" app, that most music players use to detect music) and puts those links inside your internal sdcard folder so that media storage can scan those files!
So basically you just have to set the source path like this /mnt/sdcard/Music/ (or wherever you want the USB to show up)
and your destination as /mnt/usb/[drive name mine is sdb1]/Music/
Set it to launch at boot and then reboot and you'll see it activate in the notification bar upon reboot, then your music will show up in all your music players!
Note: This doesn't just work for music, it can actually be used to remap your micro SD card as internal storage for more app and data space if you really get into it. This could really change the game for this HU, you could use it to store Sygic map packs on your micro SD, change download paths to USB or Micro SD, or put whole apps on the micro SD card if you're so inclined (your results may vary), enjoy!
Edit: I originally posted the directions backwards, source should be internal and destination should be usb drive.
The Following User Says Thank You to Deathalo For This Useful Post:
bwthor (08-13-2014)
Old 08-12-2014, 04:35 PM   #1270
Foobar
SLO NO MO
Foobar's Avatar
Since you need root anyway, why not just use a symbolic link from terminal? I assume that's what this app is ultimately doing anyway.
Old 08-12-2014, 04:39 PM   #1271
Deathalo
I'm not exactly sure what you mean or how to do that, is that a permanent change or something that would be required on every boot?
Old 08-12-2014, 05:31 PM   #1272
Foobar
SLO NO MO
Foobar's Avatar
You could use a command line operation (using the ln -s target source command in terminal) to symbolically link an internal directory to an external sdcard one. For all intents and purposes, any application navigating to the source directory will be hitting the target one without it knowing.
It should persist through boots unless android works differently than I think it does.
Old 08-12-2014, 06:58 PM   #1273
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I just changed the Poweramp theme to one more suited for a car.
Prog is offline   Reply With Quote
Old 08-12-2014, 07:07 PM   #1274
DC2R
Drives: 2014 Scion FR-S
What theme?
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
