#57 | |
Drives: 2018 BMW M240i
I love, love, love the way my car looks and sounds. BUT If I was starting from ground zero I would have not done a single one of those things and used all of that towards a supercharger or turbo installation. Of course now FI market is a little more mature than 1.5 years ago when I bought my car. So now I wont be spending anymore $$$$ on my car until I'm ready and able to go full forced induction. |
#58 | |
Drives:
| The Following User Says Thank You to WallsAndFoundations For This Useful Post: | tennisfreak (08-04-2014) |
#59 | |
Drives: accord
#60 | |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
You cant use a LWFW on an AT car, so yes they were manuals. |
#61 | |
Last one went 2000 miles (hard miles) and the bearings looked like they had 150+K on them. Visible bearing material in the oil. Showed it to the owner and he went back to a stock crank pulley with the rebuild. |
#62 | |
Drives: small
Yeah, but what were you logging? Just MPG?? That wouldn't be conclusive over hundreds or a thousand miles given variables in weather, temperature and humidity. Was that the only variable you tested for or did you also make other mods to the car at the time? FI is another topic so I don't want to muddy up the LWCP thread bringing FI into it. Increasing MPG using a SC would be the complete inverse process compared to a LWCP so the two have nothing to do with each other. So can you share what RPM is the sweet spot with a LWCP on the FA20 or no? Right, ATs already have one called a flexplate. |
#63 |
We did not add the S/C kit to increase MPG. Lol.
You dont need a LWCP to increase MPG. We can do it with just tuning. We dont "log" MPG. We log lots of other data points. We estimate MPG by calculating amount of fuel added over several tanks compared to miles driven. I will compare notes from our in house tests to notes gathered from customers verifying fuel efficiency for us (different cars have different set ups) and see if I can discern the best MT and AT. But, keep in mind the "sweet spot" is not something you can set the cruise to. It modulates based on load and throttle position. So, to stay in it the most often you need to have electronics plugged in to see data points so you can constantly modulate the left foot to stay in the sweet spot. That is why we have spent so many hours working on the tunes (with Delicious Tuning) to get the most MPG we can out of the standard tunes we offer customers. Sorry to get off topic. |
#64 | |
Drives: 2014 Scion FR-S
Sent from my SM-N900T using Tapatalk |
#65 | |
Drives: 2013 GBS BRZ Limited
![]() Or maybe you didnt really mean that.... |
#66 | |
Drives: small
That's the same thing. Whether you record it via ECU or pump reading using pencil and a calculator, it's a log. Best way to verify fuel efficiency is to dyno the engine with the LWCP and then the stock one and compare BSFC. I say LWCP first due to increased efficiency in tribology from a warmed block which would skew claims in favor of an aftermarket part. IF you are talking a tuned motor then all bets are off on the LWCP claim unless you can compare versus a tuned stock block as a baseline. You have to be able to prove the tune is not responsible for the change in MPG rather than the LWCP claim. |
#67 |
WTF are people getting stuck on MPG? This has nothing to do with this thread!!!!!!!!!!
| The Following User Says Thank You to tennisfreak For This Useful Post: | Infamous Performance (08-05-2014) |
#68 | |
So, it only seemed natural when we began working with the BRZ/FRS to see if the same results could be had. Once again, it takes constantly watching load, rpm, fuel pump duty, idc, pulse, etc. to determine actual current and constant mpg. From there you have to constantly modulate the gas pedal (ever so slightly). My wife got more than annoyed having to make room for my laptop and mount sitting in the passenger seat for a 4000 mile road trip while I tried to "win" the game of highest attained mpg. But same cars. Pre and post pulley. You can gain 1-2mpg. It is far easier to do with a tune. Now, for most customers who are adding performance parts in the attempt to gain power, speed, handling do not ever see increased mpg. Why? because they bought the parts to use their right foot. Its the same thing as K&N's claims of increased MPG by using their filters and intakes. Can it be done? Sure. Do 99.97% of customers see any increased mpg? No. Because they like the sound the intake makes when they floor it. Lol. |
| The Following User Says Thank You to Infamous Performance For This Useful Post: | kavanagh (09-11-2014) |
#69 | |
Drives: small
Huh? It has everything to do with whether the LWCP provides the increased efficiency the vendor claimed. Are we supposed to treat aftermarket parts like blessed holy water now and go on faith? |
| The Following User Says Thank You to Boxer486 For This Useful Post: | WallsAndFoundations (08-05-2014) |
| Light weight flywheel and crank pulley? | wootwoot | Engine, Exhaust, Transmission | 133 | 06-23-2015 01:04 PM |
| Light Weight Pulley's | exam2300 | Engine, Exhaust, Transmission | 18 | 02-08-2014 12:02 AM |
| FS:PERRIN Light weight pulley NEW $85 Shipped | Amalgamo | Engine, Exhaust, Bolt-Ons | 1 | 05-01-2013 11:10 AM |
| FS - Agency Power Light Weight Pulley | Kochinopride | Engine, Exhaust, Bolt-Ons | 3 | 11-12-2012 05:32 PM |
