Old 08-04-2014, 12:00 AM   #29
steve99
Drives: FT86
Originally Posted by Walla Walla View Post
every time that it knock, does it go to a "safe map" ? if so, i should better try to track down all those spikes? or is it kind of overkill to tink of that?
Only time it goes to safe map is if somethng is broken eg a sensor or some situation where the ecu decides the problem carnt be solved you will generally get a CEL ,light and car will be very sluggish.
If you read the knock thread it will explain see below, basicly it just pulls timing on knock, just chase it if its consistently happening.
Walla Walla (08-04-2014)
Old 08-04-2014, 08:23 AM   #30
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Your on 93 octane fuel ? with 93 octane tune ?
reason I ask is your IAM=0.55, so its been knocking quite a bit somewhere outside that log.
Their is some positive FLKC so the ecu is returning some timing.
If that IAM has not recovered to 1, just plug in your OFT and log on screen . then it looks like you might be better on the 91 octane tune.
Yep it's a 93 tune with 93 octane gas (or so the sticker on the pump says)...so I want to monitor the IAM to see if it comes back to 1? If it stays around 55, should I use the 91 tune with my "93" fuel? Will I have to reset the ECU or will it automatically begin to re-learn the IAM?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-04-2014, 10:03 AM   #31
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
you should try to capture a full open throttle log on 3rd gear (from 2000rpm to 7600rpm) it will give a better idea
if you switch to 91 tune, it will reset everything. each time i did flash ecu, IAM started at 1.0, then moved a bit (lower i got was .88) and then replace itsefl within 50 km to 1.0
Walla Walla is offline   Reply With Quote
Old 08-04-2014, 10:10 AM   #32
Malt
Drives: 2015 WRX
If my IAM was at .55 with the new 93 octane map there would be no hesitation on my end to do one of the following:
Figure out what's causing the knock (bad fuel?) or swap over to the 91 octane maps and still use 93 octane. The previous maps shiv has given us were all based on 91 octane to begin with and these new 91 maps are even more tweaked, so its not like you'll lose all that much. Then again, you could just let the trims learn a bit more and take more logs. Its highly likely that once the ECU learns all the trim conditions things will fix itself. You could also try to scale your MAF to see if that helps things along (if your trims are excessive).
I also have some slight knock at lowish RPM and high load in a higher gear, which is to be expected. The knock you are seeing is slightly concerning to me, but I'm not a pro tuner or an expert on these matters. I've contemplated swapping back to the 91 maps just for a margin of safety as the maybe 1-2 HP we're getting with these new maps isn't worth the knock that some of us are getting due to poor fuel.
Where I'm noticing my knock is during throttle transitions between no throttle and part throttle. The knock is very slight but it appears that STFT is pulling back excessively as soon as you get back on the throttle which is causing a lean condition, which results in the knock event. It rapidly corrects itself but I'm wondering if there is a way to correct the issue without resorting to dropping down to the 91 maps. @Shiv@Openflash might be able to shed some light on this matter.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Silver Ignition (08-04-2014)
Old 08-04-2014, 11:54 AM   #33
Silver Ignition
APEXHNTR
I'll do one more 3rd gear pull as it sits, from 2k all the way up to redline and post up tonight. I'll load a Stage 1 91 BPB-modded map onto the OFT tonight and do another 3rd gear pull with that map tomorrow.
Easy to do safely on the way home from work because there's an unused airstrip near my job
#1867 of 2500
Old 08-04-2014, 02:55 PM   #34
Kodename47
Kodename47's Avatar
Drives: UK GT86
It depends on where the knock is. The only differences between the 91 and 93 maps are 1.05 degrees of timing over 6k. That's stage 1, but I'd guess similar for maps with EL/UEL manifolds.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
drewbot (08-03-2015), Malt (08-04-2014)
Old 08-04-2014, 02:59 PM   #35
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Shiv@Openflash .....
Originally Posted by Kodename47 View Post
Shiv, what's the reason for adjusting the rear cylinder compensations for this and not for the other tunes? Which I guess asks the question as to why they are there in the 1st place?
I know that zeroing out the compensation is a good way to make power but at what cost?
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-04-2014, 05:42 PM   #36
Silver Ignition
APEXHNTR
Here you go...full 2-7.6 run...IAM is now between .96 and 1...maybe it just had to learn? Same tank of gas on all three logs...anyways, here goes;
http://datazap.me/u/silver-ignition/...l?log=0&data=1
#1867 of 2500
Old 08-04-2014, 07:21 PM   #37
steve99
Drives: FT86
It still pulling -3.5 degrees at around 6500 maybe you can try fuel from a different supplier or switch to 91 map that has leass advance over 6000
Old 08-04-2014, 07:45 PM   #38
Walla Walla
Hicas Thread Basher
could also try removing a few degree of advance timing around 6 000 and more, similar to what i did and keep the 93 octane tune? since you never know exactly what kind of gas quality you will have, just to be safe (consider this as a not know-it-all advice!)
Old 08-04-2014, 08:06 PM   #39
Silver Ignition
APEXHNTR
That kinda stuff scares me…maybe I'll e-mail @Shiv@Openflash for some custom work
#1867 of 2500
Old 08-04-2014, 08:09 PM   #40
Silver Ignition
APEXHNTR
yeah that's a really weird spike…that's right in the wheelhouse where this thread is aimed too…6200-6700
#1867 of 2500
Old 08-04-2014, 08:20 PM   #41
Silver Ignition
APEXHNTR
can you guys tell me if I'm in the right area here…
should I be pulling those 20.62's back to 18.16 or the other 18.87?
#1867 of 2500
Old 08-04-2014, 08:24 PM   #42
Malt
Drives: 2015 WRX
Just use the 91 octane maps and try some logs. The only difference between the 93 and the 91 is the timing is 1.05 degree higher on the 93 maps above 6k like @Kodename47 pointed out. Far simpler and less chance for you to accidentally mess something up unintentionally.
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
