Old 08-03-2014, 01:17 AM   #15
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
here is mine
around 50 km done since the flash, 3rd gear pull
http://datazap.me/u/walla-walla/stag...1?log=0&data=1
is it me or it seems like my pull is a bit more lean than the one from silver ignition?
waiting from comments of someone who understand all those parameters!
Walla Walla is offline   Reply With Quote
Old 08-03-2014, 02:53 AM   #16
steve99
Drives: FT86
Originally Posted by Walla Walla View Post
here is mine
Its actually a bit richer higher the AFR number = leaner, lower the number = richer.
As @Malt said ditch the VVT intake and VVT exhaust cam parameters and replace them with FLKC (fine learning knock control) and FBKC (Knock correction). it looks like you have a bit of knock but its much easier to tell if you log the correct knock parameters. .
If you read the links below will help you understand more
The Following 2 Users Say Thank You to steve99 For This Useful Post:
73TORANA! (10-09-2019), Walla Walla (08-03-2014)
Old 08-03-2014, 05:10 AM   #17
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
Does the BPB show any gains on an OTS E85 map? Even without any changes to the map itself? Or is it a waste of time.....
DEK186 is offline   Reply With Quote
Old 08-03-2014, 06:04 AM   #18
steve99
Drives: FT86
In theory the bpb should shift the peak power lower in the rpm range, by shifting the volumetric efficiency. You may loose a bit of peak hp above 6500 or so, but you should still have the benefits of E85 and bpb below that.
So unless you chasing peak hp at high rpm should still be of benefit. Although shiv's comment in the first post in this thread puts a damper on that.
@nelsmar did a good writeup on them http://www.ft86club.com/forums/showt...t+power+blocks
But he was using his own tunes and on petrol but somewhere else i think he got some pretty good results on E85
DEK186 (08-03-2014)
Old 08-03-2014, 08:33 AM   #19
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Originally Posted by Malt View Post
How many miles are on this reflash? Your IAM is at 1 but you didn't log FLKC or FBKC so its hard to tell exactly whats going on. Based on the dropping of chunks of KC learned through your pull I'd venture to say you've got some knocking going on but if this is a very recent flash your ECU might not of had enough time to adjust the trims.
Log again but this time uncheck VVT Intake and VVT Exhaust and select Knock Correction and FLKC and do another log for conformation.
that log was only about 20-25 miles on the fresh reflash…I'll put some more miles on it, add FLKC and FBKC, and log another pull
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-03-2014, 01:35 PM   #20
Walla Walla
Hicas Thread Basher
here, i've registered the required parameters
http://datazap.me/u/walla-walla/stag...-3rd-gear-pull
i think it doesn't appear within the 3rd gear pull, but prior to recording, on highway cruise (6th gear, 115-120km/h), i saw at least once a fl knock correction of 0.38 degree, and after the pull, still on highway cruise, i saw a few knock correction, at around 0.35 degree and 0.62 degree. so.. is it bad?
Old 08-03-2014, 06:16 PM   #21
steve99
Drives: FT86
Your afr look fine fuel trims ok . The odd bit of 0.7 or so knock correction is almost inevitable. hower the -3.5 your getting at high rpm and load needs some action, either run better fuel octane booster or pull about 2 degrees out of the BASE TIMING B table for you ROM at engine loads 1.2 & 1.3 & 1.4 from 6200 to 7400 then see how it looks.
You could even try fuel from a different manufacturer as some blends are better than others
Old 08-03-2014, 06:29 PM   #22
Walla Walla
Hicas Thread Basher
thanks!
i'm not sure i could find better fuel around the area (i'm currently using shell Vpower, wich seems to be the best we can have around here)
so, just to be sure i understand correctly, if on Base Timing B table at "1.2 engine load" at "6400rpm" i have the value 25.20, i should lower it to 23.30. is that right?
also, fl knock correction, does it means my engine knock, or that it pulled a few timing degrees to not knock?
thanks for the help, I read a few of your thread also, very helpfull, but there is so much to learn on this!
Old 08-03-2014, 06:37 PM   #23
steve99
Drives: FT86
thanks!
Yes you got it correct for table values
any flkc or fbkc knock correction means your ECU is detecting that amount of knock and then making adjustments to timing to correct the knock you logging the adjustments the ecu is making. There are limits to the correction the ecu can make.
I am learning all the time as well
Old 08-03-2014, 09:04 PM   #24
Silver Ignition
APEXHNTR
http://datazap.me/u/silver-ignition/run2?log=0&data=1
@Malt @Shiv@Openflash @steve99
how does this one look to you guys?
#1867 of 2500
Old 08-03-2014, 10:21 PM   #25
steve99
Drives: FT86
Originally Posted by Silver Ignition View Post
Your on 93 octane fuel ? with 93 octane tune ?
reason I ask is your IAM=0.55, so its been knocking quite a bit somewhere outside that log.
Their is some positive FLKC so the ecu is returning some timing.
If that IAM has not recovered to 1, just plug in your OFT and log on screen . then it looks like you might be better on the 91 octane tune.
Old 08-03-2014, 10:30 PM   #26
Walla Walla
Hicas Thread Basher
made the suggested correction, and it really helped!
http://datazap.me/u/walla-walla/bpb-...0&data=1-11-12
i removed 1 degree at 6 000 rpm on 1.2/1.3/1.4 load, and 2 degree at higher rpm on same load!
thanks for the help @steve99, now as I understand, it's doing great! (even if i sometime have knock correction, but it think it is not a dangerous situation under .7?)
Old 08-03-2014, 11:44 PM   #27
steve99
Drives: FT86
Yes that right if its just random spikes of 0.7 or less its ok, if its consistent and at same rpm/load point it might be worth pulling 0.35 or so if your rearly keen.
Old 08-03-2014, 11:54 PM   #28
Walla Walla
Hicas Thread Basher
every time that it knock, does it go to a "safe map" ? if so, i should better try to track down all those spikes? or is it kind of overkill to tink of that?
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
