Drives: 2013 Scion FRS, 1998 Sentra SE
Sounds from the engine
Does anyone else hear the engine purring like sound when it remains in park? I have an automatic 2013 FRS and got it used and still has less than 9000 miles. I do not know if the former owner screwed up the engine internally or something. The sound is kinda like a hoofing sound, coming from inside the engine. Not a belt, but maybe a fan. I have not personally met someone else to compare the sound to. You can also hear it when you are at a stoplight with the windows down.
Cheerz!
#2 |
Drives: 2013 FR-S, 2012 MCS
We need a video/sound clip otherwise this thread is useless sorry bud
#3 |
Is your AC on when this happens?
#4 |
#5 | |
![]() Could you expand on ..... "hoofing sound" ... ?? Does it make the sound with the A/C OFF .. ?? Are the cooling fans running when it's making the sound.. ?? If so, you may check and make sure a piece of trash is not coming in contact with the fan blades. Did it just start doing this .... ?? If so, have you done any engine related mods since it started .. ?? Come back with more info; maybe we can help ..... ![]() humfrz |
#6 |
Drives: 13 FR-S Whiteout 6MT
Sounding like a tractor at idle is normal for a flat engine.
#7 |
Drives: Scion FR-S Hot Lava
does the sound subside once the oil temp reaches average?
#8 |
Cliuless
Drives: Whiteout Scion FRS 2014
Do you hear a singing sound though?
#9 |
So it's not the AC compressor starting and stopping? Need a better description of, "purring" and "hoofing" are new ones on me.
#10 |
#11 |
Drives: 2014 BRZ SWP LTD
Can you mimic the sound and record it using your voice?
#12 |
#13 |
Wayward Member
Drives: Hot Lava 86
Mine has a lot of what I've been referring to as "a lot of belt noise" and depending on the day I'm either concerned or convenience it's just another noise this car makes.
#14 |
Drives: 2013 Firestorm FRS
no one has mentioned crickets?
There must be something wrong with the forum... OP, pretty sure your car is just fine. |
| Tags |
| automatic transmission, engine, noise |
| Sounds better set to TC | Jigglybus | Electronics | Audio | NAV | Infotainment | 3 | 07-19-2014 01:44 PM |
| Normal engine sounds | BrianBlueBRZ | Engine, Exhaust, Transmission | 3 | 06-28-2014 12:49 AM |
| BEST of Start Up sounds!! More than 70 Exhaust Sounds! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 5 | 01-08-2014 02:24 PM |
| it sounds good! | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 08-09-2012 04:46 PM |
| Video: TRD 86 Exhaust and Engine Rev Sounds | tmigo27 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 02-11-2012 06:36 PM |
