Old 08-02-2014, 09:58 PM   #43
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Originally Posted by Infamous Performance View Post
At $300 I hesitate. At $150 I buy. Pricing on FA pulleys is higher than EJ pulleys and it is a production numbers game. So, I would expect up to $250 for a FA pulley (for now).
On my own AT cars I run a LWCP. On my MT cars I run a LWFW.
Car noob, thus so many questions:
What does FA and EJ stand for?? I keep seeing those acronyms being used.
If you were to go with a lightened pully set what would you go for?
WallsAndFoundations is offline   Reply With Quote
Old 08-02-2014, 10:43 PM   #44
gramicci101
Off Topic
They're engine codes. Subaru boxer engines other than the BRZ and the new WRX are EJ engines, with the following number being engine size. EJ20, EJ25, etc. the BRZ and new WRX are FA20 engines.
Old 08-03-2014, 01:16 AM   #45
Boxer486
Drives: small
Originally Posted by Brinks View Post
I've had two lightweight flywheels, one on a 05 20G STi another on a BT Gt28rs Audi A4. Both were terrible. Maybe it was due to the specific set up but they were a buzz kill.
Which brands did you have in particular? Both MT??
Yes. My own AT cars. Due to electronic throttle and tuning there is always a sweet spot for cruising MPG. Find the sweet spot and with a LWCP you can gain 1-2 MPG cruising.
Are you actually determining that using BSFC or guessing via butt dyno? If you have any respective info on the sweet spot of the FA20 feel free to share.
The FA block is similar enough to the EJ. Neither motor has a harmonic balancer. Both motors rely on the small amount of rubber in the crank pulley to absorb vibration. We have already seen internal bearing damage from combining a LWCP and LWFW in the FA motor.
If it's using rubber it may not be a balancer but it is a damper. A balanced damper at that.
I presume all those motors were MT?
Boxer486 is offline   Reply With Quote
Old 08-03-2014, 01:31 AM   #46
litemup
Drives: around
Originally Posted by ZDan View Post
...harmonic damper...
THANK YOU! Jeeeeeezus.
litemup is offline   Reply With Quote
The Following User Says Thank You to litemup For This Useful Post:
kavanagh (09-11-2014)
Old 08-03-2014, 03:11 AM   #47
WallsAndFoundations
Drives:
Originally Posted by carbonBLUE View Post
What about a super damper? @wootwoot
Wuzzat?
:confused::confused::confused:
Old 08-03-2014, 11:36 AM   #48
tennisfreak
Drives: 2018 BMW M240i
I did the lightweight pulley set about 7 months ago.
I got all 3 pulleys (crank, alt, water) for $185 shipped.
I chose this because it was easy to install for me in my garage and did not require any special tools and much simpler than a LWFW.
If and when I go FI I will put my stock crank back on.
Old 08-03-2014, 12:39 PM   #49
WallsAndFoundations
Drives:
How are you liking it? Feeling a difference at all? And if so, what?
Old 08-03-2014, 03:08 PM   #50
Brinks
Brinks's Avatar
ACT StreetLite Flywheel for the STi, im not sure what was in the A4. It was a long time ago and It came with the car. Both were MT, i've never driven an AT with a lightweight flywheel but I can imagine that the drivability is better. I'm not saying that a LWF is terrible all together, its a blast to have in the car for going on drives and makes shifting better, it just gets old fast. Whenever I knew that I was going to have to do a lot of stop and go driving I would try to take my wifes truck. It was that annoying.
I don't care what anybody says. The car was slower from the line after the LWF install. There's a reason why people don't use them for dragracing. If you're planning on taking your car to auto cross then it might be a good install for you. It's going to come down to personal preference its one of those things your either going to love or hate.
Brinks is offline   Reply With Quote
Old 08-03-2014, 03:25 PM   #51
wootwoot
Drives: FRS
Can't put a LWF on an automatic.... They don't have flywheels...
Old 08-03-2014, 04:57 PM   #52
Brinks
Brinks's Avatar
lol right, torque converter. Kinda spaced on that one.
Old 08-03-2014, 08:58 PM   #53
Turdinator
Señor Member
Turdinator's Avatar
LWFW is probably a different beast on boosted motors. On a high comp NA (in my experience) it doesn't take much to get used to.
I really should install mine so i can be specific about one on a FA20.
1974 TA22 Celica
2013 86 GT
Old 08-03-2014, 10:36 PM   #54
Brinks
Brinks's Avatar
Very true both of those cars didn't start to spool till about 3400 , if it wasn't for the money and the pain of install I would try one out on my BRZ. Guess I'll shut up about now Just noticed that none of the downsides of a LWF are mentioned anywhere on the forum yet.
Old 08-04-2014, 11:34 AM   #55
tennisfreak
I like it. Like infamous said if you can get it under $200 then its fine but I would not pay more for it.
I did not notice a big difference just a little quicker to rev than with the stock one on.
Originally I had different plans for my car than I do now and I bought the LWCP set and a TRD intake kit.
Now I have different plans for my car and if I could do it again I would not have done those two mods and saved my ~$550 and put that towards a FI fund.
Old 08-04-2014, 11:36 AM   #56
WallsAndFoundations
Drives:
I can get the crank pulley set for 145.
What would you have used the money for instead man?
Light weight flywheel and crank pulley? wootwoot Engine, Exhaust, Transmission 133 06-23-2015 02:04 PM
Light Weight Pulley's exam2300 Engine, Exhaust, Transmission 18 02-08-2014 01:02 AM
FS:PERRIN Light weight pulley NEW $85 Shipped Amalgamo Engine, Exhaust, Bolt-Ons 1 05-01-2013 12:10 PM
FS - Agency Power Light Weight Pulley Kochinopride Engine, Exhaust, Bolt-Ons 3 11-12-2012 06:32 PM
