Old 07-29-2014, 05:22 PM   #1289
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Originally Posted by chanomatik View Post
How are people going to know where to buy the parts they want? Is it kosher to link other sites from your site?
I think I'll just provide part numbers.
Question now is, do I keep trying to use HTML and expect my excel files to drop in or shall I convert to dreamweaver as a full cms. Ugh
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
chanomatik (07-30-2014)
Old 07-30-2014, 04:39 PM   #1290
bdansingani
bdansingani's Avatar
Originally Posted by illmatic View Post
USDM STI Lip Kit Part Numbers. Installation included in the link below.
http://techinfo.subaru.com/static/whatsNew.html
E5610CA100 - Rear
E2410CA000 - Front
E2610CA000 - Side
Will this STI Lip Kit work for 2013 year model?
bdansingani is offline   Reply With Quote
Old 07-30-2014, 04:40 PM   #1291
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
yes.
illmatic is offline   Reply With Quote
Old 07-30-2014, 05:42 PM   #1292
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Dammit so I ordered the STI short shifter but it's not here yet.
The BRZ technical manual says in order to set the reverse lockout plate, put the shifter into 2nd gear, slip a 1.0mm shim in-between the plate and the shifter and then set the 4 screws. If shifting from 1st to 2nd cannot be done properly, then use a 0.8mm shim instead. Okay so I bought myself a metric feeler gauge and grouped 0.8mm and 0.2mm shims together. Wolf one down.
Then it says I need the following two types of grease:
Permalub ECN-9
Nigtight LYW No. 2
Like where the hell am I gonna find these grease? The Toyota parts counter just gave me a funny look and said "no".
Would SuperLube grease do the job? It's rated for -45F to 450F in temp and it's not petroleum based. Should be okay right?
Then there's the dust boot on the shift fork part I need to figure out. I've already bought a spare washer and cotter pin from Toyota. The STI shifter comes with a new dust boot and said to replace it. This part just baffles me it looks tough.
krayzie is offline   Reply With Quote
Old 07-30-2014, 06:55 PM   #1293
Createddeleted
Careful with the dust boost as I ripped my oem one. It's a simple slide and stretch over.
(Maybe not so simple as I'm telling you to be careful)
krayzie (08-05-2014)
Old 08-05-2014, 09:02 PM   #1294
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
I ordered some stuff from japanparts and FedEx called me asking for a description of the package. Anyone else experience that?
ModalSoul37 is offline   Reply With Quote
Old 08-05-2014, 09:17 PM   #1295
krayzie
Drive From Home
krayzie's Avatar
Okay so you mean i should slide the whole thing to the left first and then stretch it over to uncover the pin?
Old 08-06-2014, 02:03 AM   #1296
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Yep, they just want to make sure of it's contents and whatnot for customs - called me asking what I had ordered and I got a bill a couple weeks later for taxes and duties.
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
ModalSoul37 (08-06-2014)
Old 08-06-2014, 09:55 AM   #1297
Createddeleted
I pulled my boot back towards the rear of the car on the horizontal bar. Once I got it close to position I stretched it over the pin. Pull the pin and remove washer. Then struggle a little to get the two pieces apart. If they get stuck on you, use channel locks to kind of force press it out.
krayzie (08-06-2014)
Old 08-06-2014, 10:24 AM   #1298
krayzie
Drive From Home
krayzie's Avatar
Okay so if I get this straight, first pull the boot towards the rear of the car, then towards the left to stretch it over to expose the pin, then extract the pin and washer. Then, pull the shift lever apart from the fork. Is the dust boot like really stiff to stretch? I'm thinking that's why a lot of people torn it? STI does come with a new boot, I'm thinking maybe just cut the old boot off with a pair of cutters. Then again, I'm worried I would tear the new one while putting it on.
I see on the diagram there are also two plastic collars on the fork that goes into the shift lever, do those slide out or are they stuck to the shift lever during the struggle?
Old 08-07-2014, 12:10 PM   #1299
Createddeleted
Don't cut it off. Use it for practice so you know how it reacts when you work with it.
I would have to look but I believe they are stuck in there.
krayzie (08-07-2014)
Old 08-08-2014, 02:02 PM   #1300
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
and now...here it is...
Trap63 is offline   Reply With Quote
The Following 6 Users Say Thank You to Trap63 For This Useful Post:
chanomatik (08-08-2014), chaoskaze (03-10-2015), Createddeleted (08-08-2014), illmatic (08-08-2014), krayzie (08-08-2014), sprintertrueno86 (08-08-2014)
Old 08-08-2014, 03:09 PM   #1301
inc3pt
Drives: None (yet)
I bought the Bayson R full STI replica kit a few months back (before the Series.blue was announced) to see if I really liked it. I do, and the front lip and rear aprons fit perfectly, but I still haven't got the skirts to sit just right.
I placed an order for the real skirts today and am super excited to get them.
subarugenuineparts.com has a link to the installation instructions, but when I go there, it asks for me to purchase a subscription. Does anybody have the OEM install instructions (hopefully in English)?
inc3pt is offline   Reply With Quote
Old 08-08-2014, 03:15 PM   #1302
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
the color is supposed to be different. matte vs glossy. I could access the instruction manual but it seems it has been disabled by subaru.
Please let me know if you get a copy. Id like to have one as well
hanabie is offline   Reply With Quote
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 06:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 11:30 AM
