#15 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
The u joint is on the driveshaft, not on the axles.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
#16 |
Drives: around
#17 |
Drives: 2013 GBS BRZ Limited
There are 4 CV joints on these cars. One at each end of each rear drive axles.
In the manual they are referred to as "EDJ"s or EBJ (extensible ball joint )In the manual I dont see any bolts on the axles to torque though. |
#18 |
No. I understand what you're trying to say, but a Universal joint and a Constant Velocity joint are not the same. CV (axles): ![]() U-joint (driveshaft):
| The Following User Says Thank You to deucethemoose For This Useful Post: | Muaddib (07-20-2014) |
#19 |
Mentat
Drives: 2013 Scion FRS 6MT
I just ignore it. :p
#20 |
Just turn the radio up, or run a loud exhaust.
#21 |
Drives: SWP FR-S
I also experience this clicking sound. Its usually when I pull out of my driveway. I too am running e85 and other car mods but I have been hearing this click ever since i was bone stock. Maybe its normal?! haha idk
#22 | |
Drives: around
Besides the axle nut, those are the only other axle-related fasteners I see potentially needing to be torqued. But there's no actual torque being applied to that joint. Just a cantilevered load. |
| The Following User Says Thank You to litemup For This Useful Post: | stugray (07-21-2014) |
#23 |
Drives: around
#24 |
Drives: 2014 Pearl BRZ Limited
I took the wheel off again, and re-torqued the 4 'axle bearing housing' bolts, as I only did the axle nut the first time. While down there I re-torqued ALL the suspension bolts as well. Still no change. At this point in time, I am ~%95 sure its the cage in the CV joint. Is it feasible/safe to pull the boot, and check this without pulling the axle?
Probably suffered the same fate as this one..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
#25 | |
#26 |
Drives: around
#27 |
#28 |
Drives: 2014 FR-S Whiteout
Rear brake adjusters for parking brake maybe??? I had a Chevy Impala that did that...
Sent from my iPad using Tapatalk |
| Strange Noise from rear of car while OFF | mike2100 | Issues | Warranty | Recalls / TSB | 23 | 12-17-2014 09:14 PM |
| Rear axle click when entering the car? | kurbkilla | Issues | Warranty | Recalls / TSB | 10 | 07-01-2014 09:38 PM |
| Rear driver side clank and click | spyingwind | Issues | Warranty | Recalls / TSB | 11 | 04-05-2014 12:26 AM |
| click, clank click sounds when cooling down and more? leaking oil? | Boofneenee | Issues | Warranty | Recalls / TSB | 19 | 10-02-2013 12:27 PM |
| Click sound from left rear | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 1 | 09-25-2013 06:58 PM |
