Drives: 2013 scion frs
Running 3000k fog lights?
I installed aftermarket foglights and want to upgrade the halogens to 3000k HID foglights with a 55w ballast. Anyone running this? I've been reading up and got mix reviews on if I need a relay harness or not? Anyone running this setup without a relay harness and have any issues?
#2 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I'm running hid in headlights and in fogs. All I needed was a switch for mine.
| The Following User Says Thank You to Chen For This Useful Post: | 86ING IT (07-16-2014) |
#3 |
Sorry r u talking about the on and off switch designated for the foglights? I'm running HID on my headlights right now but with a relay harness.
#5 |
Truuu
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Using the relay harness as well. Was using HID's but I figure I'd clear up some clutter in my engine bay and just went with these:
http://www.ebay.com/itm/191236634492...84.m1497.l2649 Prefer them so much more over my HID's
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT Build Thread - FA20FAIL Archive |
| The Following User Says Thank You to PineappleFriedRice For This Useful Post: | 86ING IT (07-16-2014) |
#6 |
JHerbert Racing
Drives: 2013 Scion FRS
^I second using the yellow halogens. I'm using the Hella Yellow H11s and they look great, they are cheap (you can get them at pepboys) and no ballasts to worry about.
| The Following User Says Thank You to Takumi788 For This Useful Post: | 86ING IT (07-16-2014) |
#7 |
I strongly recommend switching to a 35 watt kit, especially since you are using them in the fog lights.
55 watt kits generate considerably more heat than a 35 watt kit, and in a smaller fog light housing you are greatly increasing the chances of heat related damage. Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | 86ING IT (07-16-2014) |
#8 | |
#9 |
#10 | |
JHerbert Racing
http://www.ft86speedfactory.com/diod...ghts-1288.html
#12 |
I have 6k 55w HIDs and 3k 35w Fogs. Both are ran on relay harness, the fog ignition switch is triggered from the headlights.
| The Following User Says Thank You to STS-V For This Useful Post: | 86ING IT (07-16-2014) |
#13 |
Drives: FRS
55w hid's are pointless in foglights
#14 | |
Nick C.
| LED daytime running lights | sav | AFRICA | 168 | 03-22-2016 04:26 AM |
| best LED daytime running lights | trigger happy | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 11-15-2013 10:00 PM |
| OEM LED running lights | 5spd | Exterior Parts (Aero, Lighting, Etc.) | 1 | 11-04-2013 08:21 PM |
| Led Daytime Running Lights to Fog Lights conversion? | mfbmike | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-24-2013 07:47 PM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 07:29 PM |
