Old 07-16-2014, 01:40 AM   #1
86ING IT
Drives: 2013 scion frs
Running 3000k fog lights?
I installed aftermarket foglights and want to upgrade the halogens to 3000k HID foglights with a 55w ballast. Anyone running this? I've been reading up and got mix reviews on if I need a relay harness or not? Anyone running this setup without a relay harness and have any issues?
86ING IT is offline   Reply With Quote
Old 07-16-2014, 01:59 AM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I'm running hid in headlights and in fogs. All I needed was a switch for mine.
Chen is offline   Reply With Quote
The Following User Says Thank You to Chen For This Useful Post:
86ING IT (07-16-2014)
Old 07-16-2014, 02:09 AM   #3
86ING IT
Sorry r u talking about the on and off switch designated for the foglights? I'm running HID on my headlights right now but with a relay harness.
Old 07-16-2014, 04:26 AM   #4
Chen
Regional Moderator
Chen's Avatar
Yeah the on off switch.
Old 07-16-2014, 04:33 AM   #5
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Using the relay harness as well. Was using HID's but I figure I'd clear up some clutter in my engine bay and just went with these:
http://www.ebay.com/itm/191236634492...84.m1497.l2649
Prefer them so much more over my HID's
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
The Following User Says Thank You to PineappleFriedRice For This Useful Post:
Old 07-16-2014, 11:26 AM   #6
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
^I second using the yellow halogens. I'm using the Hella Yellow H11s and they look great, they are cheap (you can get them at pepboys) and no ballasts to worry about.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Old 07-16-2014, 12:39 PM   #7
Diode Dynamics
Diode Dynamics's Avatar
I strongly recommend switching to a 35 watt kit, especially since you are using them in the fog lights.
55 watt kits generate considerably more heat than a 35 watt kit, and in a smaller fog light housing you are greatly increasing the chances of heat related damage.
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Old 07-16-2014, 01:34 PM   #8
86ING IT
Nick C.
Anyone here on the forum run into issues with running a 55w foglights ?
Old 07-16-2014, 01:41 PM   #9
86ING IT
Do u have 35w or 55w ballast on Your foglights?
Old 07-16-2014, 02:00 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Nick C.
I purchased your glass fog-light kit. Are 55 watt hella optilux yellow bulb halogens ok for use in these or are we just talking hids here?
http://www.ft86speedfactory.com/diod...ghts-1288.html
Old 07-16-2014, 03:15 PM   #11
Chen
Regional Moderator
Chen's Avatar
35 watt running 6k hids. It's bright as hell. I feel like I can drive without headlights sometimes.
Old 07-16-2014, 03:20 PM   #12
STS-V
I have 6k 55w HIDs and 3k 35w Fogs. Both are ran on relay harness, the fog ignition switch is triggered from the headlights.
STS-V is offline   Reply With Quote
The Following User Says Thank You to STS-V For This Useful Post:
Old 07-16-2014, 03:24 PM   #13
8R6
8R6's Avatar
Drives: FRS
55w hid's are pointless in foglights
8R6 is offline   Reply With Quote
Old 07-16-2014, 05:53 PM   #14
Diode Dynamics
Just talking about HIDs
Nick C.
John C.
Diode Dynamics
LED daytime running lights sav AFRICA 168 03-22-2016 05:26 AM
best LED daytime running lights trigger happy Cosmetic Modification (Interior/Exterior/Lighting) 8 11-15-2013 11:00 PM
OEM LED running lights 5spd Exterior Parts (Aero, Lighting, Etc.) 1 11-04-2013 09:21 PM
Led Daytime Running Lights to Fog Lights conversion? mfbmike Cosmetic Modification (Interior/Exterior/Lighting) 1 08-24-2013 08:47 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
