Old 07-12-2014, 03:14 AM   #1
Sailors14FR-S
Sailors14FR-S's Avatar
Drives: 2014 Scion FR-S
need help, trunk problem!!!
Hey so I can't open my trunk with the FOB or the button in the car? The key and the emergency latch work fine... what should I be looking for? Fuse? Wiring?
Thanks for any help!
Sailors14FR-S is offline   Reply With Quote
Old 07-12-2014, 03:16 AM   #2
OmarYasin
OmarYasin's Avatar
Open trunk. Left side of trunk is a small button. Push that button-omar
OmarYasin is offline   Reply With Quote
The Following User Says Thank You to OmarYasin For This Useful Post:
Sailors14FR-S (07-14-2014)
Old 07-14-2014, 01:55 PM   #3
Sailors14FR-S
Thanks brother, worked!!!
Old 07-14-2014, 02:22 PM   #4
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
http://www.ft86club.com/forums/showp...01&postcount=2
I'm sure we'll all hit this button at some point. It's good to know about it.
Tank is offline   Reply With Quote
Old 07-14-2014, 02:44 PM   #5
Lonewolf
Lonewolf's Avatar
Drives: Moped
I don't know why this isn't a sticky...seems like a new post is started about this every few months
Old 07-14-2014, 03:09 PM   #6
martinEZ
martinEZ's Avatar
yea I always have something in the trunk that slides and presses it...
someone should fab a little cover for it...
martinEZ is offline   Reply With Quote
Old 07-14-2014, 03:10 PM   #7
OmarYasin
OmarYasin's Avatar
Mine is disconnected at the pigtail.
Old 07-14-2014, 03:16 PM   #8
sklimo
@Guff. Can we get this sticky'd please??
Old 07-14-2014, 03:32 PM   #9
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I had my switch disconnected when I was fixing tail light leak and it acted like the button was pressed, I had to reconnect the button and leave it hanging (trunk panel was removed) just to keep normal access to the trunk.
Target70 is offline   Reply With Quote
Old 07-15-2014, 02:18 AM   #10
extrashaky
Drives: 2014 BRZ Limited
Can you not just jump the connection with a paper clip to close the circuit and wrap a slice of electrical tape around it? (This is how Jeep guys fix the door control lockout button when it fails.)
Old 07-15-2014, 02:23 AM   #11
OmarYasin
OmarYasin's Avatar
Press button to lock?? Then disconnect
Old 07-15-2014, 04:28 AM   #12
Target70
Target70's Avatar
I am sure you can short/jump it, I just found it strange that it worked for OmarYasin but It worked the opposite for me.
I think most of the sensor inputs are normally closed on this car, and the buttons open them. I unplugged my drivers seat belt sensor planning to jump it so it wouldn't ding at me every time I start the car (to let the idle settle) before I fasten my seat belt, and just by unplugging it, it thinks the seat belt is always fastened. Got the same thing on the trunk switch, unplugged it, and it thought it was always pushed, and the same thing on my door switch, unhooked it to cancel the window indexing, and now it thinks the door is always closed, instead of always open.
but back on topic, a small piece of sheet metal, or even cardboard folded into a shallow open top box should slide over the button and fit flush with the panel to keep the button from being pressed by accident.. I've had it happen a few times to me too.
Old 07-15-2014, 02:07 PM   #13
OmarYasin
OmarYasin's Avatar
What I did is activate the switch then disconnect and it worked for me
Old 07-15-2014, 02:33 PM   #14
PMPB
Drives: BRZ Sport-tech
It's probably a momentary switch with a code stored in the security module?
PMPB is offline   Reply With Quote
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 10:36 PM
Zeta & Carsmo Armrest, Weathertech front and trunk mats, OEM scion trunk carpet HighbreadEH3 Interior Parts (Incl. Lighting) 16 07-29-2013 11:42 AM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 03:12 PM
WTT Raven FRS wingless trunk for your Black BRZ limited spoiler trunk Tylub Exterior Parts (Aero, Lighting, Etc.) 0 05-12-2013 09:21 PM
