View Poll Results: Is bigger ALWAYS better??
17in 121 69.94%
18in 49 28.32%
Other 3 1.73%
Voters: 173. You may not vote on this poll
Old 07-13-2014, 05:56 PM   #29
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
A "little" stretched ... lol
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 07-13-2014, 06:05 PM   #30
aLaFleur
Originally Posted by k.houan View Post
Interesting.. Have a shot of em mounted?
Yep, little. Guess I keep missing out on the jokes.
@ashtonlafleur
aLaFleur is offline   Reply With Quote
Old 07-13-2014, 06:08 PM   #31
Best way to ruin rims .... stretching tires like this ^^^^
Old 07-13-2014, 07:07 PM   #32
aLaFleur
Just the rim or the whole wheel?
@ashtonlafleur
Old 07-13-2014, 07:12 PM   #33
Depends on how much you drive. You have zero room for error. The sidewall provides no stiffness at that angle. You are purely relying on tire pressure to save your rims.
Old 07-13-2014, 07:18 PM   #34
aLaFleur
Ahh I see. Thanks for clearing that up for me. Going out tomorrow and buying some wider tires. Don't want to mess up the rim of my wheel.
@ashtonlafleur
Old 07-13-2014, 11:49 PM   #35
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
If I was doing it all again I'd be putting on 17's
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 07-14-2014, 01:28 PM   #36
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm currently on 18" but if I change wheel again on this car I'll be going with a lightweight 17" like the Wedsport TC105N with meaty tire
Fizz is offline   Reply With Quote
Old 07-14-2014, 08:13 PM   #37
Ubersuber
Drives: BRZ Pearl White
Stock tires fit on 17x9 wheels??
I wouldn't.
Matching tire section width to rim width is important to get the best out of your tires on corners.
Wide rims aren't necessarily better handling rims unless you fit appropriate section tires.
8.5 x 17 is the largest wheel you should use for a 215 section tire, 7.5 inch is probably ideal. Go up to 225/45x17 and 9x17 would work but I'd still fit no more than 8x17 myself.
Ubersuber is offline   Reply With Quote
Old 07-15-2014, 01:08 PM   #38
tomkozski
Drives: 2017 WRB BRZ w/ PP
Originally Posted by Ubersuber View Post
I wouldn't.
For most 215 tires, 8" is the max safe width. Per Michelin, the safe rim width range for the OEM Michelins is 7-8".
tomkozski is offline   Reply With Quote
Old 07-15-2014, 02:25 PM   #39
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I autoX pretty regularly as well as DD my BRZ.
I chose 17x9 TC105N for their weight. The size tire I can use. With a 17" tire I can put on a larger sidewall and mitagate some of the negative affects of my suspension set up in terms of ride comfort.
Old 07-15-2014, 02:30 PM   #40
CSG David
CSG David's Avatar
17s for performance, 18s for looks. Forged 18s are acceptable though.
The Following User Says Thank You to CSG David For This Useful Post:
Mad1723 (07-25-2014)
Old 07-20-2014, 01:30 AM   #41
reardrv
Drives: 2013 Subaru BRZ
22's kid, 22's!
reardrv is offline   Reply With Quote
Old 07-25-2014, 04:13 AM   #42
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Forged 16"
WTT: Work Meister SP1 3pc 18in/8.5/+48 JCORP Wheels and Tires 22 03-24-2014 09:56 PM
Forgestar F14(18in 5x100) & Michilin Pilot Super Sports to fit Jared0934 Wheels and Tires 7 09-06-2013 10:43 PM
FS [WA] 17in GTS rims PLUS 17in GTS rim + tyre stevo_12v Australia Classifieds 12 10-20-2012 11:59 AM
