#1037 |
Off Topic
I know Antigravity batteries were swelling due to undercharge or overcharge conditions (link, post 10). They're also LiFePO4, although they have different internal construction than the Shorai batteries. Is there a battery management system that would regulate the charge and discharge of your battery to ensure it didn't exceed specifications? Is it even necessary with Shorai batteries?
#1038 | ||
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Some good info about Lithium Iron batteries and their safety/durability. All the reviews from customers in that thread have been overwhelmingly positive from both track and DD street applications; even with underdriven alternators via aftermarket pulleys. Last edited by ATL BRZ; 07-08-2014 at 03:45 PM. |
#1039 |
I've just been invited to instruct with Just Track It for their upcoming 7/26 event at Atlanta Motor Speedway around the road course configuration!
![]() The road course has been rarely used for HPDE's over the past several years but this will be both JTI's and my first time running it. I'm pretty excited to get to experience the banked NASCAR turns. It will be like a mini-Daytona
#1040 | ||
Drives: 92 NSX
Just grab a "Battery Tender" brand tender, they're pretty cheap, and if you let the car sit for over a few days, just hook it up. I've found that the FRS/BRZ's limit for sitting is about a week. Quote:
#1041 | |
I checked it out and it looks like it has specialized connectors and features that are worth it. Last edited by ATL BRZ; 07-09-2014 at 02:20 PM. |
#1042 | |
Drives: Black BRZ
I highly recommend picking up the shorai charger to be safe. It has two modes - one for charging and one for storing the battery. The nice thing about the charger to is that you don't have to hook it up to either of the leads. It simply plugs in the socket between the two leads. |
#1043 | |
#1045 |
Before and after engine bay pics.
![]() ![]() The stock battery looks HUGE now! |
#1046 |
Just a dude
Drives: Scion FR-S 2013
Sure does what a difference wow.
#1047 |
Off Topic
There's a whole lot of room where the intake used to be. A supercharger would fill that space nicely. Just saying...
#1048 | |
![]() Now accepting donations! ![]() I really want to finish off this season with the engine still NA and explore the limits of this new suspension and brake setup. Next year I may be ready to pull the FI trigger. |
#1049 |
Snow Don't Hurt!
That's the way to do it. So many people just throw EVERYTHING on the car as soon as possible, never quite learning it or appreciating each piece purchased. I've always been leery of the idea of purchasing a bunch of suspension parts all at once and installing them. I've always wanted to just piece it out by installing and playing with it for a couple hundred miles at least before doing the next piece.
Unfortunately it costs money to have parts purchased and installed or you need the time/opportunity to learn to install them yourself. I've swapped coil overs several times on other Subies, so I'm thinking I could do that, but I just don't know about control and trailing arms and such. Those seem like a PITA to install. |
#1050 | |||
I want to use the track time I'm getting wisely and really get the car behaving just the way I want it, knowing in the back of my mind that more power through FI is possible. Quote:
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
