Old 07-07-2014, 04:02 AM   #141
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by MemphisR View Post
Did you find a way to make the blade on these not so wobbly?
Thanks,
Memphis
I used clear scotch tape like in this video. [ame="https://www.youtube.com/watch?v=KlmjV7oRvlA"]Toyota Flip Key - www.duplicatekeys.in - YouTube[/ame]
Originally Posted by j2digit View Post
I see the lock and unlock buttons but where is the buttons for panic and the trunk?
Thanks
They're hidden under the cloth wrapped around the fob, I can take it apart and show you pictures if you'd like.
The Following 2 Users Say Thank You to ZOMFGAARON For This Useful Post:
j2digit (07-08-2014), XxFooManDrewxX (10-20-2015)
Old 07-07-2014, 04:17 PM   #142
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
@ZOMFGAARON I have heard of this method, but it is no the blade in the part that rotates, but rather the part that rotates has a bit of wobble.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
The Following User Says Thank You to MemphisR For This Useful Post:
Old 07-28-2014, 08:08 PM   #143
Hillermi10
Drives: Hot Lava
does anyone know where I can get a scion logo emblem on the back, thanks!!!
Hillermi10 is offline   Reply With Quote
Old 08-31-2014, 05:51 PM   #144
Synack
Boosted
Synack's Avatar
Drives: Sideways
Took a lot of BS work to get the transponder out. The hammer and razor did the most work, just had to be SUPER careful. Transponder circled in red.
I bought the white flip case to match my car.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 01-26-2015, 09:56 PM   #145
StreetShotz
Drives: 2015 FR-S
If you want to save yourself the valet key just go and get a blank key from a lock smith or from Toyota that has a transponder (not buttons) and get them to program it but not cut. Then you can keep the valet keys, and the cases for your stock keys.
StreetShotz is offline   Reply With Quote
Old 03-29-2015, 03:18 PM   #146
ovnisf
Drives: tC
The transferring of remote onto a flip shell is usually bulky. The last flip shell posted with the fake leather has been the most reliable one used in my shop Until i started using the flip keys with custom circuit boards. Much better quality. Below shows cheap shell you transfer remote into and a custom board above.
ovnisf is offline   Reply With Quote
The Following User Says Thank You to ovnisf For This Useful Post:
Avo1789 (03-30-2015)
Old 03-30-2015, 07:58 PM   #147
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Is this DIY-able? If so how is it done?
Sent from my SCH-I545 using Tapatalk
Avo1789 is offline   Reply With Quote
Old 04-01-2015, 01:13 AM   #148
ovnisf
Drives: tC
No. It's 100% new designed board tweaked to the frequency of certain toyota/Lexus vehicles. Has Toyota logo on the back. You can placed a blank chip or an already programmed one.
Old 04-01-2015, 12:21 PM   #149
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Seems expensive.
Old 07-09-2015, 03:31 PM   #150
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
I just did this with the newer style keys. Super easy
tumbla.jr is offline   Reply With Quote
Old 08-10-2015, 07:02 PM   #151
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Oh crap. I've spent a couple of days looking up this stuff and realized I have a newer style key as well.
So does that mean I'm out of luck for the shell style that everyone else is using? I really like those.
Also, where'd you get your shell?
Devante is offline   Reply With Quote
Old 08-10-2015, 10:09 PM   #152
tumbla.jr
taicho
tumbla.jr's Avatar
If your key is exactly like mine than the older style will not work.
I purchased my set from amazon. Not the cheapest place but I received them fast.
[ame="http://www.amazon.com/Keyless-Switch-Folding-Remote-Toyota/dp/B00JX5PVUM/ref=sr_1_8?ie=UTF8&qid=1439255309&sr=8-8&keywords=toyota+key+fob+flip"]Amazon.com: Keyless Entry Switch Folding Flip Blank KEY Case Shell Remote KEY Blank for Toyota Camry 2012 2013: Automotive[/ame]
Old 08-11-2015, 07:06 AM   #153
Max FRS
Drives: 2015 Halo FRS Automatic
I converted both of my remote keys to flip keys like shown in tumbla.jr's post above. I took the new flip-keys to a locksmith who charged me $2.00 per blank to make my keys. Well worth the price and both keys work great. The locksmith had to remove a pin holding the key blank in the flip-key. He removed the flip-key blank, cut it and reinstalled it into the flip-key all for $2.00. The hardest part is digging the transmitter out of the Scion remote keys. There is a little cut out section in the flip-keys to put the transmitter into. I am satisfied with my flip-keys, been working great for almost a year.
Max FRS is offline   Reply With Quote
Old 09-23-2015, 01:24 PM   #154
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
Yes I'm that guy reviving a 3 year old thread. I bought a flip key case off eBay for 10 bucks. Cracked open one of my keys....pulled transponder chip and the rest of the guts and transferred it over. Went and got key cut at locksmith which was damn near perfectly cut. Put key all back together and put in ignition and it starts to fire up then just quits. I'm assuming it's something to do with the transponder chip? I used a heat gun to get it loosened enough to pull out of original so is it possible the heat was too much for it? I thought I used it very carefully as to not damage it but does anyone else have any ideas?
Edit: nevermind, people just posted in here so I'm not a total Asshole.
cdq85 is offline   Reply With Quote
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 07:27 PM
BRZ HIDs vs FR-S HID Conversion DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 37 06-28-2012 06:20 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 03:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 09:44 PM
