Yet another Mtec shift Springs review
Well here's another review. Yesterday I tackled the whiteline positive shift kit and the perrin shifter bushing. Today was the Mtec shift Springs.
These were pretty straight forward as all you had to do was first take off the undertray. Once removed, located a 10mm hex bolt thingie on the driver side of the transmission near the rear of the transmission . Remove the bolt, use a magnet to get the spring out of the slot and replace it with the matching Mtec spring. Retorque the bolt. Next locate the 27mm / 1"1/16 Nut on the passenger side near the rear of the transmission and remove it. Once again I was doing this on my back with 2 jack stands. This bolt comes factory sealed with a boat load of lock tight. And let me tell you this thing took a heap ton of force to break it loose. I meen I struggled being on my back on the garage floor. Once out, replace the spring with the matching mtec spring and Retoque. Driving impressions. This little mod I'd absolutely amazing. It completely changes the shifter feel In a great way. It springs right where you want it to with little effort but with authority! My favorite mod so far. Highly recommended for 30$ Sent from my SGH-I337M using Tapatalk |
#2 |
When In Doubt...
Drives: Slowww
Perfect, I just logged in so I could read some review on these. I bought them recently and realized I may want to read reviews prior to installing.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#3 | |
Drives: 2015 WRX
DO NOT try to put the right side bolt back in with a ratchet. I repeat, DON'T use a ratchet at first! You need to get it hand threaded first! Make sure the transmission is in neutral before you take those bolts out as well. There have been many cases of people getting impatient and having it cross threaded, only to have to have their car flat bedded to a dealership for a new transmission housing. Take your time and get it hand threaded and everything should be fine. |
#4 |
driving smoother faster
Drives: Sold
I had mine installed recently and prefer the shifter feel with them. Also have heavier raceseng shift knob.
#5 | |
When In Doubt...
Drives: Slowww
I did read about this issue soon after and got a bit worried. How tough do you reckon the job would be on a lift? I heard that 27mm bolt is tough to open up because of the loc-tite as you mentioned and can only hope a lift would make it a bit easier.
#6 |
I would recommend you remove your front pipe. Makes the install much easier.
#7 |
Drives: Sci FR-S, Fer F355, Toy Highlander
The bolt threads were leaking tranny fluid onto exhaust and causing smoke and stink. Toyota sealed the threads and now no more stink and leak. Love the mtec shifter springs.
#8 | |
#9 |
Drives: 2013 DGM BRZ Limited (M/T)
probably dumb question... but
do you get void on warranty if you install mtec shifter springs? |
#10 |
Drives: '18 STi
#11 |
Drives: '18 STi
this thread makes me excited for my Kartboy Short Shifter kit with MTECT Springs that I will be receiving by the end of the week!
#12 |
If you got the spring and shifter. Might as well and go all out. Trans stay bushing/forced fab stiffener ,rear stay and front carrior bushings.
| The Following User Says Thank You to Brinks For This Useful Post: | SirBrass (07-10-2014) |
#13 |
As far as the springs go. Good bang for the buck, gives the shifter some weight while smoothing it out.
Make sure you have a breaker bar and a 27mm socket before you start the install |
#14 | |||
Drives: 2015 WRX
![]() You don't have to get it all off, just enough to where you can get it hand threaded a couple of turns so you don't risk stripping it out. You'll notice on the picture that the threads start at the bottom on mine. You can look at yours and see where the threads start and position the threads on your bolt to help you get it positioned to where you can get it threaded. Then again, it might thread right up and you won't have any of the issues I had. Quote:
The transmission stay bushing I'm sure adds more feel and I have one as well, I just haven't installed it yet as I don't want anymore driveline noise in the cab. An aluminium 1 piece driveshaft added to the positive driveline feel but it definitely adds noise and vibration on decel and low speed operation. If I could do it all over again I'd do the MTEC springs, kartboy shifter with rear stay, carbon driveshaft over the aluminum. I've heard that the carbon shaft helps a ton with noise and vibration and that alone would have been worth the extra $500 to me. The performance improvements from a smaller diameter shaft and the inherent damping from the carbon shaft seem to be totally worth it. Heck, I might even swap to one and sell my aluminum shaft. Last edited by Malt; 07-09-2014 at 09:44 AM. |
| MTEC shift springs | grostoine | Engine, Exhaust, Transmission | 116 | 03-30-2016 10:42 PM |
| Mtec Shift Springs 36 shipped. | Mr. | Transmission and Driveline | 8 | 02-28-2014 11:44 AM |
| WTB MTEC shift knob | Vlady | Want-To-Buy Requests | 0 | 02-09-2014 06:24 PM |
| FS: MTEC Drift Shift Knob - SOLD | Purity999 | Interior Parts (Incl. Lighting) | 4 | 01-06-2014 04:59 PM |
| MTec Industries Shifter Springs | xravexboix | Transmission and Driveline | 2 | 04-24-2013 01:39 PM |
