Old 07-01-2014, 10:23 PM   #4943
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DriftEm View Post
I'm running a Perrin, fits with no issues.
thanks. just to verify, you're intercooled right?
Old 07-01-2014, 10:25 PM   #4944
DriftEm
DriftEm's Avatar
Here is a picture of Perrin heat exchange core installed, this is before the Innovate IC was installed but you get an idea of fitment:
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
xjohnx (07-01-2014)
Old 07-01-2014, 10:28 PM   #4945
DriftEm
DriftEm's Avatar
Yes, I got IC
Old 07-01-2014, 10:43 PM   #4946
Ethan
Drives: Subaru BRZ
I am running the Robispec Total Cooling Solution which integrates the oil cooler into a larger radiator. I am also running an intercooler. No fitment issues.
Ethan is offline   Reply With Quote
Old 07-01-2014, 10:50 PM   #4947
xjohnx
Grip>Slip
xjohnx's Avatar
thanks. looks like i may have to slightly relocate my radar detector's antenna, but that's no big deal. already repacked everything and have my amazon return being processed, we'll see how quick that is. i'll probably go ahead and order the perrin tomorrow anyway.
Old 07-01-2014, 11:14 PM   #4948
xjohnx
Grip>Slip
xjohnx's Avatar
yeah, i looked into that (and almost bought @civicdrivr's) but the stock fan shroud/fans wouldn't fit, among other issues/missing pars that robi didn't ship. by the time i added a fan shroud and fans, it got expensive in a hurry.
Old 07-02-2014, 12:52 AM   #4949
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Had a slight problem today. Noticed a vacuum leak and when I got home, decided to take apart my catch can and hoses to clean and find the source
In the process I accidentally pulled off the crankcase breather line from the block and here's what I found
Is there supposed to be oil just sitting there like that on this engine? Anyway I noticed the dirty side line that goes into the catch can is always saturated with oil, and the clean side is nice and clean, but there's never any real accumulation in the can.
So what am I missing here?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 07-02-2014, 07:50 AM   #4950
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Really? I had to bend the intercooler brackets to get the heat exchanger to fit. Otherwise it was hitting the bumper beam.
Old 07-02-2014, 08:43 AM   #4951
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm using my stock fans on my Robispec radiator. .
Old 07-02-2014, 09:22 AM   #4952
xjohnx
Grip>Slip
xjohnx's Avatar
maybe his didn't come with brackets? It was probably 8-9 months ago when we tried to install it. @civicdrivr - do you remember?
Old 07-02-2014, 09:29 AM   #4953
Draco-REX
Corner Junkie
Draco-REX's Avatar
I just looked under my hood and the stock fan assembly bolts right up to the radiator. I bought mine a little under a year ago.
Old 07-02-2014, 09:49 AM   #4954
swift996
swift996's Avatar
I ran the Mishimoto radiator (stock fans clip right on), Innovate heat exchanger, and Perrin oil cooler without and issues:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-02-2014, 10:07 AM   #4955
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yea, the stock fans were hitting the hose bungs. We'd have to either trim the fans a lot, or just run aftermarket fans.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-02-2014, 10:33 AM   #4956
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'll take another look later. I was lazy and had my friend's shop put it in, so I don't know if they had to trim the shroud or not. It wasn't evident on my quick look earlier.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
