Old 07-01-2014, 02:57 PM   #4929
DriftEm
DriftEm's Avatar
Been driving around with Delicious Tuning 8.59 tune for a few days now. Partial throttle now is very smooth and no hesitation anymore. I love the new throttle maps, map 1 (daily) is great for normal driving and map 4 (extreme) is just insane Thanks Bill
DriftEm is offline   Reply With Quote
The Following 2 Users Say Thank You to DriftEm For This Useful Post:
Dustin (07-01-2014), whataboutbob (07-01-2014)
Old 07-01-2014, 03:00 PM   #4930
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I just switched back to 93 last night. Very smooth on 8.59. Miss the power of E85 though, lol. Still really good on 93 though.
Dustin is offline   Reply With Quote
Old 07-01-2014, 03:35 PM   #4931
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
Are you spinning 1st and 2nd gears until you hit 3rd? Sounds like it. Nice.
Cheers,
William Knose
It definitely spun quite a bit there, I think it was mostly from the shift, but it certainly didn't do it to that extent on any of the previous tunes. I am running some sticky 245's (Yokohama AD08R's), too.
Oil cooler comes in today, going to make some kind of heat shield for the header, then it's dyno time.
DeliciousTuning (07-01-2014)
Old 07-01-2014, 03:37 PM   #4932
Dustin
Twin Screw You
Dustin's Avatar
Originally Posted by xjohnx View Post
I am running some sticky 245's (Yokohama AD08R's).
How do you like these? They are what I'm considering getting here fairly soon. I need something because my tires are crap and I get no traction and am afraid of losing grip at a most inopportune moment, lol.
Old 07-01-2014, 03:38 PM   #4933
xjohnx
Grip>Slip
xjohnx's Avatar
LOVE them. I was running Continental ExtremeContact DW's before, and these are much better in almost every regard.
Dustin (07-01-2014)
Old 07-01-2014, 08:06 PM   #4934
xjohnx
Grip>Slip
xjohnx's Avatar
are any of you guys running the mishimoto oil cooler and the Innovate intercooler? i'm going to be installing it tomorrow and want to make sure everything fits. @Mishimoto - can you confirm?
Old 07-01-2014, 08:08 PM   #4935
whataboutbob
AutoX-10/10ths every run
My mishi won't fit as the mounting bracket for the oil cooler conflicts with the upper edge of the innovate IC. If you can get yours to work I'd be interested to see how.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 07-01-2014, 08:18 PM   #4936
xjohnx
Grip>Slip
xjohnx's Avatar
Crap, that's what i was afraid of. did it look like it was close to fitting? or was the fit a mile off? No chance @Mishimoto wants to use my car at mishifest to fab up a bracket for us innovate guys, is there?
thankfully i bought it through amazon prime, so if it doesn't work out i shouldn't have any problem returning it.
Old 07-01-2014, 08:20 PM   #4937
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Its pricey, but what about the HKS oil cooler?
I am not exactly sure how the Innovate IC is mounted, but would this conflict?
The Following User Says Thank You to tahdizzle For This Useful Post:
Old 07-01-2014, 08:23 PM   #4938
whataboutbob
I've already modded my AN10 lines to have a 90 deg elbow instead of the 45 deg ones, but even with that the mounting bracket will need to be moded IMO. It is designed to fit behind the crash bar and use the plastic clips on top of the crash bar to hold it on, you can't get it behind the crash bar with the clip holes lined up with the IC mounted.
I've drilled the clip holes all the way through the crash bar so that they are in the same position on the bottom, and was planning to get some longer bolts and some nuts to hold the mount on, but the stack height of the oil cooler mount is too tall and would need to be cut down by the thickness of the section of the crash bar that the mounting bolts would feed through.
Hope this helps/makes sense. I'm not sure what I am going to do with mine at this point.
Build thread:Here
Old 07-01-2014, 08:23 PM   #4939
whataboutbob
That would work, and I may try to get some longer AN10 lines and put my mishi core over there.
Build thread:Here
Old 07-01-2014, 08:49 PM   #4940
xjohnx
Grip>Slip
xjohnx's Avatar
yeah i think i may just return it. is anyone here running the perrin cooler?
Old 07-01-2014, 09:03 PM   #4941
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Not running Perrin, but running a custom order from Mocal with all the same parts and it fits perfectly.
Only thing I'm missing is the fancy mounting brackets, which means mine mounted about 5 mil further back.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 07-01-2014, 10:12 PM   #4942
DriftEm
DriftEm's Avatar
I'm running a Perrin, fits with no issues.
The Following User Says Thank You to DriftEm For This Useful Post:
xjohnx (07-01-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
