Old 06-26-2014, 05:19 PM   #99
fredfromnh
Drives: 2013 scion frs
Only thing I notice is that the car hates humidity. Did stock as well.
fredfromnh is offline   Reply With Quote
The Following User Says Thank You to fredfromnh For This Useful Post:
Project_1796 (04-14-2021)
Old 06-26-2014, 09:17 PM   #100
fredfromnh
These cars suck off the line. Consistency is difficult to find. My friend watched a guy at his local track do 4 runs which ranged from 14 flat to 14.6. Sounds like a healthy na tuned car.
Old 06-27-2014, 06:10 PM   #101
fredfromnh
Break the wheels loose with a hard launch and the little bastard shoots right to the shift light. Header and bigger gears to slow wheel spin are next. I will have a 13 second na car if it kills me. Consumer reports killed these cars on reliability. I would suspect mostly small crap. Squids have been complaining to toyota because they run slower with a full tank of gas. Smart.
Old 06-27-2014, 06:35 PM   #102
fredfromnh
Weight and friction need to be addressed as well. For a low priced sports car these things attract attention. I've been thinking about cutting air box resonator and rigging garbage ebay esc to blow air in there. Who knows?
Old 06-27-2014, 06:47 PM   #103
fredfromnh
Anybody use bigger gears? Worth it?
Old 06-27-2014, 07:08 PM   #104
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I'll address your three posts here. This car will benefit more on the launch from suspension and wheel changes that 30hp or even 50hp. Cutting the resonator will do more harm than good as @GRimSpeed's testing has shown that it is super well designed with the stock airbox, better than anything aftermarket. I believe either they or Cosworth claim that it makes +3hp and is good for 300hp. The "esc" would be a massive waste and an addition of weight unless you make your own proper supercharger or get the phantom setup. If by "big gears" you mean numerically higher with lower overall gearing, yes, it will make the car peppier and there are several people on this forum that have swapped gears.
Luckrider is offline   Reply With Quote
Old 06-29-2014, 04:21 PM   #105
Corradooo
Corradooo's Avatar
Drives: Storm trooper FRS
so heres my question about the BPBs and e85.
You said there is still a bump in power, but people who primarily use e85 may not like to loss up top usually found with e85.
do you still have a gain from the use of e85, but just not as significant up top as it may have been? is the power shifted over so it is felt lower in the rpm range?
I've never run e85 before, and I'm running the BPB stage 2 beta tune. if i filled up with e85 and ran the car on the BPB tune would i feel an increase anywhere? would I have to run the stg2 e85 tune and then not have the power from the BPBs?
there really hasn't been a clear answer regarding e85 full bolt ons and the power blocks.
If there is power gained anywhere and there isn't an actual huge power loss, and maybe just not as much a gain as expected in only the top end, it still seems like e85 would be beneficial, and I may want to try it out, but it seems like I'm stuck in between tune files, as theres nothing even in beta for stage 2 e85 with BPBs.
any plans on releasing?
Corradooo is offline   Reply With Quote
Old 06-29-2014, 04:38 PM   #106
Corradooo
Corradooo's Avatar
http://www.ft86club.com/forums/showthread.php?p=1784979
The Following User Says Thank You to Corradooo For This Useful Post:
jliongh (10-02-2016)
Old 07-24-2014, 12:51 PM   #107
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Just got this setup installed. AWESOME. Running the BPB (which I installed alone in 45 minutes by the way) with the "Beta" stage 1 tune from the website.
@Shiv@Openflash should I be taking data logs and sending them to you, being that it's still in "Beta"?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-24-2014, 12:56 PM   #108
Corradooo
Corradooo's Avatar
I've been running power blocks and stage 2 e85 for 800 miles now, including autoX, and I'm driving 4 hours to button willow Saturday and back and so far it's performed flawlessly, and I expect no issues, it feels better than the BPB beta map felt in my opinion
Old 07-24-2014, 07:55 PM   #109
wooly35
Drives: 2014 Scion FR-S LS3
Just want to make sure i read this right, you are running BPBs on the stage 2 E85 tune? or just switching between the two tunes? Im curious because i am running e85 and have been thinking on getting the BPBs.
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Corradooo (07-24-2014)
Old 07-24-2014, 09:56 PM   #110
Corradooo
Corradooo's Avatar
I'm running the BPBs, and e85, at the same time, for over 800 miles, using the stage 2 e85 map, and felt a difference in power over the BPBs on 91 pump gas using the BPB stage 2 beta map
Old 07-24-2014, 09:56 PM   #111
Corradooo
Corradooo's Avatar
Yes
Old 07-25-2014, 06:59 AM   #112
wooly35
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 04:19 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Tales from the Dyno: UEL E85 power Shiv@Openflash Engine, Exhaust, Transmission 20 01-20-2016 09:58 AM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
