Old 06-24-2014, 07:42 PM   #1
SunkenFRS
Sideways & Smiling
SunkenFRS's Avatar
Drives: 2013 Raven FRS
Convert NA FA20 to FA20DIT in the WRX
Is this possible? I know anything is possible with money but would it be cost effective and could it be done easily. I haven't really seen anyone on here actually go into an in-depth conversation about it. Heres some comparison pics. Right away i notice the exhaust manifold comes out the other side, there could be a conflict with top mount and the suspension bracing. Just wanting to have a conversation about it.
2013 Raven FR-S
Flossy - Fortune Auto - ESM - Project Kics - Borla - Berk - TRD - HT Auto - Winjet - P3 - Koyo - CarolinaDyno - Mocal - FIC - FBM
SunkenFRS is offline   Reply With Quote
Old 06-24-2014, 08:00 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
While the idea is not horrible... its your money.
The best thing about the fa20dit in the WRX is that its a factory turbo.
If you just wanted to slap on a twin scroll turbocharger on it, a custom kit would probably be cheaper.
The Following User Says Thank You to tahdizzle For This Useful Post:
hmong337 (03-15-2015)
Old 06-24-2014, 08:00 PM   #3
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
The manifold and turbo might fit, depending on clearance from the rad. The TMIC would never fit under the hood of an 86. You would need to make your own FMIC setup. I can't really tell, but is there an oil pump on the back of the passenger side cam like the AVO kit?
It might be worthwhile to start checking to see if oil pan P/N's match up also.
The front of the DIT looks way cleaner without all those idlers to route the belt away from the throttle body inlet
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-24-2014, 08:32 PM   #4
xwd
It has been brought up in depth a few times. I can't seem to find the main thread though, it's very old at this point.
The 20DIT is meant to attach to an AWD Subaru transmission so the bell housing is different, and the starter is on the other side of the motor. It looks like there is a place on the FA20 block where you could machine it out and attach a starter but it would take some work.
It's definitely not worth the time and effort. You'd be much better off buying a FBM shortblock and slapping on one of the FI kits.
The Following 2 Users Say Thank You to xwd For This Useful Post:
AJPG (06-24-2014), Sportsguy83 (06-26-2014)
Old 06-24-2014, 08:56 PM   #5
BadBRZ
Drives: Subaru
THe major difference between the FA20DIT and FA20DI is the turbo (obviously) starter placement (driverside on turbo passenger on ft86) and compression (10.5:1 vs 12.5:1)
there are other differences but to answer your question, yes its possible, not it would not save you any time or money to do this. If factory subby is what your after go AVO, if cheap is your route, go SBD (they ripped off greddy so its really inexpensive)
BadBRZ is offline   Reply With Quote
Old 06-24-2014, 10:48 PM   #6
protpibe
protpibe's Avatar
What about mounting the FA20DIT manifold onto the FA20 block? Not sure how the overripe would clear the steering rack/column, but there are RHD 86's that have to deal with that
Old 06-25-2014, 12:33 AM   #7
BadBRZ
Drives: Subaru
Still be cheaper to get the avo kit
Old 06-25-2014, 12:34 AM   #8
BadBRZ
Drives: Subaru
Plus the downpipe goes over the wrong side of the suspension
Old 06-25-2014, 12:48 AM   #9
Harinjo
Harinjo's Avatar
Dit has only di injectors
Harinjo is offline   Reply With Quote
Old 06-25-2014, 11:38 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You forgot the fuel injection system. The FA20 uses the Toyota D4-S with port and direct injection. The FA20DIT uses Subaru's direct injection only setup. I think the FA20 fuel injection system is superior.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
aagun (03-16-2015), BadBRZ (06-25-2014), Jeff Lange (06-01-2017)
Old 06-25-2014, 03:02 PM   #11
andrew20195
Drives: 2013 Subaru BRZ
The 86 subframe has identical contours for the overpipe on both sides. It may very well fit, though on the automatic LHD car the ATF cooler is in the way. I'm not really sure if the RHD cars run the exhaust around the other side or not.
andrew20195 is offline   Reply With Quote
Old 06-26-2014, 06:30 AM   #12
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
the WRX doesn't have an overpipe, the exhaust runs under the subframe:
JP is offline   Reply With Quote
Old 06-26-2014, 08:28 AM   #13
1stGenBRZ86
1stGenBRZ86's Avatar
These might become good swap candidates in the future or good cheap starter turbo setups, as more 2015 wrx's end up in the junk yard, but at the moment, it would be way cheaper to get a pre-existing kit. Hell, I've got a custom turbo kit on my car, and if I could do it all again, I'd probably just buy a kit to spare me from the hassle.
1stGenBRZ86 is offline   Reply With Quote
Old 06-26-2014, 08:48 AM   #14
ciro
Drives: Scion FR-S
I think the big issue will be the turbo will sit to low. our engine mounts are many inches lower then other subarus.
ciro is offline   Reply With Quote
The Following User Says Thank You to ciro For This Useful Post:
AyJay (11-07-2015)
FA20DIT vs FA20 D4-s? hmong337 Forced Induction 31 07-26-2020 02:11 AM
Any of you convert from a WRX? newports FR-S / BRZ vs.... 101 04-03-2014 09:42 PM
FA20DIT parts glorydays Forced Induction 8 03-14-2014 05:03 PM
FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested kbye Other Vehicles & General Automotive Discussions 7 02-27-2014 09:40 AM
is it possible to convert metric to imperial? chenshuo BRZ First-Gen (2012+) — General Topics 26 01-07-2014 11:41 AM
