#43 |
So elite I'm 1338
Drives: WRB Subaru BRZ
#44 | |
Drives: 2013 FRS
+1 for OFT+Phantom ESC. Nothing else for that price is going to come close. |
#45 |
Drives: 2013 FR-S Argento
Depends on your goals, but guessing you're looking for 'factory plus' improvements this is what I did (and I'm cheap):
1) OFT $499+shipping new, got mine for $350 slightly used - won't give you huge actual gains, but will make the car much more responsive and fun to drive. Ecutek will do the same, somewhat higher investment though. 2) Lowering springs on extra stock struts $300 - a set of Eibach Sportline springs installed on stock struts, some people don't like springs this low but I love them. Bought them on stock struts so easy to bolt (no labor for spring swap on struts) on and easy to return to stock if I want to. 3) Cheap rims - used set of XXR 530's, 18"x8.75, for $250. Yeah they're not baller rims but they do the job, not terribly light but not terribly heavy. These combined with lowering springs *transform* the look of the car. 4) Camber bolts, front and rear plus alignment $200ish - SPC camber bolts up front, H&R camber bolts installed in rear innermost mount point on stock LCA's. Aligned, dialed in with -1.6 camber front, -2.1 camber rear, -1/32 toe in front, 0 toe in rear. 5) Cheap (but good!) tires - very slightly used set of Goodyear Asymmetric 2's, 235/40R18's, $180. Great all around summer performance tires, especially in rain, often can find these when the Focus ST guys dump theirs (OEM) for Rivals, Dunlop ZII's and the like. These plus springs plus camber bolts plus alignment *transform* the handling of the car. Yeah the sportline springs aren't ideal for track but I track the car only a couple times a year, my priorities in this case are looks over performance, and that said handling is amazing. 6) Exhaust - Greddy SP Elite, used $350, perfect for what I want. Not obnoxious at all, makes the car sound exotic, a touch porsche like but really a sound of it's own. 7) Exhaust diffuser - $60, reproduction of factory style exhaust diffuser, sold by someone here on the forums. Fills out the area below the exhaust nicely. 7) Shift Knob - ok sounds silly, but bought a used moddiction Anvil stainless steel knob for about $40. Love the way it looks and feels. Total so far, $1730, prob will invest in a good reproduction 5axis duck spoiler soon, that'll bring it up to around $1900 if I have a shop paint it. Overall it's a much nicer looking and much more fun to drive street car now, but still has a fairly conservative 'factory plus' look. |
#46 |
Junior
Drives: a car
Besides the lower top speed, what negative connotations are there for raising it? It's a Toyota unit too so it's not exactly bad quality.
#47 |
Off Topic
A higher final drive will mean higher RPM at a given speed. At 80 mph, mine is already high enough as it is.
#49 |
NASA SpecE30 Racer
Wheels and tires are the only correct answer. Every BRZ/FR-S sells with the same exact wheels and tires. Make yours different.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#50 |
Also skip the drop in filter because it's no bang, all buck. But whatever you do, DO NOT buy an Injen intake, please! I die a little every time someone does that.
#51 |
Bang for buck on pure power.... ESC, OFT....unleash some torques
...especially if you have e85 available because the updated tune is free and is good for 225whp/205wtqI have since added a OFH and trackpipe but they are mainly for the sound. [ame="https://www.youtube.com/watch?v=zWbuV0uewLM"]FRS BRZ OpenFlash header(OFH) - Nameless trackpipe - Phantom SC - YouTube[/ame] |
| The Following User Says Thank You to fenton For This Useful Post: | makesdrivingfunagain (06-25-2014) |
#52 | |
noob and expert
Drives: None :(
On the intake side of things, a k&n drop in filter IS the best bang for the buck. Also, the injen and Takeda intakes are some of the best intakes out there. For me, there is no glide in pulse and glide :p |
#53 |
Tires and a tune.
#54 |
Drives: Fiat Abarth
I made an extra 10whp/8wtq with a K&N filter at the top end.
Phantom Supercharged BRZ | 205WHP / 185WTQ Nameless FP/OP Combo |
#55 | |
#56 | |
In winter, idle goes up by about 300rpm too. I think it actually comes down to the type of driving you do, dd isn't the determining factor. If your driving is pretty much all long straight highways, I can see adding 300rpm would be annoying but then again it isn't the best place for the 86 anyways.
| The Following User Says Thank You to s2d4 For This Useful Post: | cdrazic93 (06-26-2014) |
| 3gs to spend | jb0y3 | Engine, Exhaust, Transmission | 48 | 03-09-2014 12:54 AM |
| If you had $10K to spend | jbdrs | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 12-10-2013 01:01 PM |
| First 500$ you would spend on your BRZ?? | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 64 | 10-18-2013 07:59 AM |
| If you had $2000 to spend what would you buy for your FR-S/BRZ | BlueDubbinTDI | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 09-06-2013 12:48 PM |
