Old 06-23-2014, 08:39 PM   #15
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by KGB View Post
thanks for all the quick responses, you guys are awesome! Im not looking for stupid power but with that being said im am coming from a 2012 shelby and I know there is no comparison but I want at least around 260-300hp. My budget is around $6000 maybe a bit higher with the install. I really dont want to wait 5 years for the warrenty to expire because by that time im probably going to be buying an SUV anyways for the family. I want somethimg that does not require a lot of supporting mods. Just exhaust and intake but thats about it.
Thanks again for the input.
If you go with the vortech kit, you are fine with the stock clutch etc.
It does not put loads of torque out, so you don't have to worry about breaking things. If you decide you want to go a bit faster, fuelpump/injectors and E85 can put you into ~300whp if not more, and a quick pulley swap would just add more power.
The only thing you need to worry about is the drive belt. Run a quality drive belt, and check for wear every oil change along with checking the supercharger fluid levels.
Turbo will give you more power for less, but the engine with a supercharger just feels like you stock engine but.... more. Not overwhelming or kick in your pants torque, but just that extra bit to make it really fun at high rpm
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
KGB (06-24-2014)
Old 06-23-2014, 09:00 PM   #16
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
he probably doesn't have e85 in Canada. that budget really only works for a mild supercharger.
Old 06-23-2014, 09:03 PM   #17
KGB
Drives: 2014 BRZ
Im looking at the vortech website and its about $6000 US plus tax, plus install. The turbo kits are a bit cheaper right?.
KGB is offline   Reply With Quote
Old 06-23-2014, 09:04 PM   #18
Reaper
Reaper's Avatar
Drives: violent
no. except speedbydesign. theirs is REALLY cheap. but don't forget, gauges(600), tune, oil cooler(600), someone to weld the BOV flange on(75$?), new crash bar(150$) unless you want to cut it.
The Following User Says Thank You to Reaper For This Useful Post:
KGB (06-24-2014)
Old 06-23-2014, 09:07 PM   #19
KGB
Drives: 2014 BRZ
great thanks. I will take a look after work today.
Old 06-24-2014, 03:48 AM   #20
KGB
Drives: 2014 BRZ
I checked out the speed by design turbo kit. looks pretty sweet. how reliable or reputable is their turbo compared with lets say AVO or other competitors?
Old 06-24-2014, 03:52 AM   #21
KGB
Drives: 2014 BRZ
it comes with intercooler. is that an oil cooler. sorry im not good with cars :/
Old 06-24-2014, 04:02 AM   #22
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
I don't think forced induction is the route you want to take if you don't know much about how your car works imo.
Spinning Sushi is offline   Reply With Quote
The Following 6 Users Say Thank You to Spinning Sushi For This Useful Post:
Freeman (06-27-2014), mikepaul21 (06-25-2014), mwjcyber (06-26-2014), Reaper (06-24-2014), s2d4 (06-24-2014), sshole (06-24-2014)
Old 06-24-2014, 04:22 AM   #23
KGB
Drives: 2014 BRZ
why is that? is there a lot a maintenance after the install? im not putting it in myself. Hence the research.
Old 06-24-2014, 05:21 AM   #24
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Buys car: want to drop 10K on mods before break in finished.
Not sure if taking the piss.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 06-24-2014, 05:35 AM   #25
KGB
Drives: 2014 BRZ
Meta. Im asking for advice. Not criticism. Not everyone is mechanically inclined. From what I have read, and this could be wrong. Most new cars have to be broken around 1000k. If you have advice as to how long I should wait please say so...
Old 06-24-2014, 10:13 AM   #26
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Alright @KGB here is a super basic diagram of a turbo system to show you how it works/what an intercooler is.
As you can see, the exhaust gases are used to spin a turbine. This turbine is connected to the compressor via a shaft and the entire assembly is commonly known as a "Turbo."
Since the turbo runs off of the exhaust gases, it tends to get extremely hot which leads to extremely hot intake air. Hot air = less power because the hotter it is the less dense it is.
You can see in the picture above the after the intake air goes through the turbo it goes through the intercooler. The intercooler is like a radiator but for the intake air. It sits in front of the radiator and is very noticeable (see the picture below). This cools down the intake air again and essentially gives you more power.
After the intercoller, it flows into the engine.
This is a very basic explanation of a turbo system. Quite a few supercharged systems also come with an intercooler.
I strongly suggest researching both systems on the internet to understand them better. You may not be mechanically inclined now, but all it takes is a little reading. Not only will it help you with your decision but it will help you a lot down the line when it comes to install and tuning. I know you won't be doing either of them, but it certainly helps understanding what's going on.
ToyoburuBRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to ToyoburuBRZ For This Useful Post:
KGB (06-24-2014), Lavalover (06-24-2014), SirBrass (06-24-2014), Ursam (06-24-2014)
Old 06-24-2014, 11:33 AM   #27
Turbowned
Turbowned's Avatar
Generally speaking, a supercharger should be more reliable and less fuss because it is internally lubricated and does not have to tap into the engine oil supply. Also, boost tends to be more consistent and thus safer because it doesn't rely on a wastegate to meter boost pressure (again, generally speaking). In the FR-S/BRZ, the primary catalytic converter is located in the exhaust manifold, so that has to be eliminated if you install a turbo. Therefore, your likelihood of passing emissions without doing any funny stuff to the ECU becomes a challenge as well.
You can upgrade to a smaller pulley to run more boost, and if you max out the Vortech or Rotrex blower, like you could max out a turbo, you can always upgrade to a larger unit.
The Following User Says Thank You to Turbowned For This Useful Post:
KGB (06-24-2014)
Old 06-24-2014, 12:01 PM   #28
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
It is cheap because it is a ripoff of the Greddy turbo kit, thus reducing the R&D costs significantly. It is made in Taiwan.
Jyn is offline   Reply With Quote
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 03:40 PM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 08:02 AM
ECU Tuning for Reliability regal Engine, Exhaust, Transmission 7 06-27-2013 08:07 AM
Scion top rated for reliability FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 10-29-2012 05:13 PM
