#869 |
Drives: 2014 Pearl White BRZ
I suppose I could try to replace the entire thing with this:
[ame="http://www.amazon.com/gp/product/B00L2SF64E/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]Amazon.com: Axxess AX-USB-35EXT USB + 3.5 Waterproof Cable w/ Covered Panel: Car Electronics[/ame] (Not sure if it will fit the location but it has to be close) - Edit: Looks like someone on here has used it and it is a direct replacement! woot Then I could add a 3.5 to dual RCA splitter and plug them into the ca-fi left and right audio in. The usb should plug into the ca-fi cable. Looks like this thing has 6 feet of cable lol. Last edited by Fastbrew; 06-19-2014 at 02:25 AM. |
#870 | |
Drives: gray
#871 | |
Drives: 2013 WR Blue Limited Manual BRZ
Just take some pliers and bend the front parts of the brackets a bit outward, takes almost no strength and all of 10 seconds, then line it up like in the pictures. |
#872 | |
I actually downloaded this and it seemed to really improve touch response, maybe it was just in my head but see if you guys notice a difference too. Last edited by Deathalo; 06-19-2014 at 12:06 PM. Reason: Forgot link |
#873 | |
| The Following User Says Thank You to Deathalo For This Useful Post: | Fastbrew (06-19-2014) |
#874 |
12% Done with the car.
Drives: FRS
Micro Sd card is stuck, not popping out. Not reading Usb's. Brackets problem fixed though guys thanks!
i could have lived with the USB not working since I could have depended on the SD for music, but I guess I'll have to take it in for warranty :/. Bluetooth is great, but the quality from a USB or SD card really brings out my system.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
#875 |
Grip>Slip
It's not the CPU choking torque down, it's the bluetooth. I've run both bluetooth and USB connections to torque on my head unit and when connected VIA USB the refresh rate is easily 5-10 times faster than on bluetooth, and torque has no issues.
| The Following User Says Thank You to xjohnx For This Useful Post: | Prog (06-19-2014) |
#876 | |
#877 | |
Drives: FRS
Tried that. It's stuck lol. No popping out.
#878 |
Yeah but are you also running things like poweramp and maps/gps data at the same time?
#879 |
Grip>Slip
#880 |
Wow, which BT Adapter are you running and are you using fast com mode?
#881 | |
Grip>Slip
I'll have to try and make a video of it once i finish updating the firmware/reinstalling my apps. |
#882 | |
Drives: Toyota Sienna
P.S. If someone does not know - screenshot becomes simultaneous pressing hard buttons <PowerOn> (volume control) and <Back> on 1 second. Screenshots in a .PNG remain in folder SDcard/Pictures/Screenshots |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
