| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1107 | |
NisSubuGuru?
Drives: 2011 Subaru WRX
8.5 wide is a good width for a 225, depends on the tire brand, that'll determine how "stretched" the sidewall will be. 225 on a 8" wide is likely to have a more "flush tire" look to it. However, like i said, it all depends on the tire make/model. They all fit a little differently. A 225 in one brand, can sometimes run wider than even a 235 from another make. A stretched sidewall is stronger and more resistant to caving, or rolling over, but a more natural fitting relaxed sidewall will have more grip feedback at the limits. you may also have a bit more Curbing protection when parallel parking
Past to Present |
#1108 |
#1109 | |
Drives: 2013 Subaru BRZ
RPF1: 18x8 in 35 or 45 offset RAIJIN: 18x8 in 35 or 45 offset GTC01: 18x7.5 in 48 offset; 18x8 in 35 or 48 offset EV5: 18x7.5 in 38 or 45 offset Any reason (other than looks) to prefer one over the other? And how do I determine which offset is right? |
#1110 | ||
NisSubuGuru?
My girl is affraid to drive cars i own, so i'm good..lolall my damage is self inflicted ![]() Quote:
if you're going with a 225/40 18 tire, i'd say go 8" wide, it's a better fit IMO. for 8" wide, it seems your offset choices are 35 or 45. If you care about the Look, +35 will Sit better. but your steering geometry will stay truer with the +45. The +45 will poke ~15mm more than stock, the +35 ~25 mm more than stock. If you're not planning on lowering at all the +35 might look strange. With a large drop (1.5"+) the +45's even with their 15mm of "poke" may still end up looking very tucked. but i mean, if all you care about is the drive, the +45 is a better fit. provided it clears the inner suspension. you'll have ~10mm less inner clearance..you're likely fine. a +35 has the same inner clearance as stock.
Past to Present |
#1111 | |
Bit of a newb, but I think I follow what you're saying. I do want to maintain steering geometry, but I probably will do lowering springs at some point. When you say the +35 "pokes" more than +45, do you mean they will stick out closer to the fender? And what exactly does "tucked" mean? You mean like hugging against the fender? Sorry for the dumb questions, and thanks for the help. It sounds like +45 would work better for me, since I don't care too much about the wheels hugging SUPER close to the fenders...of course I don't want the wheels super pushed in either. So +45 sounds good, assuming it clears the suspension. |
#1112 | |
![]() Will do. At this point. I'm waiting to see what wheels will be available and how they will fit. This will be my DD so I'm looking at 18's max.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#1113 | |
NisSubuGuru?
For a similar price/performance range, i like 5zigen ..although their style selection is VERY limited. As far as performance wheels, there's not alot of competition in enkei price range. If you were willing to spend a bit more you could look at OZ's/sparco wheels(cheap OZs), and the Work Emotion Line. Work emotion CR kai/ultimates have always been one of my favorites. I'll probably end up with those for the FR-S/BRZ. These Works can easily be twice the price of enkei's though, so i can't say there's value in them, but the heart knows no value ![]() http://www.workwheelsusa.com/product...=27&wheel=1003 I do think any enkei is a great choice though.I've owned the GTC01,EKM,RPF's and the RPMs before, all great rims. Their styles are rarely flashy but they get the job done
Past to Present |
#1114 |
AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I'm looking for a lightweight 17x7 to use for autocross. In order to stick with stock class in SCCA you need 17x7 wheels. Anyone ever heard of or have experience with the Konig Daylite? A 17x7 wheel is only ~15lb. at $140 a piece it's hard to beat. However it only comes in a 40 offset. While it work on the BRZ/FRS chassis?
#1115 | |
NisSubuGuru?
Cheap/light/strong..when it comes to wheels u only get 2 out of the 3. If you Really cheap out theyre often not strong OR light
Past to Present Last edited by CoryUyede; 04-11-2012 at 01:24 PM. |
#1116 | |
Drives: ND2, formerly BRZ (MT/CBS)
I'm looking at Kosei K1-TS. Kosei lists them as available in 17x7, 42mm offset, 5x100/114.3 and they should be ~$200 and ~15lb but I can't find a source yet at this offset. |
#1117 | |
Site Moderator
Drives: Stuff
These were Konig Heliums and they are well known for their cracking and breaking, kinda like the reputation Rota has, except it's actually deserved for Konigs :P
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#1118 | |
#1119 | |
Site Moderator
Drives: Stuff
I'm bent an OEM enkei before too I guess. I've never damaged any other wheels so I think you are confusing me with someone else I've seen plenty of wheels get damaged though.
-Dave
#1120 |
Sneakerhead
Drives: 2003 Honda Civic Si
| How to embed a YouTube video in a post | ichitaka05 | Site Announcements / Questions / Issues | 71 | 03-21-2021 03:47 AM |
| Post your Workspace. | Ricepuddin | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 11-25-2014 10:15 AM |
| Post your Desktop | Ricepuddin | Off-Topic Lounge [WARNING: NO POLITICS] | 125 | 10-10-2013 02:38 PM |
| Any news or updates for Oz post here | Calais | AUSTRALIA | 92 | 07-28-2011 06:55 AM |
