#4789 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
The car is at Toyota and so far we have identified Spark plug on cylinder 3 electrode totally burnt off, no ignition on bank 3. We suspect the supercharger has packed up, it's dead and not blowing, fortunately I just received the replacement blower, which we exchanging. Keep am eye on your oil. While we at it will double check coil packs, injector seals. Got a small oil leak out the cam plate, which I'm replacing with Raceseng cam plate today. Hopefully engine all safe and back on the road today. Keep you posted. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | CK_Bladesmith (06-17-2014) |
#4790 |
Super 86
Drives: Red 86 GTS
So haven't been following tuning lately but has anyone done any Innovate maps via OFT?
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#4791 |
PhoneFlash by EcuTeK
As a pointer for all Innovate owners, these blowers eat oil MUCH faster than stated in the service intervals. I would check my supercharger oil at every motor oil change if I were you.
Sincerely, Zach Delicious Tuning |
| The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post: | CK_Bladesmith (06-17-2014), Dustin (06-17-2014), Khorne (06-17-2014), mikalem (06-17-2014), whataboutbob (06-17-2014) |
#4792 |
Super 86
Drives: Red 86 GTS
On that note what oil is everyone using, the manual says Redline 75W90NS oil i have the plain 75W90 on hand, has a friction modifier adidtive pack in it. Messaged Mark at Sprintex to see if that's cool.
#4793 | |
AutoX-10/10ths every run
Redline 75W90NS. As Zach said, be sure to CHECK THE OIL often.
| The Following User Says Thank You to whataboutbob For This Useful Post: | DeliciousTuning (06-17-2014) |
#4794 | |
Drives: 2014 BRZ Limited-SWP
Is anyone having issues with the carb tune or with a custom and minimal mods? Or is the charger setup itself causing everyone issues? |
#4795 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
You can have issues even if you remain stock.
#4796 |
Drives: GBS Premium
I have no issues, the only custom thing I have is a smaller pulley. I am using the moto-east tune.
#4797 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
I spoke with Bill @ Delicious today a bit and he seems confident he has the sputtering issue figured out. I'm dumb when it comes to tuning so I won't try to explain but like I said before, he seemed confident that he's got it sorted out. Hopefully we'll have the update soon. I'd still like to get the moto-east tune just to see the difference in the tune. @moto-mike seems like a really good guy. I addressed some of my concerns to him and he was willing to have me sample their tune before purchasing to see if I was satisfied with theirs.
| The Following User Says Thank You to Dustin For This Useful Post: | Toyota86.ir (02-25-2016) |
#4798 | |
Drives: 2020 DGM BRZ Limited
I've been providing feedback to Bill on the misfire issues, hopefully he'll have something soon for everyone - the current revision I have looks to be solid numbers wise, I'm just looking for some last adjustments around ECUTEK features. Sent from my Nexus 5 using Tapatalk |
| The Following User Says Thank You to mikalem For This Useful Post: | Dustin (06-17-2014) |
#4799 |
I ran the CARB tune for over 20K with no issues.
#4800 |
We did find the hiccup in the tune, or the misfire people were having. When the supercharger is under light load, the 8.58 tune still continues a mix of port and direct injection through to redline. We were using this method in order to have linear input under all conditions but this has its drawbacks as we now see.
What we found was the MAP sensor will actually jump around quite a bit on the smaller pulleys a bit above 4.5K RPM, as much as 1.5 pounds of boost. We believe this is due to the supercharger itself causing the pulses of air to the MAP sensor as we have not seen it happen on other boosted vehicle. Because of this the port injectors will follow the same characteristics and cause the AFR ratio to jump up and down, between 13.0 and 15.0. This is causing the car to see drastic quick changes in the AFR which is causing the vehicle to hiccup/misfire in these conditions. FYI - This is NOT an issue on the CARB tune. What we did to resolve this is go back to what Subaru did from the get go, run pure direct injection above 4K RPM so that the fuel delivery is smoother. Now with pure direct injection the AFR stay much closer to stoich. Now that we have that taken care of we spent a little more time refining the map more. So here is the list of updates to the new tune. Final Testing in Progress - Here is the latest - Version Number To Be Announced 1. Hiccup/Misfire gone, confirmed by myself and two other customers on 70mm pulley and pump gas. 2. Smoother acceleration than before for pump gas cars especially on smaller pulleys from a dead stop and even when cold. 3. Smoother acceleration through the 3-4K rpm range. There was what felt like a slight dead spot, it is now gone and smoother through this area. 4. Better idle for auto's with smaller pulleys or cars with heavy loads on them. We spent some time spending time loading the engine up under idle and now have a tune to hold idle a LOT better. 5. We found some small spots in the tune where we could actually improve the fuel economy a little more. Though these are very minor they may add up over time. 6. We are finalizing testing on our 69mm pulley (slightly more boost), and so far the tune has been working great on it. So we might be adding this to our official tune. I would like to put a quick note out there to Mike at Moto-East even though we never officially spoke. I believe Mike at Moto-East actually experienced the problem with the map sensor jumping around on these kits prior to us as we had heard this through EcuTeK. I believe he was testing some larger MAP sensors so people could read boost but the downfall was how drastic the jumps were on the MAP sensor causing the car to stumble a bit in power. This very insight gave us the knowledge to look at this measurement specifically so we could determine what was going. So I would like to thank Mike at Moto-East for that tid-bit of information. Regards, William Knose Delicious Tuning |
| The Following 8 Users Say Thank You to DeliciousTuning For This Useful Post: | calispec (06-17-2014), CK_Bladesmith (06-17-2014), Dustin (06-17-2014), Ethan (06-18-2014), mikalem (06-17-2014), TemeCal (06-17-2014), whataboutbob (06-17-2014), xjohnx (06-17-2014) |
#4801 | |
Drives: Raven FR-S
Is the 69 mm pulley going to be detrimental to the blower in regards to going over it's redline?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#4802 | |
I do from what Sprintex has told us that there are race teams around the world running pulleys smaller, as small as 63mm, but this is well beyond the original spec of the supercharger and of course not recommended for daily use. Also much smaller than 69mm on 91 octane is getting to a point of diminishing returns on 91 octane. Though 93 and 94 might be better off and of course E85 will soak it up and love it. Cheers, William Knose Delicious Tuning |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
