Old 06-12-2014, 12:41 PM   #127
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Originally Posted by gonzo View Post
I got the clicking about 6-8 months ago and it's getting worse. Stock suspension and only a tune. Changed from stock tires to michelin pilot super sports also around 6 months ago but no hard launches or autocross since the new tires.
Well, this is disturbing...
Eurasianman is offline   Reply With Quote
Old 06-16-2014, 06:10 PM   #128
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
So my 2nd axle is on it's way out. Any suggestions of where to order spares? I think I'm just gonna order two this time so I have a back-up.
I got about 30K miles and 30ish autoX events out of each axle so that's not so bad.
Old 06-17-2014, 01:38 AM   #129
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
Because the stock setup seems to be reliable, there has yet to be someone completely stock with a broken axle. If you'll notice every single post in this thread is on some form of aftermarket suspension and/or has made significant changes to the power output.
My stock FRS minus an air filter and brake pads broke the LH axel at 12k miles and four track days.
WillRacer1jz is offline   Reply With Quote
Old 06-17-2014, 02:32 AM   #130
pghfan19
Drives: honda civic ex
So just curious if i'm experiencing the initial symptoms of a broken axle or not..My car is making the clicking/ticking noise..happens when i'm in 1st and 2nd gear and reverse..car was taken to the dealer and had the control arm bolts loosened, repositioned and retorqued, and the noise went away. 3 days later and the noise is back..Car is completely stock..Just wondering since re-torquing the bolts didn't solve the problem if its possibly related to a broken axle?
pghfan19 is offline   Reply With Quote
Old 06-17-2014, 03:37 AM   #131
Kostamojen
FYI apparently the BRZ tS in Japan has beefier axles from the factory... I think someone is trying to get part numbers for them.
The Following User Says Thank You to Kostamojen For This Useful Post:
BRZPDX (06-17-2014)
Old 06-17-2014, 05:02 AM   #132
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Sounds interesting, I wonder if they are going to cost as much, or more than the DSS axles..
I have heard that even with stronger rear axles, if the geometry is not fixed, even the beefier axles can pop due to the angle and stress to the material. If you can raise the rear diff, a stock axle will hold more power when lowered.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 06-17-2014, 11:07 AM   #133
Kostamojen
Certainly more expensive considering they will need to be shipped from Japan.
And yes, until folks un-slam their cars and fix their geometry, the underlying problem won't be solved and it will keep happening.
Old 06-17-2014, 11:42 AM   #134
BlaineWasHere
Grip>Drift
Drives: FRS
Do you guys have any good sources for purchasing stock axels?
Old 06-17-2014, 11:51 AM   #135
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Ebay?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-17-2014, 01:26 PM   #136
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
This is the first post I've seen with stock power and suspension breaking an axle.
Sorry you had to deal with it, I think it should withstand track days no problem but you're still a very very small minority.
ineedyourdiddly
WillRacer1jz (06-17-2014)
Old 06-17-2014, 04:30 PM   #137
BlaineWasHere
Grip>Drift
Drives: FRS
Originally Posted by feldy View Post
Ebay?
There are none on ebay right now...
Old 06-25-2014, 05:39 PM   #138
Roxy86
Roxy86's Avatar
Drives: Diesel daily / FR-S
S2000's have a similar problem with lowered cars...
Someone should develop some alxe spacers - pushing the axles further in by the CV
Roxy86 is offline   Reply With Quote
Old 06-25-2014, 11:20 PM   #139
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
I think I may be joining this list very soon.
Edit: false alarm, not an axle...yet. combination of the diff brace and exhaust/diffuser interference were generating the sound.
Kwaziekeller is offline   Reply With Quote
Old 06-26-2014, 01:10 PM   #140
Dipstik-sportech
Dipstik-sportech's Avatar
Well went drag racing again. Hopped like a somebitch and still knock on wood haven't broke an axle. I'm lowered on h&r super sports
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
