Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > EUROPE
Old 06-10-2014, 06:27 AM   #421
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Hi there,
Americans use a different rating sytem: AKI for them, RON for us. Their "Premium" fuel (93AKI) is pretty much our "Super Plus" (98RON).
[ame="http://en.wikipedia.org/wiki/Octane_rating"]Octane rating - Wikipedia, the free encyclopedia[/ame]
That being said, it explicitly says "98RON only" on the sticker on my fuel door.
It seems that 95RON fuel is more prone to the "cricket syndrome" (fuel pump chirping) and yes, you will probably get less power, particularly on a hot day.
Guillaume is offline   Reply With Quote
Old 06-10-2014, 05:07 PM   #422
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by Khazandra View Post
Elbarto, where in Waasland are you from? I'm in Temse.
I'm from Sint-Pauwels (it's the small village in between Stekene and Sint-Niklaas)
Originally Posted by JoeHK View Post
Hey guys a little question, i just came back from filling my tank and was wondering what fuel you guys use?
95 or 98? I'm asking here cause if i'm not mistaking the Americans have different fuels...
Does it make a big change which i use? I read somewhere that 98 is better for performance & just in general for the engine if it's a high compression ratio one, and ours is high compression ratio right (12.5:1) ?
And if i'm using 95 right now, am i allowed to drive this tank empty & then just fill it with 98 next time?
Thanks guys!
Grtz
I use 95 for daily driving (max 3000rpm), 98 for fun drives. It's the first car I actually notice a difference between 95 and 98.
To switch just drive your tank empty, fill up with 98 and done. The first 25km's or so you don't notice the difference but after that you will start to feel it (buttdyno).
But don't expect big changes.
Originally Posted by Guillaume View Post
It explicitly says "98RON only" on the sticker on my fuel door.
I don't think anybody in Belgium has crickets? I drive for over a year now with a tank of 95 and never heard the infamous crickets.
I think it's more the quality of the fuel that's causing it. Cheap white brand leftovers will have more polluted fuel than the more expensive brands.
The Americans also have 89AKI (something like 93RON) and winterblend fuel and other crapfuel like that.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 06-10-2014, 05:49 PM   #423
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Why the hell would you put in 95 when it clearly says to put in 98 :/ well your own choice offcourse
GT86meMR2 is offline   Reply With Quote
Old 06-10-2014, 05:55 PM   #424
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
I used to go to primary school in Kemzeke (Stekene) :p
That means we're all pretty close!
Anyway, i know it says 98 in the fuel cap cover, that's what got me confused actually... But it's good to know, i like to drive in the higher RPM's once in a while so guess i'm gonna switch over to 98, might as wel
Thanks for the explanations guys! This was something kinda bothering me, i want to feed my baby correctly!
Oh & something else, anyone else experiencing loose shift knobs? I was shifting the other day and suddenly the shift knob turns a quarter clockwise... as if it wasn't screwed on correctly And it still felt very loose...
So i turned it around once to make it sit tight and heard something snap... the plastic cover which shows the gears popped half off... So i immediately got in a groupbuy here from Anarchy Motive for a wheighted shift knob! Or like they say: 670 grams of shifting butterieness
Grtz
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 06-10-2014, 06:27 PM   #425
projectXTR
Drives: Sterling Silver BRZ
670gr.... wait what?
projectXTR is offline   Reply With Quote
Old 06-11-2014, 03:32 AM   #426
JoeHK
JoeHK's Avatar
Well, 671 to be precise (if you'd like they're up in the groupbuy section)
It's a weighted shift knob, so it just help make the gears "pop" instead of feeling like you're crunching them...
Also i'm going to order MTEC shift springs so shifting should be optimal
Grtz
Old 06-11-2014, 07:13 AM   #427
remme
remme's Avatar
Drives: GT86 & Celica T180
In dutch, but understandable for most here.
http://members.upc.nl/h.hoften9/hoof...offen_anwb.pdf
95 octane, ignition has to be less pre-ignited than 98 => a little less power on acceleration and high rpm.
remme is offline   Reply With Quote
The Following User Says Thank You to remme For This Useful Post:
JoeHK (06-11-2014)
Old 06-11-2014, 04:14 PM   #428
Khazandra
Drives: Hot Lava GT86
Originally Posted by elBarto View Post
I'm from Sint-Pauwels (it's the small village in between Stekene and Sint-Niklaas).
Yes, I know where Sint-Pauwels is.
About 2 weeks ago I was on the road from Temse to Kruibeke. On the way I saw 2 GT86/BRZ (white and silver) coming from the other way.
And sometimes I don't see one for weeks.
Lot of people here are from the same area.
Khazandra is offline   Reply With Quote
Old 06-11-2014, 05:54 PM   #429
projectXTR
JoeHK, is it possible i saw you in the Meise area, near the roundabout of Borght this evening?
I was riding with a group of cycling friends on the road.
License plate 1-FTU-something?
Old 06-11-2014, 05:57 PM   #430
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's cheaper for daily use. 95% of my driving time is work/home/store with shifting at max 3000rpm with a max speed of 90 kph.
When I want to have fun with the car I switch to 98.
It runs perfectly on 95, just less power because the ECU corrects itself for the lower RON-value.
Those cars are built for the entire world, they have to build in safety-checks to accommodate for bad fuel, lower octane, big temperature differences and various heigts.
So here in Belgium it's no problem, we are at sea-level, quality fuel and normal temperatures.
It's crazy here, together with you guys it's around 15 cars that I know off that are in the neighborhood, and only seen 3 others in the rest of Belgium (and number 4 being Guillaume).
I probable spotted also a few off you guys driving around here.
Old 06-12-2014, 02:12 AM   #431
JoeHK
JoeHK's Avatar
Nope, don't think that was me..
My license plate is 1-GHS-... :p
But i know there is an other black GT86 somewhere here, maybe you saw that guy :p
Grtz
Old 06-12-2014, 03:05 AM   #432
Yrr
Yrr's Avatar
Drives: Toyota GT86
Most of the time I refill my gastank at BP and only use RON98.
But last week I had to stop at some local gasstation and filled it up with "Super plus" and unfortunately i'm hearing crickets under the hood the last three days.
Maybe it's caused by the combination of bad fuel and the "hot" weather the past days in the Netherlands?
I hope they will be gone after after the next refill
Yrr is offline   Reply With Quote
Old 06-12-2014, 11:03 AM   #433
JoeHK
JoeHK's Avatar
I'm sorry guys if this sounds stupid... but... crickets? Like in the little animals crickets?
My knowledge/experience on this subject obviously hasn't reached that far yet :p
Grtz
Old 06-12-2014, 11:07 AM   #434
Guillaume
Guillaume's Avatar
Drives: Exige S 240
http://www.ft86club.com/forums/showthread.php?t=9836
http://www.ft86club.com/forums/showthread.php?t=12422
http://www.ft86club.com/forums/showthread.php?t=8678
http://www.ft86club.com/forums/showthread.php?t=9837
http://www.ft86club.com/forums/showthread.php?t=9686
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 11:35 PM
GT86 pricing for Belgium (Europe) NA_T Scion FR-S / Toyota 86 GT86 General Forum 13 01-15-2012 12:33 PM
MR2 OWNERS Abflug Other Vehicles & General Automotive Discussions 8 09-02-2010 09:35 PM
