go_a_way1
Old 06-10-2014, 01:42 AM   #1471
CSG Mike
CSG Mike's Avatar
Just a FYI for you guys.
http://www.ft86club.com/forums/showthread.php?p=1787471
A lot of my posts in that thread are gone, leading me to believe that the vendor asked for my posts in that thread to be deleted. I'm 100% confident that the product is crap at this point.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
finch1750 (06-10-2014), gramicci101 (06-10-2014), kavanagh (06-10-2014)
Old 06-10-2014, 03:55 AM   #1472
uncivilised
Drives: 86 GT
if i wanted to use semi slick tyres, most likely the advan a050, would it be worth staying with 17x8 and use a 215/45/17 tyre or jump up to a 17x9 wheel and use a 235/45/17 tyre?
uncivilised is offline   Reply With Quote
Old 06-10-2014, 03:56 AM   #1473
juliog
juliog's Avatar
Drives: 86
^ mods? Application?
Sent from my iPotato
juliog is offline   Reply With Quote
Old 06-10-2014, 04:02 AM   #1474
uncivilised
Drives: 86 GT
at the moment:
225/45/17 rs3 on 17x8 wheels
e85 tune
catless EL header
front bbk and coilovers
4.55 final drive
stock aero
Old 06-10-2014, 04:13 AM   #1475
juliog
juliog's Avatar
Drives: 86
Auto cross or race tracks (which ones?)?
Old 06-10-2014, 05:35 AM   #1476
uncivilised
Drives: 86 GT
Race tracks. Time attack
Old 06-10-2014, 08:09 AM   #1477
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
at the moment:
e85 tune
catless EL header
4.55 final drive
stock aero
You can go with either (I've assumed you've increased power & torque ~20% via the E85/4.55 combo). If you plan to develop the car further, including aero, I'd suggest going straight to the 17X9/235 combo. Use a probe pyrometer to confirm your camber and toe are still good with that tire; if you haven't already, it's probably worth asking other racers how stiff they've found the sidewall to be. How much do those tires cost (I did a quick search and they looked pretty spendy!)?
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
uncivilised (06-10-2014)
Old 06-10-2014, 08:25 AM   #1478
dradernh
Originally Posted by RFB View Post
Im tracking the Mosport Gran Prix track next week (long high speed straights and corners).
Any tips on how to better throttle steer ?
will try slightly tail happy on Monday.. and more front grip as well.
Did a full day at Mosport Gran Prix track today.
NO oversteer NO understeer.
Good enough for me.
How fast ? Are you kiddin ? Off camber before Moss corner comin up ?
You think I was lookin at the speedo ?
The throttle ? I was jerkin me right toes up and down as needed and watchin apex line for entry and exit.
Had blisters on my hand from the round handlebars at the end of the day !
Got it.
Old 06-10-2014, 10:34 AM   #1479
gramicci101
Off Topic
Since even the brake pads were proprietary, it wasn't too tempting anyways. I like having options available to me.
Old 06-10-2014, 01:41 PM   #1480
ZionsWrath
Thanks
ZionsWrath's Avatar
How often do you bleed the clutch?
I did the brakes RBF600, and made me notice the clutch master cylinder fluid is very dark compared to the new brake fluid.
Should I bleed it? I have a bottle of Subaru brake fluid, can I use that for the clutch?
Old 06-10-2014, 04:45 PM   #1481
becauseracecar1
becauseracecar1's Avatar
Drives:
Thanks to all of the advice I got here, I went 4 seconds faster this time in homestead!! I think I'm finally getting that "smoother is faster".
This was my fastest and smoothest lap:
[ame]http://youtu.be/tUtW39aZJKI[/ame]
This was my second fastest lap but it was a little sloppy. My tires started going off and after 5 sessions I think I was a little tired.
[ame]http://youtu.be/rEy1XP1zcdk[/ame]
I'm all ears for more advice!! Thank you!!
Car was stock, with the exception of hawk hp+ pads.
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
The Following User Says Thank You to becauseracecar1 For This Useful Post:
juliog (06-10-2014)
Old 06-10-2014, 05:10 PM   #1482
ddeflyer
One thing that will help some is to not do such a binary steering input. Feed steering in to let the car's weight transfer. Specifically you want to have the derivative of your steering lock (so the rate of change) have a curve to it (sort of like a bell curve). The idea here is to get the weight to transfer smoothly so you have more consistent traction.
As there is no view of your hands in the first video I don't know if you were doing it there, but in the second one you are having pretty jerky inputs (though it looks like you smooth it out some for the second lap's start).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
becauseracecar1 (06-11-2014)
Old 06-10-2014, 05:38 PM   #1483
CSG Mike
CSG Mike's Avatar
Once a year, and just use fluid left over from a brake bleed.
If you're not going to be vigilant about it, get a cheap DOT3 fluid from your local auto store, and use that.
Old 06-10-2014, 07:38 PM   #1484
uncivilised
Drives: 86 GT
yeah the a050 are quite a bit normally but i have mates in the industry that can help on that
it seems to be the tyre of choice in australia so ill go with it soon enough.
The Following User Says Thank You to uncivilised For This Useful Post:
CSG Mike (06-10-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
